Noise After New 5.9 Install - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 10-22-2019, 09:27 AM Thread Starter
Hi all,
I did spend a lot of time reading posts trying to locate the answer before making a post, so I apologize if this is a repeat. I just recently had a Jasper 5.9 engine put into my 07 3500 and I have this very annoying noise that only happens (that I can hear) when accelerating at a normal pace. The noise will not happen when the engine is in park or neutral. I've narrowed it down to the injector pump and it sounds like a bag of marbles rattling around when there is a load on the the engine, accelerating, pulling my trailer, pressing the break while in drive and accelerating. From what I read the CP3 pump in a common rail and doesn't need to be timed, so I'm not sure. I've only put about 3k miles on the engine so far and wanted to make sure it's ok to keep driving. The mechanic pretty much gave up on trying to locate the source of the noise and said "its a Diesel, they make noise", but this is NOT a normal noise. Any help would be much appreciated, this noise is driving me insane!
Also, new injectors were also put in at the time of the engine install.
jljosey95 is offline
post #2 of 10 (permalink) Old 10-22-2019, 09:38 AM
b.lee's Avatar
Sounds like injector rattle?
Does the truck have a programmer or tune on it?
2012 2500 Cummins 4x4 - Mega
Laramie, Auto, EFI Live
b.lee is offline
post #3 of 10 (permalink) Old 10-22-2019, 09:45 AM Thread Starter
I'm not sure what injector rattle sounds like, but I guess it could be coming from the injectors. Sounds like it's coming from the pump to me though. No, there is no programmer or tuner, everything stock.
post #4 of 10 (permalink) Old 10-22-2019, 09:55 AM
TECH SPECIALIST
steve05ram360's Avatar
Welcome to Cumminsforum!
While the CP3 does not need to be timed, it can be adjusted so it is quieter... have a look at this...
https://www.cumminsforum.com/forum/3...g-results.html
I've never had to do it so no personal experience but there are several threads here discussing it.
AFE PG7 drop in filter, AFE Torque Tube, HTT 2.5 turbo, AFE e-mani, ATS Arc Flo, 50HP DDP , 424k, HPTuners, G56, 25.065 mpg, mpg threads ->https://www.cumminsforum.com/forum/3...l#post23312562
steve05ram360 is offline
post #5 of 10 (permalink) Old 10-22-2019, 09:55 AM
TECH SPECIALIST
Also... if your new to the truck, this might be of use...
https://www.cumminsforum.com/forum/3...you-truck.html
post #6 of 10 (permalink) Old 10-22-2019, 10:39 AM Thread Starter
Thank you very much. I'll have to give this a try.
post #7 of 10 (permalink) Old 10-22-2019, 10:31 PM
I know what you are talking about, I had the same issue replaced the fuel pressure sensor and the rail pressure relief valve and it solved the pre ignition sound.
2006 Crew cab Laramie, Rancho 9k's, leveled, Nitto ridge grapplers 35x12.50x17, Mishimoto trans cooler, Carli end links, Thuren trackbar, 09 steering upgrade, built trans, Iron cross bumpers front & rear, Warn 12k winch, Bully dog tuner, KC flex 20 light bar.
eklarsen is offline
post #8 of 10 (permalink) Old 10-23-2019, 03:29 PM Thread Starter
I'll have to look into this thank you.
post #9 of 10 (permalink) Old 10-23-2019, 03:47 PM
rghavana's Avatar
Any codes ??
Good lift pump fuel supply??
04 QCSB HO Automatic
rghavana is offline
post #10 of 10 (permalink) Old 10-23-2019, 04:23 PM Thread Starter
No codes and according to the mechanics good fuel supply. The truck runs fine, it's just this annoying unusual noise that is driving me nuts. I'm taking to a different place to get another opinion.
