Remove oil pan without lifting engine - Dodge Cummins Diesel Forum
 4Likes
post #1 of 29 (permalink) Old 05-18-2019, 04:15 PM Thread Starter
evildiesel's Avatar
Looked around and could find a definitive answer to my question. I’m going to do a clutch in my truck along with a rear main seal as it’s leaking. My question is, can I just remove the flywheel housing and then slide the oil pan straight back? Has anyone done this? It doesn’t need to be done, but if it just takes removing that housing I might as well do it as preventive maintenance.
2006 Dodge Ram 2500 ST, RCLB, G56
AFE Intake - 4" Straight Flo-Pro Exhaust - EFILIVE - CARLI - TGC 3.5" lift - 20x12 wheels - 35" AT2 Tires
evildiesel is offline
post #2 of 29 (permalink) Old 05-18-2019, 04:35 PM
TWR
TWR's Avatar
Hi you should be able to but you will need to support the rear of the motor some how.
OIL PAN
REMOVAL
(1) Disconnect the battery negative cables.
(2) Install engine support fixture # 8534.
(3) Raise vehicle on hoist.
(4) Disconnect starter cables from starter motor.
(5) Remove transmission and transfer case (if equipped).
(6) Remove flywheel or flexplate.
(7) Remove starter motor and transmission adapter plate assembly.
2003 Ram 3500 6 inch lift, 2012 seats and console [email protected] Shifter, Fass 95 pump, Built 47re and mishimoto trans cooler, Srt10 hood, Smarty touch.
TWR is offline
post #3 of 29 (permalink) Old 05-18-2019, 04:44 PM Thread Starter
evildiesel's Avatar
OIL PAN
REMOVAL
Beautiful! That’s what I like to hear!
post #4 of 29 (permalink) Old 05-18-2019, 04:59 PM
TWR
TWR's Avatar
Hi that is for a 2003 but a 2006 will be same.
TWR is offline
post #5 of 29 (permalink) Old 05-18-2019, 05:02 PM Thread Starter
evildiesel's Avatar
Perfect, thank you
post #6 of 29 (permalink) Old 05-18-2019, 05:13 PM
TWR
TWR's Avatar
Hi are you going to replace the pan? If not i would look really well at your pan they like to rust under that black coating.
TWR is offline
post #7 of 29 (permalink) Old 05-18-2019, 05:15 PM Thread Starter
evildiesel's Avatar
Yes, I will be replacing the pan as it has bubbles. No leak from the pan itself, but I might as well replace it as I’m in there.
post #8 of 29 (permalink) Old 05-19-2019, 12:05 AM
T Bell's Avatar
Yeah, I just did mine and still had to lift engine. I also had to drop the rack and pinion. But mine is a 2wd, you may have enough clearance with a 4wd.
06 DRW QC auto 314k 2wd
T Bell is offline
post #9 of 29 (permalink) Old 05-19-2019, 11:36 AM Thread Starter
evildiesel's Avatar
Yea mines a 4x4 with a 3.5” lift so I won’t have to lower the axle.
post #10 of 29 (permalink) Old 05-19-2019, 11:49 AM
Quig19's Avatar
2006 service manual says remove trans, flywheel or flexplate, starter, remove bolts to pan, remove suction tube at front of pan 2 bolts (make sure you have a gasket for it) slide pan out back of engine. I just replaced my oil pan and pan gasket. I cut the cross member (remove brake line that runs along the cross member) and welded it back in 3 hour job.
2006 3500 360hp 706ftlbs<-stockw/ custom 'puter flash now with edge juice w/attitude, 5" turbo back to 6" Aussie Stacks "That thing got a Hemi ?? Nah CUMMINS TURBO!!!!!
Quig19 is offline
post #11 of 29 (permalink) Old 05-19-2019, 11:54 AM Thread Starter
evildiesel's Avatar
That’s one way to do it and to me it’s pretty hack. The PO did it to my truck cuz I can see the two big welds on the crossmember. I was gonna cut it right out and make up a removable crossmember.
hseII likes this.
post #12 of 29 (permalink) Old 05-19-2019, 12:04 PM
Quig19's Avatar
I ground my welds and added more steel. looks better than factory
hseII likes this.
Quig19 is offline
Similar Threads
Transmission...Stumped Jhart11 3rd Gen. Powertrain 5 11-02-2013 09:28 PM
Fuel Requirements For Cummins Engines - Service Bulletin 3379001 LReiff Technical Service Bulletins & Recall Support 9 11-17-2012 02:48 PM
auto to manual 2wd swap write-up benartm80 98.5-02 Powertrain 5 08-10-2012 07:17 AM
edge problem? pump problem? where to start??? CATSTACKS 98.5-02 Powertrain 14 10-29-2011 06:03 PM
first 24v okcoalroler99 98.5-02 Powertrain 13 09-27-2011 01:24 PM
