P1222 trouble code help - Page 2 - Dodge Cummins Diesel Forum
post #13 of 25 (permalink) Old 11-16-2019, 11:37 PM
Pull an oil sample after work, cooled off crankcase or burned arm. Wipe off drain plug area, spray clean with brake cleaner, wipe off again. 3>4 ounces in a sample bottle and ship off to Blackstone for diesel contamination in oil test. You can't tell 5 or even 10% fuel dilution in oil but their lab test equipment can.
May save you a titttes up motor
steelhead1 is offline
post #14 of 25 (permalink) Old 11-16-2019, 11:42 PM Thread Starter
How much does such a test cost? And what's the turnaround time?
BlazeKeeper is offline
post #15 of 25 (permalink) Old 11-16-2019, 11:48 PM
GRUNT 11B's Avatar
$25 is what it cost me, but i think it went up to $28. I don't remember how long it took to get the results, but i don't think it was over a week.
06 QCLB 4X4 G56, SOUTHBEND DD, FASS 150, ARP STUDS, 50HP INJECTORS, EFI, HE351 S475 COMPOUNDS, FLUIDAMPR, HAMILTON PUSHRODS & 103# SPRINGS, 624 HP 1090 TQ 01 QCLB 4X4 AUTO, WHEELS, TIRES, STEERING WHEEL, CUMMINS, BUMPERS, FUEL TANK, SEATS, ETC.
GRUNT 11B is online now
post #16 of 25 (permalink) Old 11-16-2019, 11:53 PM Thread Starter
Oh, that's not bad at all. I'll definitely look at grabbing a sample this week and having it tested.
I'll be adding the PSD Diesel Kleen to a full tank tomorrow as I'm heading home (which will be about a 260 mile drive) so we'll see what happens. I'm still hoping this is just a clogged injector and a heavy dose of cleaner will fix my problem.
post #17 of 25 (permalink) Old 11-17-2019, 04:23 AM
GRUNT 11B's Avatar
If you contact Blackstone they will send you a container for your oil sample.
post #18 of 25 (permalink) Old 11-17-2019, 11:48 PM Thread Starter
Alright, finally made it home.
Dumped a bottle of Diesel Kleen in the tank and filled up. 149 miles later I stopped and filled up again to calculate mileage. 149 miles, 14 gallons = 10.64mpg. I'm no engineer, but I feel like that number should be higher.
Also, when the truck is idling (and at very small amount of throttle) I hear a faint tick/knock from under the hood, but at higher RPMs and at highway speed I don't hear anything. This is my first diesel, so I've never experienced it, but I've heard of something called injector knock. Could the noise I'm hearing be that?
post #19 of 25 (permalink) Old 11-19-2019, 01:48 AM Thread Starter
Well, I took an oil sample and sent it off for testing. They'll do everything from checking for diesel in the oil, detergents, additives, wear metal, the works. It's a company I use often for work, so I trust their work. Should have results back by the end of the week. I assume that ANY diesel in the oil would indicate an injector problem, and thus resulting in the replacement of them?
post #20 of 25 (permalink) Old 11-19-2019, 12:14 PM
GRUNT 11B's Avatar
Diesel can also get into the oil through a leaky seal in the CP3. That is not as common though.
post #21 of 25 (permalink) Old 11-22-2019, 12:49 AM Thread Starter
Little update:
Oil sample came back perfect. No fuel, no excessive wear metal, the lab said it was great. Changed the FCA (to the person that severely stripped out the bolt that's incredibly hard to get to, I hope you're sorry for what you put me through) and the rail PRV. I seem to recall reading somewhere that the PRV being full of diesel was a sign that it's bad. Is that correct? Regardless, mine was full to the brim. Took it for a small test drive, and no light so far. Not sure it would come on after only 25 miles of driving anyway, but so far so good. Still mentally (and financially) preparing for injectors, but if I can wait a while on that it'd be nice.
post #22 of 25 (permalink) Old 11-22-2019, 03:44 AM
GRUNT 11B's Avatar
Did you ever put the new PRV in?
It's a good idea to always be ready or saving to buy an expensive part like injectors.
post #23 of 25 (permalink) Old 11-22-2019, 11:25 AM Thread Starter
I put it in yesterday along with a new Bosch FCA.
post #24 of 25 (permalink) Old 11-22-2019, 11:31 AM
cerberusiam's Avatar
Rail PRV should have diesel in it, its job is to release excess pressure in the system. The problems start when the wear on the seat etches it and it won't seal, diesel being released at +24k psi will eventually etch the metal parts.
cerberusiam is offline
