05 Cummins 6 speed Manual - Dodge Cummins Diesel Forum
 3Likes
post #1 of 25 (permalink) Old 12-10-2019, 11:32 PM Thread Starter
Have new injector just got new long block 5k miles ago south bend dual disk clutch I haul often and need a turbo to keep egts cool and also give me better mpg then my stock one
2005 Dodge Ram 3500 dually 4door long bed 6speed g56 4x4 255/80/17 south bend dual disk smarty s06 and edge cts2 with pyro gauge new injectors new long block stock turbo
Buckshot0887 is offline
post #2 of 25 (permalink) Old 12-11-2019, 03:47 AM
tryNto's Avatar
Is there a question in there somewhere?
Rethink and repost with some sense of structure.
rghavana likes this.
'03 QCLB 2500 305/555 NV5600 w/ FastCoolers 3.73 4x4, Color match Lear Topper.
Smarty S-06 PoD, Edge CTS for Gauges, DPP Cool Tube w/ OEM AF Box, Baldwin PF7977, GDP MK-2 FF Kit, Pusher Intake Horn, Adj. Boost Elbow @ 30psi, OEM Fan Clutch Delete/Mod, Steering Box Brace, On-Board Air w/Horns
tryNto is offline
post #3 of 25 (permalink) Old 12-11-2019, 10:58 AM
trevdogg67's Avatar
Agreed!
Very hard to read. Re write that or youíll never get good answers.
06 2500 qc 4x4 long bed, Dynamic 48RE, 4Ē TBE, s&b intake, leveled 35's, GDP 2 mic filter kit, thuren track bar, one piece driveline, redhead steering box, Carli ball joints, KMC Hoss 18s, EFI live, isspro EV2's, Detroit Tru-trac rear
trevdogg67 is offline
post #4 of 25 (permalink) Old 12-11-2019, 11:11 AM
Babin Farms's Avatar
Ok, so I think your asking about how to get EGT down and get better fuel mileage while towing. We need more detailed info. Any other modifications done to the truck??
A Signature with these details would help out in any future threads.
2017 GMC 2500 6.0
SOLD - 2008 3500SRWCCLB 4x4 6.7 Cummins, G56 w/South Bend DD
Riding the "Struggle Bus"
Babin Farms is offline
post #5 of 25 (permalink) Old 12-11-2019, 02:15 PM Thread Starter
I’m very new to this I haven’t really figured out how to do my signature yet but it’s a 05 Dodge Ram 3500 6speed Manual south bend dual disk 255/80/17 tires new long block injectors smarty s06 and edge cts2 with pyro for gauges Im looking to do some upgrades for fuel Economy this truck loves diesel and the truck cruises at around 9/10 psi of boost and I need to do some mods to get that down but I can’t go with to big of a turbo Bc I also haul hay a lot and I need it to spool so what are y’all thinking
post #6 of 25 (permalink) Old 12-11-2019, 02:36 PM
iTrader Score: 15 reviews
Iím very new to this I havenít really figured out how to do my signature yet
OP, Many of us here that are able to help with problems have NOT yet forfeit the use and utility of PUNCTUATION while communicating an idea or a question, or even an answer to a question.
Try it (i.e. using punctuation)... you just might like it.
And even if you don't like it, it will help us give you better answers!!!!
Just my .02
tryNto and trevdogg67 like this.
2005 SLT 4x4 QC LB G56, GDP horn, HDCAI, SBC ConOFE,
seafish is offline
post #7 of 25 (permalink) Old 12-11-2019, 02:43 PM
Getting good MPG and towing just don't go together. What's the current EGT that makes you concerned that you need a new turbo? How long does it stay at those temps? Where are you getting your reading from, before or after the turbo? There are plenty of other issues that it could be other than replacing with a different turbo.
What are you currently getting for mileage towing now? I would easily get in the single digits when hauling 15-20,000lbs, especially in the hills but when I was just cruising w/o trailer I could get 20mpg consistently(hand calculated) LOTS of variables with fuel mileage.
2017 GMC 2500 6.0
post #8 of 25 (permalink) Old 12-11-2019, 03:33 PM Thread Starter
My main concern is fuel mileage unloaded I’m getting 15 on the highway going 65 at 1950 rpms around 670 EGTs. my temps are okay I haft to stay in it very hard to get it past 1300. But wen I’m unloaded cruise set at 65 I’m around 9/10 psi of boost on flat ground I need help getting better mileage!!
post #9 of 25 (permalink) Old 12-11-2019, 03:39 PM
tryNto's Avatar
15 mpg is in the range of what to expect from most trucks here. Very few reach the 20 mpg most claim to get. Takes a lot of $$ and effort.
The way to Sig posting = click on USER CP at top of page > on the left of the page under Settings & Options > see Edit Signature > fill in info > save. there ya go
tryNto is offline
post #10 of 25 (permalink) Old 12-11-2019, 03:52 PM Thread Starter
See the truck got better before I put the bigger tires on it then it went down in town Iím getting like 13.5. It feels like somtnjng just dragging on it
post #11 of 25 (permalink) Old 12-11-2019, 03:52 PM
Signature will deff. help here.
Year, cab, duals or single rear wheel if 3500, modifications, tire size, lift, accessories, 2wd-4wd, and whatever else I forgot.
The mileage is going to depend on all of the factors above and then some.
Check out the Signature of my sold Cummins, it's a good start
2017 GMC 2500 6.0
post #12 of 25 (permalink) Old 12-11-2019, 04:15 PM Thread Starter
Okay I think I got my signature filled out!!!!
