Rear brake rotors - Dodge Cummins Diesel Forum
 10Likes
post #1 of 26 (permalink) Old 08-13-2019, 03:40 PM Thread Starter
Rear brake rotors
I've got a 2005 2500 and when I rebuilt the a caliper I noticed noticed the inside pad was almost gone. I've done front brakes on several vehicles, but this is the first time I've done the rear. My truck has rotors that are finned on the backside - not ventilated, but the inside brake pad contacts the fins. In looking for replacement rotors the dealer couldn't tell me if the replacements are finned or not (he didn't have any in stock and the pic didn't show fins). A couple questions: Can I replace these with conventional rotors with no issues? Why would you want these "fins" as they have much less braking area? When setting the emergency brake does it just actuate the inner pads?
Thanks, I appreciate the input.
jogn2 is offline
post #2 of 26 (permalink) Old 08-13-2019, 03:50 PM
cerberusiam's Avatar
You mean they are slotted rotors? Finned is entirely different.
You want the slotted rotors, helps keep the brake dust cleaned out an water routed off the surface. They even make drilled and slotted rotors for perforamnce but for the most part the slotted s work the best.
E brake just sets the shoe son the inside of the hub. You don't have to even pull the hub to change the rotors.
cerberusiam is offline
post #3 of 26 (permalink) Old 08-13-2019, 04:01 PM Thread Starter
No, on the back side of the rotor in lieu of a flat braking surface there are a bunch of "raised" fins that the pad contacts. I'm not the original owner so not sure these are the original ones.
jogn2 is offline
post #4 of 26 (permalink) Old 08-13-2019, 04:08 PM
Its a "hat " style rear rotor . very easy to replace assuming the inside emerg brake shoes have not formed a large rust ring . that makes it tuff.
Just go standard high quality rotor .
VERY important at that time to check the caliper slider pins , free them up and add special grease if ness. This will even up the pad wear / or help a great deal.
SOLD My 2001 and 2005 .
SOLD 2004.5 Sons mod truck
24hrsparkey is offline
post #5 of 26 (permalink) Old 08-13-2019, 04:28 PM Thread Starter
Sparky, thanks for the info - yes I will check the slider pins. Just curious what is the purpose/advantage of the "hat" design? I'll just go with a good, quality standard design.
jogn2 is offline
post #6 of 26 (permalink) Old 08-13-2019, 05:25 PM
Sounds like you wore through the rotor and all thatís left are the fins that used to join the two rotor faces. Thatís why the inner pad is worn out.
Jhenderson is offline
The Following User Says Thank You to Jhenderson For This Useful Post:
vreihen (08-13-2019)
post #7 of 26 (permalink) Old 08-13-2019, 05:39 PM
utahtrapper's Avatar
Pics would be Great to see what we are talking about here?
Mr Jhenderson is very likely correct.
2006 Blue Laramie DRW. 3500 5.9 G56 Mobil Delvac 50, Tans Cool PTO Covers, GDP Fuel Boss, GDP Double-X Ladder Bars, GPD big line kit, GDP MK-2 Fuel filter kit with CAT UHE 416 1225, GDP Power-Flo Intake Manifold, Throttle Up Industries Dual Fuel Filters, Dieselsite Coolant Filter, Cool Hose, Timbrens, 26k with Horses in Trailer, ................... BBi's .5 Towing Injectors WOW!
Carli Ball Joints
utahtrapper is offline
post #8 of 26 (permalink) Old 08-13-2019, 05:59 PM
PWong's Avatar
Originally Posted by Jhenderson View Post
Sounds like you wore through the rotor and all that’s left are the fins that used to join the two rotor faces. That’s why the inner pad is worn out.
I did see a member here posted a picture like that sometimes ago.
One side of the rotor was totally gone.
_________________
'05 2500 QC SLT SB 4X4 48RE Smarty Jr 205k miles
Baldwin FB1311 + Donaldson P551313 (3 Micron) + Baldwin PF7977
PWong is offline
The Following User Says Thank You to PWong For This Useful Post:
post #9 of 26 (permalink) Old 08-13-2019, 08:52 PM
Umm, no. If you do not have a flat surface with like 5-6 grooves cut in it the rotor is trashed. You need rotors and pads and might as well replace the calipers as thye are trashed form the heat and age.
utahtrapper and MDSWA like this.
post #10 of 26 (permalink) Old 08-14-2019, 01:03 AM
Another TRUE response.
Another thought is to Flush the entire Brake Fluid system starting from the right rear caliper ie passenger rear to driver side rear then passenger front to driver front caliper.
I am still waiting for Pictures!
tryNto likes this.
Carli Ball Joints
post #11 of 26 (permalink) Old 08-14-2019, 01:49 AM
Posting Suspended
Rotor fins?
This?
Or this?
https://youtu.be/qHMhsD8OFCs
Those who ride their brake pedal pay double repair costs
steelhead1 is offline
The Following User Says Thank You to steelhead1 For This Useful Post:
vreihen (08-14-2019)
post #12 of 26 (permalink) Old 08-14-2019, 02:35 AM Thread Starter
Wow! I would have never imagined that could happen. I just started having issues 2 weeks ago. I know my hearing isn't great, but ....
New rotors and pads will be ordered to night.
Thanks for the help gents.
ID:	854077   Click image for larger version
jogn2 is offline
The Following User Says Thank You to jogn2 For This Useful Post:
