Can a bad valve cover gasket injectors wire harness cause white smoke during start up - Dodge Cummins Diesel Forum
post #1 of 31 (permalink) Old 09-17-2019, 07:45 PM Thread Starter
I’m having white smoke puff (A lot)in the morning on my truck after I changed all six injectors still.. a lot of people are telling me it could my my wire harness to my fuel injectors? I never replace the wire harness btw I used the same one
2006 Dodge Ram 2500 5.9
5.9lorenzo is offline
post #2 of 31 (permalink) Old 09-17-2019, 08:11 PM
No . That would give you a rough running condition .
What injectors did you install , and were the feed tubes new ?
SOLD My 2001 and 2005 .
SOLD 2004.5 Sons mod truck
24hrsparkey is offline
post #3 of 31 (permalink) Old 09-17-2019, 08:31 PM
GRUNT 11B's Avatar
Was it doing this before you swapped injectors?
06 QCLB 4X4 G56, SOUTHBEND DD, FASS 150, ARP STUDS, 50HP INJECTORS, EFI, HE351 S475 COMPOUNDS, FLUIDAMPR, HAMILTON PUSHRODS & 103# SPRINGS, 624 HP 1090 TQ 01 QCLB 4X4 AUTO, WHEELS, TIRES, STEERING WHEEL, CUMMINS, BUMPERS, FUEL TANK, SEATS, ETC.
GRUNT 11B is online now
post #4 of 31 (permalink) Old 09-17-2019, 09:34 PM Thread Starter
Yes it was smoking slightly before I installed the new injectors but now it’s puffing white smoke like crazy only when the engine is cold but it’ll be running good when it’s in running temps.. I keep getting told it’s my wire harness.. and yes it has new feed tubes
post #5 of 31 (permalink) Old 09-17-2019, 09:39 PM
Compression....... is it a raw fuel smell from exhaust?
Aburdett is online now
post #6 of 31 (permalink) Old 09-17-2019, 09:43 PM Thread Starter
Yes smell like fuel
post #7 of 31 (permalink) Old 09-18-2019, 07:15 AM
Could be wires. Pull the injector wire plugs at the valve cover and measure the resistance to the injectors there. If the wires are good, they should all match abd be less than 1 ohm. Found this on mine, the crimped end that connected to the injector was not tight and caused a wondering reading. Redid all the terminals and now all the injectors read the same whether I am at the injector or at the plug.
Sent from my Nokia 7.1 using Tapatalk
2013 RAM 2500 diesel 6.7 Bighorn Crew Shortbed 4x4 in white. As of 7/21/16 16,100 miles.
cwendel is offline
post #8 of 31 (permalink) Old 09-18-2019, 07:20 AM
I would think a bad injector wire would cause a shudder or something like the power was being turned off and on. Not a haze dependant on temperature.
post #9 of 31 (permalink) Old 09-18-2019, 07:30 AM
Not sure. The system on these trucks is really primative compared to new gas vehicles. Kinda like being in the early 80's. The system does not seem to have hard set values and works even out of range so it could be adjusting for an injector solenoid that changes with temp. Easy way is measure the injector solenoid resistance through the harness connection. If it is less than 1 ohm and more than 0.1 ohm then that is not the problem. Just another box to check off, especially since these rams are so sensitive to electrical conditions.
cwendel is offline
post #10 of 31 (permalink) Old 09-18-2019, 08:14 AM
Exactly .
Again , What injectors were used and if new feed tubes and O rings
post #11 of 31 (permalink) Old 09-18-2019, 11:16 AM
Not if the wire is not cut through. A broken wire can still make contact 90% of the time if it broke inside the insulation.
cwendel is offline
post #12 of 31 (permalink) Old 09-18-2019, 11:19 AM
Ya but would that cause white smoke? Id disagree. Seen half broke and broken injector wires on class8 trucks. All only caused on/off power. Or a miss. No white smoke or haze that went away.
