Torque converter cooler - Dodge Cummins Diesel Forum
 3Likes
post #1 of 37 (permalink) Old 04-23-2019, 10:25 PM Thread Starter
OneBadDodge's Avatar
I have a really dumb question that I've mulling over doing.
Transmission was still getting warm plowing last winter. Only thing I got left for ideas is possibly getting a small electronic fan to attach to the torque converter cooler next to the engine to help cool things off. But I don't know if this is a really idiotic idea or not.
2006 2500 Heavy Duty Sport Quad Cab, Bullydog PMT,
Bullydog Intake, 5" exhaust,Transgo/Sonnax 48RE Upgrades, Carli ball joints and track bar.
OneBadDodge is offline
post #2 of 37 (permalink) Old 04-23-2019, 10:56 PM
Gator1's Avatar
Most people add an Auxiliary cooler with a fan, and thermostat to deal with temps
03 Dodge SHO QCLB Dually w/ Banks intercooler 4" side draft intake. Carli/Thuren Argon filled Shocks, radius arms, SRW 4 link Conversion, 17"methods, 42" Squishy's, / 25.263 mpg legit. Disabled Marine wartime veteran.
Gator1 is online now
post #3 of 37 (permalink) Old 04-23-2019, 11:39 PM Thread Starter
You mean like what BD diesel has with a remote aux cooler?
post #4 of 37 (permalink) Old 04-23-2019, 11:54 PM
evildiesel's Avatar
Adding a fan to that will do nothing. It’s not like a rad with fins where it’ll pull heat away. a good upgrade would be to add an additional auxiliary cooler with its own fan. That will keep it cool.
2006 Dodge Ram 2500 ST, RCLB, G56
AFE Intake - 4" Straight Flo-Pro Exhaust - EFILIVE - Southbend DD Clutch - CARLI - TGC 3.5" lift - 20x12 wheels - 35" AT2 Tires
evildiesel is offline
post #5 of 37 (permalink) Old 04-24-2019, 01:30 AM
smelonas's Avatar
Did the front cooler leak and clog itself with dirt?
Delete the thermostat in the cooler for starters. Should help a good bit in the winter months..
Sent from my SM-N950U using Tapatalk
1994 Buick Roadmaster Sedan 'Betsy' LT1-4L60E, Every Option Good Old Fashioned Lead-Sled
2007.0 Ram 2500 MCSB Laramie Every Option - ATS S3|FASS 150|DDP 50HP|S&B Intake|4"TBE|CTS2|EFI
smelonas is offline
post #6 of 37 (permalink) Old 04-24-2019, 09:36 AM
Gator1's Avatar
Yes, I have one of their double stacked coolers. Derale makes a bunch of them also, but the BD is plug and play with wiring and thermostat in a kit. Pretty nice. I also deleted the heat exchanger, but if you live in snow country I'd keep it for the winters because it will heat your fluid up faster.
post #7 of 37 (permalink) Old 04-24-2019, 09:47 AM
Gator1's Avatar
The stock cooler is only 1/2" thick, and is a tube and fin type is not very efficient. Stack pl8 design is best and the Derale are a full 2" thick for literally 4X the cooling as stock and 2X the cooling as the Mishimoto replacement cooler for 1/2 the price!!! The brackets I made are also 6061 Aluminum so the whole assembly is one big heat sink.
post #8 of 37 (permalink) Old 04-24-2019, 09:52 AM
Dynamic's Avatar
This is the setup I typically install when MAX cooling is needed. Between the cooler thermostat delete and this setup, you will not have any temperature issues.
Name:	IMG_1851 (800x600).jpg
24hrsparkey and Gator1 like this.
2000 Ram 2500, Quad, SB, 4x4, 24V...SOLD
Dynamic is offline
post #9 of 37 (permalink) Old 04-24-2019, 12:41 PM
I already have the thermostat delete. Is this fan setup available to purchase as a kit?
2004.5 3500 QC SB 4X4 48RE 3.73s Laramie Silver over graphite leather, Pacbrake, Insight CTS2 Monitor, Putco wheel to wheel steps, chromed OEM alloy wheels, Pullrite 16K superglide, Tekonsha Prodigy, Line-X, Extang Trifecta
njmurvin is offline
post #10 of 37 (permalink) Old 04-24-2019, 02:56 PM
Dynamic's Avatar
No, we never did put this together as a kit. We just use -8AN plumbing and a Derale 15870 cooler. I typically install them with a temp switch on the inlet, but with provision to manually turn the fan on via a dash-mounted switch. This is a heat shedding monster, especially when your'e dealing with limited airflow such, as when plowing snow.
Dynamic is offline
post #11 of 37 (permalink) Old 04-24-2019, 02:58 PM
smelonas's Avatar
Jon, if I ever decide to move up to Washington, I'll be sure to put these kits together and ship em out for you. Haha
Man has it all right. Thermoswitch pre cooler, with manual override, 8AN the whole system.
smelonas is offline
post #12 of 37 (permalink) Old 04-24-2019, 03:11 PM Thread Starter
When you say delete the thermostat, are you talking about the one in the transmission cooler in the front?
Thought there was a "how to" on here I read many years ago.
Similar Threads
Damaged Torque Converter Cooler, what are my options? hardtail 3rd Gen. Powertrain 7 08-18-2014 04:01 PM
Torque converter cooler leak jrcaldwell75 3rd Gen. Powertrain 1 07-29-2014 10:41 PM
Torque converter cooler delete? DirtyWhite325 3rd Gen. Powertrain 21 06-25-2012 10:13 PM
93 automatic torque converter?? wallybanger 89-93 Powertrain 22 12-21-2011 09:24 PM
ATS Diesel Performance Co-Pilot & Commander cummins96 2010-2012 General Discussion 12 06-22-2011 09:46 AM
