2006 transmission issues - Dodge Cummins Diesel Forum
 4Likes
post #1 of 27 (permalink) Old 05-14-2019, 12:41 PM Thread Starter
I just recently bought a 2006 quad cab 4x4 with automatic transmission. At cruising speeds the truck shifts fine, but from a dead stop it has issues with shifting from 1st and 2nd. It will either rev up or you have to feather the throttle for it to shift.
The truck has the original motor and transmission with right at 300k miles.
Any help would be great.
Sent from my SM-G965U using Tapatalk
Abstrastic is offline
post #2 of 27 (permalink) Old 05-14-2019, 12:48 PM
dhoagland's Avatar
Second gear apply band adjustment would be a start.
Then check band apply pressure.
https://www.cumminsforum.com/forum/3...tment-tip.html
03 2500 SO QC 4x4. Airaid, 2nd Gen Intake, Grid Heater Delete, D-Tech 62/65/12, Magnaflow. Bully Dog: Propane Injection, Triple Dog W/Outlook Crazy Larry. Edge EZ, BD Flow-Max, frame mount 3 Micron filter W/Water Separator, Big line kit "Wild Cat Version" 48RE: Sonnax Sure Cure/Transgo combination, Derale turbulator, billet input, Triple Disc,Super servo, 4 ring Accumulator.
dhoagland is offline
post #3 of 27 (permalink) Old 05-14-2019, 03:33 PM
MDSWA's Avatar
Check for diagnostic trouble codes (DTC's) . Turn key on/off 3 times. Leave key in on position 3rd time, engine off. Read codes in odometer. If it displays a P0720 code, you have a bad transmission output shaft sensor. Cheap part and only takes 5 minutes to change. Check Youtube for video on how to change it.
dhoagland likes this.
MDSWA is offline
post #4 of 27 (permalink) Old 05-14-2019, 04:06 PM Thread Starter
Checked for dtc's this morning and there were none... bout to just replace the transmission with one that has 3yr or 100k mile warranty. It's got 300k on it and I plan to drive this truck for a long time pulling a lot of trailers. So I dont want to be stranded out in bfe.
post #5 of 27 (permalink) Old 05-14-2019, 07:07 PM Thread Starter
Originally Posted by autocomputerdiesal View Post
That is a common issue we see alot in the computer. If you need help with your ECM, PCM, TCM call us at 1-800-680-4275 | 1-888-664-8787. We have free tech support and free car computer testing. We have the best prices for repairs and replacements on all auto computers.
So you think this is a computer issue not a transmission issue? Explain please...
post #6 of 27 (permalink) Old 05-14-2019, 09:34 PM Thread Starter
Transmission is bought and going to the shop Thursday. I have no 1st or 2nd gear now.
post #7 of 27 (permalink) Old 05-15-2019, 07:29 AM
Hello What if any upgrades are you having installed in new/rebuilt tranny.
2006 CCLB 2500,silver, stock , 373,
Bluejoe is offline
post #8 of 27 (permalink) Old 05-15-2019, 06:44 PM Thread Starter
Fully built transmission from Jasper, their top of the line trans. $4700.
post #9 of 27 (permalink) Old 05-15-2019, 10:56 PM
smelonas's Avatar
This should end well...
Sent from my SM-N950U using Tapatalk
rghavana likes this.
1994 Buick Roadmaster Sedan 'Betsy' LT1-4L60E, Every Option Good Old Fashioned Lead-Sled
2007.0 Ram 2500 MCSB Laramie Every Option - ATS S3|FASS 150|DDP 50HP|S&B Intake|4"TBE|CTS2|EFI
smelonas is offline
post #10 of 27 (permalink) Old 05-15-2019, 11:16 PM
Youre possibly not a fan of Jasper transmissions.....?
davo727 is offline
post #11 of 27 (permalink) Old 05-16-2019, 05:41 AM Thread Starter
3yr or 100k mile warranty on the transmission no questions asked.
post #12 of 27 (permalink) Old 05-16-2019, 08:47 AM
steelhead1's Avatar
good luck with that out of state "warranty". hope you have a thick wallet.
https://www.bbb.org/us/in/jasper/pro...511/complaints
steelhead1 is offline
Similar Threads
Transmission issues, with codes....please help gsmitty90 4th Gen Powertrain 7 01-05-2015 04:42 PM
Shift Issues, Vibration @60mph, AC Blows Hot & Washer Fluid Light on...Pandoras Keeps cpao1064 3rd Gen. Powertrain 4 07-26-2013 04:01 PM
Another Transmission issue ThatOneGuy469 3rd Gen. Powertrain 15 08-03-2012 04:54 PM
48re Question Driller05 3rd Gen. Powertrain 8 09-10-2011 06:29 AM
