12 valve swap in progress - Dodge Cummins Diesel Forum
 3Likes
post #1 of 25 (permalink) Old 10-07-2019, 11:27 PM Thread Starter
05quad4x4's Avatar
So really just making this post to document my progress and to hopefully help others as I finish this up. Couple months ago while taking a road trip my common rail started shaking as I pulled into a little town in the middle of no where. Whole underside and sides of the truck were covered in oil and the oil cap hit the hood when I took it off. I didn't have a hole in the block and the oil(diesel) level was over the full line. So once I trailered her home I started buying parts for a swap.
2004.5 quad 4x4 6 speed
2" springs w/ 35s
05quad4x4 is offline
post #2 of 25 (permalink) Old 10-07-2019, 11:34 PM Thread Starter
05quad4x4's Avatar
The new to me 93 twelve valve. Since she was out I did the dowel pin fix and tightened all the case bolts with loctite. These were all hand tight and probably would've wrecked this motor before the dowel pin. I also changed the oil pan gasket and front/rear main seals, ve pump seal and put a billet tappet cover on since they were all leaking a bit of oil. I also did a fuel pin kit and 3200 governor spring too.
2" springs w/ 35s
post #3 of 25 (permalink) Old 10-07-2019, 11:40 PM Thread Starter
05quad4x4's Avatar
So on to parts you'll need to pull this off. Transmission adapter. The first gen is tiny. I'm going on to a nv5600 so I had to source a second gen adapter plate and starter spacer. The third gen starter will bolt up fine to this and it's less electronics to replace. The third gen plate has different bolt pattern and will not work. This was my method of changing the rear main, worked like a champ with a screw and hammer.
2" springs w/ 35s
post #4 of 25 (permalink) Old 10-07-2019, 11:51 PM Thread Starter
05quad4x4's Avatar
I'm using my he351 from the common rail with a third gen manifold. You don't need to port anything. The circle holes cover the square 12 valve holes completely. I did this so I wouldn't have to modify my exhaust, air box or after cooler. To pull this off you need the oil adapter from the old turbo to screw onto the he. The first gen supply line can be flipped and used and will barely clear the manifold. Use the flex oil drain from the common rail or better yet if you pull the pan, put on an after market drain so it's a vertical drop. You can spin the drain on the twelve valve to make a sloped run with a small pipe wrench and use the stock adapter.12 valve swap in progress-1002191216_hdr_1570506462463.jpg
98whitelightnin likes this.
2" springs w/ 35s
post #5 of 25 (permalink) Old 10-08-2019, 12:06 AM Thread Starter
05quad4x4's Avatar
Next up would be motor mounts. The common rail has multiple mounts like a storm block supposedly does. The twelve valve mounts are forward and you need to move one space back so you need adapter plates and to notch your frame mounts to account for the space with the plates. I used a YouTube series where the guy covers most of the swap. Essentially you need a 1/4x4x12 piece of plate steel. The plate needs six holes, the front two are bolted into the block, the middle set is the mount and the rear you have to insert nuts into the plate and weld them in then grind them fairly flush and use short bolts. If you have a belt sander and a drill, you can run a bolt into the drill with the nuts on it, spin the drill while the sander is running and make perfect circles. I then made some flat spots so I could get my weld down into the meat of the plate.
ID:	857953   Click image for larger version
ID:	857955   Click image for larger version
2" springs w/ 35s
post #6 of 25 (permalink) Old 10-08-2019, 12:18 AM Thread Starter
05quad4x4's Avatar
The a.c. compressor will bolt up from the common rail onto the twelve valve so the stock lines will work. You'll need a late 24 valve alternator, the plugs match the common rail connectors and it'll mount to the first gen. To make the computer, a.c. tach and alternator work, you'll need a 60 minus two tone ring and the common rail crank sensor. I tried to get one from destroked but they would never call me back about getting just the plate but I found the common rail tone ring will bolt to the front of the twelve valve dampner it you use longer bolts and spacers. You'll also need to fab a bracket for the crank sensor. I'll have to add a picture off that later. Finding higher grade longer bolts is a challenge locally, you'll need m12x1.25x50 mm bolts and 16mm worth of spacers or washers.
* added a picture off the crank bracket. I tried to mount out higher originally but the fan contacted it. I drive through some deep snow drifts so I didn't want to mount it on the under side
ID:	857959   Click image for larger version
ID:	857961   Click image for larger version
2" springs w/ 35s
post #7 of 25 (permalink) Old 10-08-2019, 12:39 AM Thread Starter
05quad4x4's Avatar
Adapting the water sensor. The engine my truck came out of was an auto and they have a sensor for the transmission overdrive. This is the same plug as the common rail, only bad side is its on the wrong side of the block as the harness you'll be re using. If you want to use the common rail sensor, you need a 1/2 npt to m14x1.5 adapter and there's a few places to put it in. Adapting the oil pressure you'll be going from an 1/8 npt to m14x1.5mm and you have to use the common rail sensor here. I used an o ring to keep this leak free and to mount tighter to the block. When you delete the auto cooler, you'll need a plug or you can mount the water temp sensor in this spot.
ID:	857969   Click image for larger version
2" springs w/ 35s
post #8 of 25 (permalink) Old 10-08-2019, 12:47 AM Thread Starter
05quad4x4's Avatar
I just got the engine stabbed tonight so I'll get to figure a few things out tomorrow. The common rail uses drive by wire but it uses a cable to a box under the battery. It looks like this will hook into the ve perfectly but I'll find out tomorrow. The common rail power steering line will bolt to the twelve valve steering pump and looks like it'll be the right bend to work. You'll need to go from 5/8 to 1/2 on the drain side, ace hardware fittings work great for that. *update the stock cable does hook into the ve pump. Got to mess with a better mounting solution though. The stock power steering supply line hooks perfectly into the brake booster *
ID:	857973   Click image for larger version
2" springs w/ 35s
post #9 of 25 (permalink) Old 10-08-2019, 01:07 AM Thread Starter
05quad4x4's Avatar
Fuel system notes. I had a walbro system and 1/2" lines on my truck. Good thing, the fittings are the same size for the different years and I'm pretty sure the return line will hook up and the wif sensor as well. Bad side, the walbro puts out way too much pressure unless you regulate it below 15psi. I could never keep mine from spiking up pretty high so I'm deleting it and running a hvlp mechanical pump. I have it plumbed so I can still use the stock pump by putting the relay in if I need to use it and closing some valves. The ve uses a seal that will blow and flood the motor with diesel above 20 ish psi. I did the loctite mod when I changed the seal for some peace of mind. *update, the stock return line is the same connector size!*
2" springs w/ 35s
post #10 of 25 (permalink) Old 10-08-2019, 08:26 PM
Love your build BUT using the crappy 3rd gen exh manifold , your 12valve exh note won't sound like a 12 valve .
SOLD My 2001 and 2005 .
SOLD 2004.5 Sons mod truck
24hrsparkey is offline
post #11 of 25 (permalink) Old 10-09-2019, 12:57 AM Thread Starter
05quad4x4's Avatar
I was a little concerned on how it would sound. Instead of using my old stock manifold, I'm using an after market that actually divides the cylinders equally like the first gen kinda. Reading reviews and watching YouTube videos, it's deeper sounding than the stock piece. But really I'm using it so I don't have to modify my new exhaust and so I can keep the factory intake.
24hrsparkey likes this.
2" springs w/ 35s
The Following User Says Thank You to 05quad4x4 For This Useful Post:
24hrsparkey (10-09-2019)
post #12 of 25 (permalink) Old 10-09-2019, 01:32 AM Thread Starter
05quad4x4's Avatar
Got a lot done today. Found out a second gen intake horn will only fit with some grinding but I need to find a better solution. I might try my third gen horn but I would rather not. Torqued the motor mounts down. Mounted the starter. Mounted the turbo. Installed new 5x14 vco injectors from hungry diesel. Installed power steering. Hooked up the fuel lines. Hooked up the throttle cable. I just have to mount the computer and hook into the sensors now and put the front end back together. I work the next 14 days unless we get blown out from the blizzard coming through so updates might be thin.
Does anyone know of an after market intake with a better bend for clearance? I might have to weld up my own, I think I'm going to have to mod the intercooler piping to fit the different location possibly. It's easier to order stuff now instead of finding out later on my days off. I travel for work and the truck is an hour away at my friends place.
ID:	858089   Click image for larger version
2" springs w/ 35s
