Stripped intake plenum bolt - Dodge Cummins Diesel Forum
 4Likes
post #1 of 14 (permalink) Old 12-08-2019, 01:35 PM Thread Starter
Kmehr's Avatar
I've managed to strip the rear passenger side bolt hole on my intake plenum, One of the four that holds the intake horn/grid heater down and it's causing a substantial boost leak. I'm not sure how to fix it. Previous owner put studs in and they have corroded enough that they won't move, except for this position, which I had to replace with a bolt a couple years ago. Basically the threads in the hole won't grab and they were probably already damaged when I Heman over tightened it, and now it's toast.
Are the threads in the actual head? the intake plenum itself? How do I fix this? Helicoil?
1984 Dodge CCSB P-pump NV4500- SOLD
2005 QCSB NV5600, SouthBend OKHD, CFM+, Jake brake, Thuren 3in, Vulcan w/ CAT UHE 416-1225, CTS2, HPTuners by Optimal Welding, BBI stage 1, II bag of parts
Kmehr is offline
post #2 of 14 (permalink) Old 12-08-2019, 02:02 PM Thread Starter
Kmehr's Avatar
Well I found the answer- the threads are in the head, and I did an awesome job of totally cracking the ear off. Sweet. Awesome.
Think the only fix option I have right now is getting a piece of long all thread, putting a bit on the bottom and top. F$&@ me.
Kmehr is offline
post #3 of 14 (permalink) Old 12-09-2019, 10:13 AM
TECH SPECIALIST
steve05ram360's Avatar
Why not replace the plenum cover?
one example of whats out there...
https://www.dieselpowerproducts.com/...e-cummins.aspx
AFE PG7 drop in filter, AFE Torque Tube, HTT 2.5 turbo, AFE e-mani, ATS Arc Flo, 50HP DDP , 428k, HPTuners, G56, 25.065 mpg, mpg threads ->https://www.cumminsforum.com/forum/3...l#post23312562
steve05ram360 is offline
post #4 of 14 (permalink) Old 12-09-2019, 11:33 AM Thread Starter
Kmehr's Avatar
I thought about that, but as I discovered the threaded holes are actually in the cylinder head, which I broke. The "stud" I made with a nut on the bottom is working pretty well. The boost leak from the gap in the intake elbow and grid heater is gone. I had a little bit of a leak coming up through the nut on the stud, but some blue locktite on those threads appears to have fixed that as well. My other studs have nylock nuts on them, but I couldn't find those for non-metric bolts at the hardware store yesterday. Word of caution- do NOT over tighten your intake bolts!
Kmehr is offline
post #5 of 14 (permalink) Old 12-09-2019, 11:47 AM
TECH SPECIALIST
Ah, got it, yeah that sucks.
It sounds like the stud method is holding, hopefully it lasts & no more issues with it.
post #6 of 14 (permalink) Old 12-09-2019, 11:51 AM Thread Starter
Kmehr's Avatar
Fingers crossed.
Kmehr is offline
post #7 of 14 (permalink) Old 12-09-2019, 04:14 PM
3 footin' through life
Broaner's Avatar
iTrader Score: 11 reviews
Had that happen to me. RTV'ed the piss out of it and held 50psi for about a year till I burnt up that engine and fixed it the right way.
Kmehr likes this.
'05.5 6.7 Shotpeened NV5600 - 12.6 @ 111.6 - 994 HP & 1630 lbs/ft
150%'s, LBZ/Arson pumps, MHP +1mm, ZZFab, Wagler Rods, 69/73/1.0 & s482
1350 Frontshaft, TruTrac, 315's, 64" T-Bars,TGC 1/2"+, Carli BJ's, '08.5
Street Triple, 103#/Extreme Pushrods, 625's Broaner Gets Hooked
Broaner is offline
post #8 of 14 (permalink) Old 12-09-2019, 04:33 PM
tryNto's Avatar
Hope it works a long time for you
rghavana and Kmehr like this.
'03 QCLB 2500 305/555 NV5600 w/ FastCoolers 3.73 4x4, Color match Lear Topper.
Smarty S-06 PoD, Edge CTS for Gauges, DPP Cool Tube w/ OEM AF Box, Baldwin PF7977, GDP MK-2 FF Kit, Pusher Intake Horn, Adj. Boost Elbow @ 30psi, OEM Fan Clutch Delete/Mod, Steering Box Brace, On-Board Air w/Horns
tryNto is offline
post #9 of 14 (permalink) Old 12-09-2019, 07:18 PM Thread Starter
Kmehr's Avatar
How would you even fix this short of milling the intake plenum off and getting an aftermarket one?
Kmehr is offline
post #10 of 14 (permalink) Old 12-10-2019, 12:00 PM
Broaner's Avatar
Correct. LOL
Kmehr likes this.
Broaner is offline
post #11 of 14 (permalink) Old 12-11-2019, 11:30 AM
Grogg's Avatar
that's the only way, I don't even think you could reasonably weld it back if you wanted to.
2006 RAM 3500 DRW 6 speed 4WD QCLB: unit bearing delete, metric delete, all tow no go.
1991 W350 SRW auto 4WD RCLB: Fleetjunk delete, Garmon trans, NASTRUCK
Just say no to metric Daimler-Fiat
Grogg is offline
post #12 of 14 (permalink) Old 12-11-2019, 11:59 AM Thread Starter
Kmehr's Avatar
Yeah i don't see a feasible way to weld it.
Kmehr is offline
