Lightweight Pulleys - Page 10 - Dodge Cummins Diesel Forum
 34Likes
post #109 of 121 (permalink) Old 11-27-2019, 02:56 PM
Gator1's Avatar
Originally Posted by spooled05 View Post
You have to start out with it filled to a certain spot in the filler neck , than fill to the same spot every time to get repeated results , as you already found out how much it can vary from different fill rates .
Ha, that was my attempt at humor...I did fill it up to the inside of the neck, it's longer than I thought, so it was safe to do. But, I need to try it again on flat ground, when the wind isn't gusting to 100 mph.
03 QCLB- 19 to 25 mpg with electric parts, and engine mods....
Gator1 is offline
post #110 of 121 (permalink) Old 11-27-2019, 08:06 PM Thread Starter
TECH SPECIALIST
steve05ram360's Avatar
Originally Posted by Gator1 View Post
That filler neck method is bad, I got 13 mpg today100 mile trip running in some hills and VERY windy conditions. I will try the filler neck method again on a flat road where I got 33.
Its the only way to do it without having a 5 gallon container (or some known quantity) and running it dry.
AFE PG7 drop in filter, AFE Torque Tube, HTT 2.5 turbo, AFE e-mani, ATS Arc Flo, 50HP DDP , 428k, HPTuners, G56, 25.065 mpg, mpg threads ->https://www.cumminsforum.com/forum/3...l#post23312562
steve05ram360 is offline
post #111 of 121 (permalink) Old 11-28-2019, 09:41 AM
Gator1's Avatar
True, that's the way I will do it next time I do a strictly mpg run.
Gator1 is offline
post #112 of 121 (permalink) Old 11-28-2019, 10:13 AM Thread Starter
TECH SPECIALIST
i have a vent kit on my tank so every fillup is up to the neck. after the first auto shutoff, i hit the pump again until the next one then done. i always can see the fuel in the neck...
200 mile run this morning on that same route that gave the 25, ambient temps are 28-35* should be interesting. i would expect low 20's pre-pulley & EWP...
will fill up afterwards, noonish...
post #113 of 121 (permalink) Old 11-28-2019, 10:23 AM
Gator1's Avatar
Ya, I can do that, I have a 50 gal tank in the bed with a vent and roll over valve on a riser so it's always above fuel level, and the neck is 3-4 inches above level also. So as long as I get fuel into the neck it would be really accurate.
Good luck on your run today.
Gator1 is offline
post #114 of 121 (permalink) Old 11-30-2019, 02:07 PM Thread Starter
TECH SPECIALIST
what did your do over mpg run give?
post #115 of 121 (permalink) Old 12-02-2019, 10:58 PM
Gator1's Avatar
Didn't do it yet.
Gator1 is offline
post #116 of 121 (permalink) Old 01-08-2020, 03:38 PM
Gator1's Avatar
Update on pulley selection, first off, the truck has not moved since last post, so no new mpg #'s. Since I'm only running a 6 rib belt I decided to do some more experimenting and found a smaller 5 1/4" in overdrive pulley VS. 6 1/4" dia 6 rib pulley, and it only weighs 8 oz, Ssshhhzzzaaaaaam! Also, there is no worry at all about slipping since the HellCat uses a 6 rib I don't think spending most of the time below 2000 rpms with no fan clutch, or water pump is going to tax the belt and cause it to slip.
24hrsparkey likes this.
Gator1 is offline
post #117 of 121 (permalink) Old 01-15-2020, 02:55 PM
Gator1's Avatar
Update, the new lightweight pulley champ is...OEM pulley 1lb 13oz new composite overdrive pulley 8.4oz.
ID:	865249   Click image for larger version
Gator1 is offline
post #118 of 121 (permalink) Old 01-15-2020, 03:48 PM Thread Starter
TECH SPECIALIST
Wow thats getting light... but thats a 6 groove pulley right?
post #119 of 121 (permalink) Old 01-15-2020, 04:45 PM
If the 6.25 pulley was spinning 2000rpm, the 5.25 is going 2381. I would wager the weight loss will go unnoticed from the extra work being done. But if you need the speed it's a win win.
56Cummins is offline
post #120 of 121 (permalink) Old 01-16-2020, 06:34 PM
Gator1's Avatar
Yes, 6 rib. So far I haven't found an 8 rib 5in pulley.
Gator1 is offline
