**HELP** Motor Mount Stuck - Dodge Cummins Diesel Forum
post #1 of 2 (permalink) Old 04-19-2019, 04:55 PM Thread Starter
06 5.9 auto in the process of removing my oil pan and for the life of me I can’t get the engine to lift off the mounts. Removed the nut from both sides bolt is still in place... Unbolted trans crossmember and turbo is currently off the truck so outlet pipe and down pipe aren’t an issue. Using a 2 ton cherry picker have tried lifting from only the front lift point and front & rear at the same time. There is nothing keeping it from coming up that I can see. Is there something I’m missing here? Any help at all is greatly appreciated
BrilliantLaramie is offline
post #2 of 2 (permalink) Old 04-20-2019, 10:22 PM
macko300exc's Avatar
Remove the bolt about an inch. The washer on the bolt can grab the mount. May also need a bottle Jack on the pumpkin of the front diff. Disconnect cold side boost tube.
Just did one the other day
macko300exc is offline
Similar Threads
Getrag gets stuck in 5th gear hteah 89-93 Powertrain 5 06-27-2015 10:54 PM
Left hand blinker stuck on 99FiveNine 98.5-02 Non-Powertrain 14 03-25-2015 07:54 AM
HELP! key fob stuck, and stuck in park Brettkk 2010-2012 General Discussion 11 02-14-2015 07:36 AM
14' stuck no 4X4 adama 4th Gen Powertrain 20 11-16-2014 02:34 PM
Pullrite superglide stuck bufordTjustice Towing & Hauling 4 05-21-2014 10:56 PM
