NV5600 lube alteration - Dodge Cummins Diesel Forum
 3Likes
  • 1 Post By BFD
  • 1 Post By Squeaksleaks
  • 1 Post By tryNto
post #1 of 7 (permalink) Old 08-18-2019, 05:43 PM Thread Starter
Can anyone tell me what a lube alteration is on an NV5600? I'd heard of a customization you can do where oil is pumped in to the top of the gear box, thereby making shifting easier and cooling better. Is that it?
custom03 is offline
post #2 of 7 (permalink) Old 08-19-2019, 07:10 PM
tryNto's Avatar
Sorry, no idea on this subject.
'03 QCLB 2500 305/555 NV5600 w/ FastCoolers 3.73 4x4, Color match Lear Topper.
Smarty S-06 PoD, Edge CTS for Gauges, DPP Cool Tube w/ OEM AF Box, Baldwin PF7977, GDP MK-2 FF Kit, Pusher Intake Horn, Adj. Boost Elbow @ 30psi, OEM Fan Clutch Delete/Mod, Steering Box Brace, On-Board Air w/Horns
tryNto is offline
post #3 of 7 (permalink) Old 08-19-2019, 11:49 PM
BFD
BFD's Avatar
I ran 6 qts of RP synchro max in mine with awesome results. Some guys use 7'qts. Some guys take the shifter out to get the extra juice in. I always took the left pto plate off to check the magnet so I put another fill hole in the plate while I,had it off the first time. Craig
custom03 likes this.
2012 CCLB 4wd dually, 3.73, 68rfe, Fass, BD IH and E-brake kits. DD and towing machine.
Olde too soon... Schmart too late!
BFD is offline
post #4 of 7 (permalink) Old 08-20-2019, 05:43 PM
I think you are referring to the "power lube" mod.
""Powerlube Mod" Passageways for lube are enlarged. I will try to get more info on what specifically is modified. This requires a full teardown. Any time you are going through the effort of fully rebuilding you should do this. At ~$275 its money well spent. The shifting is a lot faster and smoother with this mod performed and it really helps 6th live longer by keeping the smaller gear cool. I have driven non powerlubed trans and powerlubed trans within hrs of each other. The difference is very tangible at all RPM's. This gets even more pronounced at 3,000+. The non treated trans I had would NEVER shift above 3500 rpm's. Even above 3,000 it would really take some muscling. Modded, its no problem ripping a gear at 4,000 rpm with normal'ish effort."
-Broaner
That quote was taken right off of Broaners thread https://www.cumminsforum.com/forum/3...-upgrades.html
It has alot of good information regarding his trails and tribulations getting a NV5600 to handle his power output.
2008 2500 6.7 4x4 68RFE Stock
2003 2500 5.9 4x4 NV5600 bbi stage one injectors
Squeaksleaks is offline
The Following 2 Users Say Thank You to Squeaksleaks For This Useful Post:
custom03 (11-05-2019), tryNto (08-20-2019)
post #5 of 7 (permalink) Old 08-24-2019, 02:58 AM Thread Starter
I'm about to pull my trans and xfer case to do a clutch replacement. Can't find a drain plug. Do I pull the pto plate? And when I put it back do I need to get a special gasket or will gasket goop work?
custom03 is offline
post #6 of 7 (permalink) Old 08-24-2019, 03:28 AM Thread Starter
-Broaner
Many thanks on Broaner's thread. Lots of info there.
custom03 is offline
post #7 of 7 (permalink) Old 08-24-2019, 12:55 PM
tryNto's Avatar
Pulling a bottom bolt on the PTO cover will get it to drain. I would pull the PTO cover to check for wear indications and clean the magnet. Black RTV is what I use to reseal.
Be sure to add 1 extra Qt of gear oil.
tryNto is offline
The Following User Says Thank You to tryNto For This Useful Post:
custom03 (08-24-2019)
