Engine Oil Leak -- Rear Main Seal? - Dodge Cummins Diesel Forum
post #1 of 24 (permalink) Old 06-16-2019, 03:40 PM Thread Starter
Normally there are no fluid spots under the truck in the garage, but today I noticed a patch of oil under the truck, pretty much right at the back of the engine. But it's not a puddle, looks more like possibly it was sprayed there in a fine spray. There is also a fine coating of oil on most of the oil pan plus the transmission. See pic below. I checked the engine oil level and it's down a bit from full.
So from the symptoms, what am I likely looking at here -- a leaking rear main seal? If yes, this is not something I would choose to tackle, so what kind of cost should I expect a (non-dealer) shop to charge to replace the seal?
Are there other possibilities besides the rear main seal? If yes, what might be the source of the oil leak?
04.5 QCSB 4x4, 156K, 2nd Owner, Pacbrake, Airbags with onboard compressor, CTS Insight gauge w/Backup Camera, Smarty Jr tuner
Dudeonthenet is offline
post #2 of 24 (permalink) Old 06-16-2019, 04:06 PM
the man in black's Avatar
Rear main or pan gasket. Could also possibly be the valve cover leaking down the back of the block.
Scooty Puff Sr - 2016 3500 CCLB
Truckasaurus - 2010 2500 CCSB -sold
the man in black is online now
post #3 of 24 (permalink) Old 06-16-2019, 05:05 PM Thread Starter
Thank you. There is no evidence of oil leaking down from the valve cover, so must either be the rear main or the pan gasket.
post #4 of 24 (permalink) Old 06-16-2019, 07:01 PM
Gator1's Avatar
one spot that is pretty typical to leak, and really hard to see if you don't know where to look is the spacer under the valve cover in the back. Take your hand or a clean rag and wipe back there and see if it's soaked and then it will run down the oil pan, or trans case.
03 Dodge SHO CCLB Dually Banks intercooler 4" side draft intake. Carli/Thuren Argon filled Shocks, radius arms, SRW 4 link Conversion, 17"methods, 42" Goodyear MTR Kevlar Tires / 6 in a row ready to tow! NO BUSTERS
Gator1 is offline
post #5 of 24 (permalink) Old 06-16-2019, 08:00 PM Thread Starter
Thanks for the tip! I did that, and it's completely dry back there.
post #6 of 24 (permalink) Old 06-16-2019, 10:00 PM
cerberusiam's Avatar
Either rear main or cam seal. It is almost always one or both of them with any miles on the engine.
cerberusiam is offline
post #7 of 24 (permalink) Old 06-17-2019, 09:19 AM Thread Starter
Thanks, cerb.
post #8 of 24 (permalink) Old 06-17-2019, 09:56 AM
Kbess's Avatar
How would you check the cam seal? I have the same symptoms just not yet leaving a mark, I’ve been leaning towards oil pan gasket but don’t know how to narrow it down. Thanks and sorry to hijack
2004.5 Dodge Ram 2500. QCSB, NV5600. Stock
Kbess is offline
post #9 of 24 (permalink) Old 06-17-2019, 12:17 PM
Have to pull the engine adapter off the block to check the cam seal, it is buried pretty deep in there to see.
post #10 of 24 (permalink) Old 06-17-2019, 01:02 PM
Kbess's Avatar
Ahh, so it would be something to do while knocking the RM out. Sounds like a pain, I appreciate the expertise.
Kbess is offline
post #11 of 24 (permalink) Old 06-18-2019, 03:23 PM Thread Starter
I found the source of the oil that has been ending up on the bottom of my oil pan and transmission plus on the garage floor. It's the tube in the photo which comes down the driver's side of the engine, and as you can see, next to the starter. I'm having trouble tracing this tube. It's difficult to see where it goes, though it looks like the tubing turns up higher.
Can someone tell me what this tube is, and why it should suddenly start throwing some oil?
Thanks for any advice!
post #12 of 24 (permalink) Old 06-18-2019, 04:04 PM
Crank case breather. You might want to check and see if you have developing blow by.
