Bad alternator or? - Dodge Cummins Diesel Forum
 3Likes
post #1 of 16 (permalink) Old 08-12-2019, 11:56 PM Thread Starter
Bad alternator or?
Hey everyone. First post. This site has saved me enough money to buy a new truck years ago. I’m starting to pull my hair out with my latest issue. I have a 07 5.9 w/ 180000 miles and am the original owner. I rebuilt the a/c system two weeks ago and it runs great. Also ended up having to replace the fan clutch. Several days after installing the fan clutch I got a ‘check gauges light’ with a P2305 code. Tested the batteries and was down to 10.8v and nothing coming of the alternator. Bought a new alternator and still no voltage coming off it. I’ve been charging the batteries manually the last few days and driving it still without getting the low voltage light on. I tested some more things tonight and I’ve got power on both prongs of the alternator connector. Did I get a bad alternator from nap?
Kar6man is offline
post #2 of 16 (permalink) Old 08-13-2019, 09:26 AM
PWong's Avatar
With engine idling:
What's the voltage reading output at the back of alternator?
What's the reading on the passenger side battery positive post?
What's the reading on the driver side battery positive post?
elephantrider likes this.
_________________
'05 2500 QC SLT SB 4X4 48RE Smarty Jr 205k miles
Baldwin FB1311 + Donaldson P551313 (3 Micron) + Baldwin PF7977
PWong is offline
post #3 of 16 (permalink) Old 08-13-2019, 11:17 AM Thread Starter
Originally Posted by PWong View Post
With engine idling:
I have no reading on the be post. Getting a 1. On the multimeter.
Passenger side is 11.87v
Driver side is 11.86v
Kar6man is offline
post #4 of 16 (permalink) Old 08-13-2019, 11:32 AM
steelhead1's Avatar
Most likely blown fusible link in the wire from + AUX side batt to alternator post.
steelhead1 is offline
post #5 of 16 (permalink) Old 08-13-2019, 12:29 PM
PWong's Avatar
That only tells that there is no charging juice coming to the batteries.
it doesn't meant that there is no charging juice output from alternator.
tryNto likes this.
_________________
PWong is offline
post #6 of 16 (permalink) Old 08-13-2019, 12:33 PM
PWong's Avatar
http://www.rambodybuilder.com/2007/d...gingsystem.pdf
One of your best friend.
_________________
PWong is offline
post #7 of 16 (permalink) Old 08-13-2019, 12:38 PM
PWong's Avatar
Can tell you more if the alternator output voltage is posted.
_________________
PWong is offline
post #8 of 16 (permalink) Old 08-13-2019, 01:21 PM
smelonas's Avatar
Follow PWONGS directions. PWONG knows all. You'll have a fix in no time with him helping.
I would guess fusible link. Which may trend towards an alternator issue.
Sent from my SM-N950U using Tapatalk
1994 Buick Roadmaster Sedan 'Betsy' LT1-4L60E, Every Option Good Old Fashioned Lead-Sled
2007.0 Ram 2500 MCSB Laramie Every Option - ATS S3|FASS 150|DDP 50HP|S&B Intake|4"TBE|CTS2|EFI
smelonas is offline
post #9 of 16 (permalink) Old 08-13-2019, 03:52 PM Thread Starter
Thanks for all the replies. It turned out to be the fusible link. Replaced it with 6 ga. cable and a 150 amp inline fuse and all seems to be functioning normally now. Thanks again.
Kar6man is offline
post #10 of 16 (permalink) Old 08-13-2019, 04:44 PM
PWong's Avatar
For those who are interested about the alternator output:
If the reading is the same as the passenger side battery positive post then the fusible link is good and there is no output from alternator.
If the reading is 30s something volt then the fusible link is open and the alternator is good.
tryNto likes this.
_________________
PWong is offline
post #11 of 16 (permalink) Old 08-14-2019, 12:31 AM
steelhead1's Avatar
find out why the fusible link blew out from high overcurrent. check for short to block/chassis from the alternator to the battery, worn through or crushed insulation.
Or someone momentarily grounded the + AUX side batt post while motor running. Jump starting cable connection sequence can also screw the pooch on the fusible link.
Sparks flying is usually in indication someone has screwed up and the good smoke has escaped.
Very lucky ECU is not fried
post #12 of 16 (permalink) Old 08-14-2019, 01:54 AM Thread Starter
I cut open the wire this afternoon looked like a corrosion issue about 3 inches off the battery terminal eye. When I tried to inspect it it broke clean off. I’ve got the parts to replace the fusible link to the grid heater as well. It looks to be in a similar condition.
Kar6man is offline
