High Altitude really high reail pressure smarty - Dodge Cummins Diesel Forum
 2Likes
post #1 of 16 (permalink) Old 07-21-2019, 08:34 PM Thread Starter
Kmehr's Avatar
I've seen a few threads on this but they never seemed to come to a conclusion. I'm running a Smarty Sr on 90hp tune. I live at about 6300ft and everything runs fine. When I'm up really high in the mountains though, mostly around 8500+ ft, my rail pressure goes the way of the super high and stays there even at low loads. It pegs at 25.8K and will stay there even on really low loads. There is some increased rattle/knock as well when this is going on. Definitely feels down on power, but I expect this at altitude. Turbo spool is pretty poor and I can black out a highway if i try to pull out into traffic in second and try to get on it.
Anyone have any ideas? I've haven't had a chance to put it back to stock, but I'm not going to go up that high for a few more weeks.
1984 Dodge CCSB P-pump NV4500- SOLD
2005 QCSB NV5600, SouthBend OKHD, CFM+, Jake brake, Thuren 3in, Steering brace, Synergy Track Bar, Vulcan 3 micron w/ CAT UHE 416-1225, CTS2 Insight, Smarty S06
Kmehr is offline
post #2 of 16 (permalink) Old 07-21-2019, 08:52 PM
the man in black's Avatar
Everything but the high rail sounds normal. Did your pressure go back when you went down in altitude?
Scooty Puff Sr - 2016 3500 CCLB
Truckasaurus - 2010 2500 CCSB -sold
the man in black is offline
post #3 of 16 (permalink) Old 07-21-2019, 09:04 PM Thread Starter
Kmehr's Avatar
It did. Once back lower everything returned to normal.
Kmehr is offline
post #4 of 16 (permalink) Old 07-21-2019, 09:05 PM
Everything sounds normal. Except for the rail. That's odd.
post #5 of 16 (permalink) Old 07-21-2019, 09:16 PM
TECH SPECIALIST
steve05ram360's Avatar
Go back to stock and repeat... Hook up a scan tool to it and look at the baro sensor tk ensure it is working ok
AFE PG7 drop in filter, AFE Torque Tube, HTT 2.5 turbo, AFE e-mani, ATS Arc Flo, 50HP DDP , 415k, HPTuners, G56, 25.065 mpg, mpg threads ->
steve05ram360 is offline
post #6 of 16 (permalink) Old 07-21-2019, 11:33 PM Thread Starter
Kmehr's Avatar
Definitely will be returning to stock before the next trip.
I’ve got it set to all defaults and realize there is a “stock” railpressure setting that can be selected. Maybe that’s what I need to run since I get up to that altitude once or twice a month camping.
Kmehr is offline
post #7 of 16 (permalink) Old 07-22-2019, 03:20 PM
TECH SPECIALIST
why wait until the next trip... analyze now and know the system is working properly. look at the baro sensor and know that it measures your altitude correctly, then measures it at the camp site correctly as well
post #8 of 16 (permalink) Old 07-22-2019, 06:19 PM Thread Starter
Kmehr's Avatar
I just pulled up the Baro gauge on my Edge, its reading 25.2-25.5 right now (at my office which is at 4670 feet), the weather app on my phone however is saying 30.04. This is with the Smarty program loaded. I'm guessing that's a pretty significant difference that might be throwing some things off?
Also if any moderators are watching- Anyone able to correct the spelling of "rail" in the title of this thread? Thanks
Kmehr is offline
post #9 of 16 (permalink) Old 07-24-2019, 10:46 AM Thread Starter
Kmehr's Avatar
Alright I went back to stock this morning before my commute. No change in the Baro reading, it's still about 5-6inHg lower than what appears on the weather app on my phone. What I have noticed though is that what I thought was transmission/clutch rattle, particularly in 4th, 5th and 6th gears around 1600-1800RPMS is gone...I was nervous about this given it's a brand new clutch! Rail pressure on my commute is about the same, but then again I wasn't noticing anything funny with it during my commute with the Smarty loaded.
Not sure what to make of the situation. At 167K miles, my original injectors are certainly getting a little more noticeable noise wise. MPGs and starting are still just as good as they were at 120K when I bought the truck though.
I'm about to decide to just leave tuning stock and get rid of the smarty. Plenty of power at stock level, seems to run a little better, and the locomotive smoke at high elevation, which I do frequently, ain't cool. Maybe once I get some extra $$ I'll go custom tuning.
Kmehr is offline
post #10 of 16 (permalink) Old 07-24-2019, 11:57 AM
TECH SPECIALIST
Your baro sensor appears to be OK... I would see what it says at the higher altitude.
Have you tried a tune with no added timing to remove/reduce the smoke at the higher elevation?
post #11 of 16 (permalink) Old 07-24-2019, 12:06 PM Thread Starter
Kmehr's Avatar
I have only used SW5 with defaults on this truck. I'll see what the rail pressure does at high altitude on stock before making anymore changes.
As to baro pressure- why is the reading on my phone so much higher? Just using the standard Iphone weather app.
Kmehr is offline
post #12 of 16 (permalink) Old 07-24-2019, 01:11 PM
TECH SPECIALIST
Not sure... my phone has a built in barometer and it is fairly close to what the truck says. The readings you are seeing are in line with what the chart says.
