06 5.9L will not turn over/ No spark code - Dodge Cummins Diesel Forum
 3Likes
  • 1 Post By rghavana
  • 2 Post By cjtpilot
post #1 of 9 (permalink) Old 12-06-2019, 02:11 PM Thread Starter
cjtpilot's Avatar
So I am sure this is covered deep down in the depths of this forum but I am too lazy to search. lol
I replaced my starter about 1-2 months ago, today I went to start my truck and nothing, no clicking sound, just silence. I got a engine light and when I retrieved the code it said no spark. Anyway after a few more attempts the truck turns over and starts fine. Any suggestions on cause and possible no spark failure code?
Cjtpilot
2006 Ram 2500 Megacab 5.9L 4x4
cjtpilot is offline
post #2 of 9 (permalink) Old 12-06-2019, 02:52 PM
Babin Farms's Avatar
Start by changing the spark plugs & coils.
Being serious now, what code# you were coming up with? That would help out tremendously with helping diagnose your problem.
2017 GMC 2500 6.0
SOLD - 2008 3500SRWCCLB 4x4 6.7 Cummins, G56 w/South Bend DD
Riding the "Struggle Bus"
Babin Farms is offline
post #3 of 9 (permalink) Old 12-06-2019, 10:53 PM
gib megacab
smokestack69 is offline
post #4 of 9 (permalink) Old 12-07-2019, 06:24 AM Thread Starter
cjtpilot's Avatar
Yeah the no spark threw me a little, so I made sure to check the plug gaps and adjust the points. LOL
So of course after the issue at lunch yesterday, I have had no issue again YET. However one thing I paid attention too was which way i inserted the key(buttons on key towards me instead of away) could it be that simple? Has anybody come across where either the key and chip inside wear or the tumbler and will only work with the key inserted 1 way?
Cjtpilot
cjtpilot is offline
post #5 of 9 (permalink) Old 12-07-2019, 07:41 AM
rghavana's Avatar
Key position does not matter, ring style antenna in skim module reads key.
Sure starter is good seen some garbage reman starters sold at chain auto part stores.
If sure starter is good should load test batteries double check good wiring including grounds to starter .
Get proper scanner to read DC Controller Area Network (CAN) data bus system
Some trucks turning key on key off 3 times in 5 seconds show active codes.
tryNto likes this.
04 QCSB HO Automatic
rghavana is offline
The Following User Says Thank You to rghavana For This Useful Post:
cjtpilot (12-07-2019)
post #6 of 9 (permalink) Old 12-09-2019, 06:31 AM Thread Starter
cjtpilot's Avatar
Ok, checked all wire connections and are tight, went 2 days no problems. This morning of course in the pouring rain same problem.
So I eventually shook the gear selector while turning the key and it started up.
Cjtpilot
cjtpilot is offline
post #7 of 9 (permalink) Old 12-09-2019, 06:56 AM
sidewayzz69's Avatar
Are you seeing the square box around park. I had a similar issue. Was not getting square around park. Replaced range selector ( neutral safety switch) fixed mine.
sidewayzz69 is online now
post #8 of 9 (permalink) Old 12-09-2019, 09:23 AM Thread Starter
cjtpilot's Avatar
Yeah indication is good, it also would not crank when in neutral. I am thinking the Neutral Safety Switch at this point.
Cjtpilot
cjtpilot is offline
post #9 of 9 (permalink) Old 12-14-2019, 12:37 PM Thread Starter
cjtpilot's Avatar
UPDATE>>>>>>>>>>>> Replaced Neutral Safety Switch, noticed wires on connector started to pull out replaced connector as well. PROBLEM SOLVED
steve05ram360 and rghavana like this.
Cjtpilot
cjtpilot is offline
The Following 2 Users Say Thank You to cjtpilot For This Useful Post:
ssteve (12-14-2019), tryNto (12-14-2019)
