Limited slip additive - Dodge Cummins Diesel Forum
 6Likes
post #1 of 13 (permalink) Old 01-24-2020, 04:05 PM Thread Starter
Can anyone clarify if I need to purchase limited slip additive for 06 2500 11 1/2 AA differential. The manual states if its a Trac-Lok Differential then additive is needed but if its a Trac-Rite EL then not needed. The dealership had no idea what I was talking about.
On another note I read if the clutches inside the diff that lock up are worn and not adjusted regularly (75K miles or so) that no longer will the diff go into full lock and then what would be the point of the additive.
Need some education, thanks
liska is offline
post #2 of 13 (permalink) Old 01-24-2020, 07:02 PM
jnstrong's Avatar
I don't believe there was an axle change between 04 and 06. My 04 11.5 AAM has a Torsen style LSD, requires no LSD additives (aka there are no clutch packs).
tryNto likes this.
Early '04 / 5.9L / NV5600 / 3.73 / 2500 SLT 4x4 / QCSB / 5in TBE 6in tip/ Fass 150 / Tuned
jnstrong is offline
post #3 of 13 (permalink) Old 01-24-2020, 08:55 PM
nosympathy's Avatar
Only time I've seen people say to add it, is if they chatter from a stop making an immediate turn. My front did this and I opted to do the 75W140 route instead. That shut mine up.
05 CCLB 48RE
nosympathy is offline
post #4 of 13 (permalink) Old 01-24-2020, 10:06 PM Thread Starter
The MOPAR manual does not state the AAM is a Torsen, so I am guessing your diff is not OEM. I really wish I had a Torsen because that system is great and simple...just pure mechanics. Its been a while since I saw the guts of my diff but I am 99% sure its not a Torsen gear setup. So back to the original question about the additive, anyone?
liska is offline
post #5 of 13 (permalink) Old 01-24-2020, 10:15 PM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 16 reviews
I ran 75w85 limited slip fluid and a bottle of mopar limited slip additive in mine. Try running without additive and if you need it, itís a small bottle that only holds a few oz so it wonít yet to add later.
1998 12v, 4x4, Club Cab, Carli, Thuren, BlueTop, Core 4x4, BD Diesel, PDD 5x.012, South Bend
2012 Laramie Longhorn, EFI by Ryan, Carli, Thuren
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is offline
post #6 of 13 (permalink) Old 01-25-2020, 11:30 AM
Chrome's Avatar
The AAM rearend uses a different style locker that never requires additive.
2003 Dodge Ram 2500, QCSB, 4x4, Nv4500 w/ mainshaft, Valair clutch, Edge Evo2, AFE Bladerunner, ARP Studs, SRT10 Hood, Sport front, 285 Falkens. Laramie interior. 09 steering. Redhead + Borgenson 275,000 miles and counting + 2013 Ram 5500 4x4 6.7 aisin CC 11' bed
Chrome is offline
post #7 of 13 (permalink) Old 01-25-2020, 12:11 PM
Ridin1 feels degraded
tryNto's Avatar
No clutch discs inside
CTD NUT and rghavana like this.
'03 QCLB 2500 305/555 NV5600 w/ FastCoolers 3.73 4x4, Color match Lear Topper.
Smarty S-06 PoD, Edge CTS for Gauges, DPP Cool Tube w/ OEM AF Box, Baldwin PF7977, GDP MK-2 FF Kit, Pusher Intake Horn, Adj. Boost Elbow @ 30psi, OEM Fan Clutch Delete/Mod, Steering Box Brace, On-Board Air w/Horns
tryNto is offline
post #8 of 13 (permalink) Old 01-25-2020, 12:42 PM
rghavana's Avatar
11.5 AAM DIFFERENTIAL , if equipped with antispin, is an AAM Trac-Rite GT
DESCRIPTION
The TracRite™ differential is a helical gear differential.
The differential has two side gears, six pinion gears and six pinion brake shoes.
Trac-Rite™ differentials DO NOT require Limited Slip Additive.
AAM ID info here
http://www.demandaam.com/product-cat...tion-enhancing
tryNto likes this.
04 QCSB HO Automatic
rghavana is offline
post #9 of 13 (permalink) Old 01-25-2020, 12:43 PM
ofelas.5z's Avatar
Do not "require", but I've found some Track-Rites did better with some additive
R12 in the summer, Webasto in the winter; cassette tapes & SAE-20078 all year.
ofelas.5z is offline
post #10 of 13 (permalink) Old 01-25-2020, 07:01 PM Thread Starter
Perfect, thanks as always!
liska is offline
post #11 of 13 (permalink) Old 01-29-2020, 03:10 AM
smelonas's Avatar
Its a torsen style differential.. and Im sure someone will correct me on exactly what style it is from there. Yeet.
2007.0 Ram 2500 MCSB Laramie - FASS150 - VB BY DYNAMIC - 2" THUREN SUSPENSION - 13.8s 1/4 - MM3 - STOCK INTAKE AND EXHAUST.. WERE RECYCLED, YEAH THAT. - AMPs - LOTS MORE STUFF SOON
smelonas is online now
post #12 of 13 (permalink) Old 01-29-2020, 03:53 PM
tryNto's Avatar
2 informative links on Diffs.
difference explained.
https://www.carthrottle.com/post/eng...table-for-you/
Old but basic.
rghavana and smelonas like this.
tryNto is offline
The Following User Says Thank You to tryNto For This Useful Post:
smelonas (01-29-2020)
