Reuse injection lines with rust - Page 2 - Dodge Cummins Diesel Forum
 15Likes
post #13 of 48 (permalink) Old 11-17-2019, 03:12 PM
Start using 0.5 oz of TC-W3 rated outboard lube per gal diesel. Walmart Supertech is the lowest cost and avail. everywhere. TC-W3 lube has extra additives to prevent water corrosion in fuel systems.
Also lubes and quiets down the injectors and CP3
ALL road diesel has en-trained water in it, even high volume stations. Comes from the pipeline system and bulk fuel storage tanks. Few stations bother with expensive centrifuge water removal filtration
rghavana likes this.
steelhead1 is offline
post #14 of 48 (permalink) Old 11-17-2019, 05:39 PM Thread Starter
Kmehr's Avatar
I use power service in every tank, have since I owned it.
The line between the cp3 and the fuel rail is the most rusty. Man this sucks. It was running really well before I took it apart. Guess it’s like blood pressure though, the silent killer. If anyone knows the CP3 to fuel rail line part number that’d be greatly appreciated. found it - 05086870AA
1984 Dodge CCSB P-pump NV4500- SOLD
2005 QCSB NV5600, SouthBend OKHD, CFM+, Jake brake, Thuren 3in, Vulcan w/ CAT UHE 416-1225, CTS2, HPTuners by Optimal Welding, BBI stage 1, II bag of parts
Kmehr is offline
post #15 of 48 (permalink) Old 11-17-2019, 06:24 PM
jesus
don't buy from Mopar, way marked up overpriced
Go to Genos Garage.
they carry real Cummins/Bosch parts or check your local truck parts counter Cummins shop.
PS D Kleen does NOT prevent nor stop rust
post #16 of 48 (permalink) Old 11-17-2019, 08:24 PM Thread Starter
Kmehr's Avatar
Everything so far has come from Diesel Power Products. Mostly because I find their website the easiest to use and prices good. Hopefully they send me a nice coupon cause I've spent a stupid amount there this week...
Having a hard time finding that feed line anywhere online that I trust...05086870AA
Kmehr is offline
post #17 of 48 (permalink) Old 11-17-2019, 10:17 PM Thread Starter
Kmehr's Avatar
3957079 is an alternate part number that many vendors have in stock.
Kmehr is offline
post #18 of 48 (permalink) Old 11-18-2019, 09:20 PM Thread Starter
Kmehr's Avatar
Everything should be here tomorrow except the #6 injector line. Apparently thatís on national back order. This is my daily, so thatís awesome.
@steve05ram360 here is the before ATF soak:
And here is the after:
Kmehr is offline
The Following 2 Users Say Thank You to Kmehr For This Useful Post:
GRUNT 11B (11-18-2019), steve05ram360 (11-18-2019)
post #19 of 48 (permalink) Old 11-18-2019, 09:31 PM
GRUNT 11B's Avatar
Im kinda surprised the ATF removed the rust like that.
06 QCLB 4X4 G56, SOUTHBEND DD, FASS 150, ARP STUDS, 50HP INJECTORS, EFI, HE351 S475 COMPOUNDS, FLUIDAMPR, HAMILTON PUSHRODS & 103# SPRINGS, 624 HP 1090 TQ 01 QCLB 4X4 AUTO, WHEELS, TIRES, STEERING WHEEL, CUMMINS, BUMPERS, FUEL TANK, SEATS, ETC.
GRUNT 11B is offline
post #20 of 48 (permalink) Old 11-18-2019, 10:22 PM Thread Starter
Kmehr's Avatar
Me too. And honestly it wipes off pretty easy on the other ones. Just not sure how to clean the inside of the tube out. OR if putting it in ATF will just knock things loose to blast my injectors.
Not sure what to do about the #6 line. Looks like tis not even made anymore.
Kmehr is offline
post #21 of 48 (permalink) Old 11-18-2019, 10:27 PM
GRUNT 11B's Avatar
That's the hard part, not being able to see inside the injector lines. You don't know what's left in them that could potentially get into your squirters.
post #22 of 48 (permalink) Old 11-18-2019, 11:59 PM
TECH SPECIALIST
steve05ram360's Avatar
I would think if the full blast of atf did that, the smaller amount in the fuel would have a negligent impact, there is just not enough of it to do anything, but maybe it might prevent it? My truck has approx 100k now using the ATF/2SO mix. First set lasted to approx 160~165k miles, 2nd set about the same. First set lived its life on the MMO/PSD mix, 2nd set 130~140k on it, then went to the ATF/2SO mix. It sucks not knowing how long injectors will last with the mix being used, but I will find out first hand.... in 50~60k.
Two things to remind people about, I run a fuel cooler year round after the OEM filter and before the 2 micron filter, and my truck rarely sees 20k psi of pressure.
Kmehr, thanks again for doing the experiment...
AFE PG7 drop in filter, AFE Torque Tube, HTT 2.5 turbo, AFE e-mani, ATS Arc Flo, 50HP DDP , 427k, HPTuners, G56, 25.065 mpg, mpg threads ->https://www.cumminsforum.com/forum/3...l#post23312562
steve05ram360 is offline
post #23 of 48 (permalink) Old 11-19-2019, 12:06 AM Thread Starter
Kmehr's Avatar
Happy to do experiments. Now if anyone has a spare #6 injector line laying around....
Kmehr is offline
post #24 of 48 (permalink) Old 11-19-2019, 12:34 AM Thread Starter
Kmehr's Avatar
If I canít find this injector line ASAP, Iím thinking about putting an old injector and tune back in #6 for the time being. I have a line on some shops to call. But itís also my daily so I canít be without it much longer.
Kmehr is offline
