idle adjustment - Dodge Cummins Diesel Forum
 3Likes
  • 1 Post By rghavana
  • 1 Post By tryNto
post #1 of 11 (permalink) Old 12-08-2019, 04:04 PM Thread Starter
idle adjustment
my early 04 used to idle at 800 rpm in gear and was smooth.now it idles at just over 700 and is rough.if i push gently on the pedal up to 800 i smooths rite out.can i just manually adjust the idle up or is a indication of another prob.
2004 CTD Qcab 2500
mulutchoker is offline
post #2 of 11 (permalink) Old 12-08-2019, 06:35 PM
rghavana's Avatar
ECM controls idle
Check for codes ?
tryNto likes this.
04 QCSB HO Automatic
rghavana is offline
post #3 of 11 (permalink) Old 12-08-2019, 06:41 PM
Mike @ Dude's Diesel Performance
TexNeck's Avatar
Have you changed fuel filter lately?
2013 Ram 2500
John 3:16 - Philippians 4:13
See what we are up to on:
FACEBOOK
INSTAGRAM
Or Email me at:
[email protected]
TexNeck is offline
post #4 of 11 (permalink) Old 12-08-2019, 10:32 PM
tryNto's Avatar
Could it be dirty injectors?
rghavana likes this.
'03 QCLB 2500 305/555 NV5600 w/ FastCoolers 3.73 4x4, Color match Lear Topper.
Smarty S-06 PoD, Edge CTS for Gauges, DPP Cool Tube w/ OEM AF Box, Baldwin PF7977, GDP MK-2 FF Kit, Pusher Intake Horn, Adj. Boost Elbow @ 30psi, OEM Fan Clutch Delete/Mod, Steering Box Brace, On-Board Air w/Horns
tryNto is offline
post #5 of 11 (permalink) Old 12-08-2019, 10:47 PM Thread Starter
new filters
2004 CTD Qcab 2500
post #6 of 11 (permalink) Old 12-08-2019, 10:49 PM Thread Starter
Originally Posted by rghavana View Post
ECM controls idle
Check for codes ?
will it automatically show a code if there is a prob?
2004 CTD Qcab 2500
post #7 of 11 (permalink) Old 12-09-2019, 01:51 AM
FCA is an electromechanical device. Service replacement item subject to wear, most wear occurs at where the motor runs at most of the time, IDLE. Wears out of spec.
More water, rust and dirt =s more wear.
steelhead1 is online now
post #8 of 11 (permalink) Old 12-09-2019, 07:12 AM Thread Starter
what is FCA and where is it located?
2004 CTD Qcab 2500
post #9 of 11 (permalink) Old 12-09-2019, 07:26 AM
rghavana's Avatar
Depends on what/where problem is, but have to start some where and no codes would also point to look at parts not monitored by ECM in fuel system. Ie most common like mentioned FCA ,injectors ,and fuel supply to CR.
tryNto likes this.
rghavana is offline
post #10 of 11 (permalink) Old 12-09-2019, 11:45 PM
fuel..... control..... actuator.....
located on the cp3......
smokestack69 is offline
post #11 of 11 (permalink) Old 12-10-2019, 12:18 AM
And no you can not just adjust the idle.
bigfish95971 is offline
