Fuel pressure woes? - Dodge Cummins Diesel Forum
 2Likes
post #1 of 14 (permalink) Old 05-14-2019, 07:34 AM Thread Starter
Fuel pressure woes?
Good morning all,
This morning on my way to work I was watching my fuel psi on my cts2 monitor. I do not have a programmer. At idle with my foot on the brake I read around 5.2-5.3k psi and at wot the most I’ve witnessed is 17k. This seems low to me and I want to know if it’s something I should be worried about. I have no idea if/when the injectors were changed. My truck is a 2003 non ho 5.9l 47re 3500 4x4. My truck does have the lope at idle every now and then when warming up. The fuel filter was changed 2000 miles ago. Truck has 319k on it, was bought with 310k on it back in December. Thanks in advance for any and all input.
Jason- 99' dodge 3500 flatbed, 2wd, 3.55's, nv5600, airdog 100
Jrollings is offline
post #2 of 14 (permalink) Old 05-14-2019, 04:14 PM
I don't know if this is any help. I have a CTS2 monitor as well. But my truck is an 04.5 and may work differently. My rail pressure at idle is consistently in the 6-7K range. I can't say what it is WOT because I haven't really paid attention. I'll try to remember to goose it next time out and take note of the pressure.
2004.5 3500 QC SB 4X4 48RE 3.73s Laramie Silver over graphite leather, Pacbrake, Insight CTS2 Monitor, Putco wheel to wheel steps, chromed OEM alloy wheels, Pullrite 16K superglide, Tekonsha Prodigy, Line-X, Extang Trifecta
njmurvin is offline
post #3 of 14 (permalink) Old 05-14-2019, 06:59 PM
05PowerHouse's Avatar
iTrader Score: 7 reviews
17k for fuel pressure is fine, its rail pressure you should be monitoring..
| Firepunk HP-T | Firepunk Comp 2 | GDP Fuel-Boss | T&C 10mm | Ducky 63% | Billet S400 | GDP Air-Boss | Stud's | Rods | Springs | Gauges |
770HP 1150TQ ( Conservative Tune )
05PowerHouse is offline
post #4 of 14 (permalink) Old 05-14-2019, 07:17 PM
GRUNT 11B's Avatar
He is talking about RP. 17 KPSI is 17,000 PSI. The lift pump is not capable of 17 KPSI. Even if it was, it would blow lines and seals. The edge CTS2 cannot read fuel pressure unless you put one of their sensors (EAS i believe) in.
06 QCLB 4X4 G56, SOUTHBEND DD, FASS 150, ARP STUDS, 50HP INJECTORS, EFI, HE351 S475 COMPOUNDS, FLUIDAMPR, HAMILTON PUSHRODS & 103# SPRINGS, 624 HP 1090 TQ 01 QCLB 4X4 AUTO, WHEELS, TIRES, STEERING WHEEL, CUMMINS, BUMPERS, FUEL TANK, SEATS, ETC.
GRUNT 11B is online now
post #5 of 14 (permalink) Old 05-14-2019, 07:20 PM
Your reading Rail Pressure, your idle RP is fine, seems a bit low at WOT. My 03 idles at about the same amount.
2003 4x4 QC SB Cummins 5.9 Toyo A/T 2 265/70/17 Smarty Jr. 4" TBE/ FTE 30"
Big Lar is offline
post #6 of 14 (permalink) Old 05-14-2019, 07:20 PM
GRUNT 11B's Avatar
Do you have hard starts/long cranks or white smoke at start up?
post #7 of 14 (permalink) Old 05-14-2019, 07:26 PM Thread Starter
Thanks to everyone for the replies. I checked again on my way home from work and hit 22k at wot so I jumped the gun posting so soon. Now I just need to figure out why I have a like at idle.
post #8 of 14 (permalink) Old 05-14-2019, 07:26 PM Thread Starter
No hard starts or long cranks.
post #9 of 14 (permalink) Old 05-14-2019, 09:21 PM
Yes, you are correct. My mistake since the OP stated he was monitoring "fuel pressure ".
post #10 of 14 (permalink) Old 05-15-2019, 07:36 AM Thread Starter
Not worth it
post #11 of 14 (permalink) Old 05-15-2019, 10:24 AM
Gator1's Avatar
You're close, I'd say your IP is just showing it's age a little, my RP is 7K @ idle and 26K @ WOT with a fresh IP.
24hrsparkey likes this.
03 Dodge SHO CCLB Dually Carli/Thuren Argon filled Shocks, radius arms, SRW 4 link Conversion, 17"methods, 42" Goodyear MTR Kevlar Tires / 6 in a row ready to tow!
Gator1 is online now
post #12 of 14 (permalink) Old 05-15-2019, 04:17 PM
I think the 2003 have lower idle rail pressures that the later model trucks. I have a 2003 and mine is about the same as yours. Occasionally I see 5.1 and never over 5.6 at idle
2003 Dodge 2500 5.9 Stock
Brav302 is offline
Similar Threads
Bosch vp44 101 Jeeper Jimmy 98.5-02 Powertrain 48 02-23-2017 07:41 PM
Stuck in socorro, p2146 & p0148 snailhouse_projects New Mexico 18 07-01-2015 11:32 PM
Furnace oil? LPU_911 Alternative Fuels, Additives, Oils & Lubricants 6 12-16-2013 11:12 AM
VP44 Cut away rattlewagon 98.5-02 Powertrain 16 10-13-2011 01:46 AM
Joe G's fuel system writeup ykdave 94-98 Engine 2 04-22-2008 09:13 AM
