Trans help - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 04-15-2019, 05:23 PM Thread Starter
Trans help
I've done my research and can't find a definitive answer.
The 48re is shifting funny in my 05.
1-2 is slightly harsh most of the time
2-3 usually seems good.
3-4 seems to slip or rpm flare up during the shift. Doesn't happen every time. More so when I'm a bit heavier on the throttle or pulling my 4000lb trailer.
Happens in tow/haul as well
Just installed a borg Warner governor pressure solenoid and transducer.
Adjusted rear band while I was in there, front band was done not too long ago.
Time for a rebuild?
2005 ccsb. 48re. mbrp 4". leveled on 35's.
Albertan is offline
post #2 of 9 (permalink) Old 04-15-2019, 07:17 PM
02smokin's Avatar
Mine was doing all of that plus slipping in o.d. While loaded up hill, I said screw it and ordered a new trans and converter, be here Wednesday
06 4dr LB Laramie,dynamic stg 4,64.5/73/.91,steed speed,anarchy EFi,Fleece bypass,ARP 425ís,insight,pac brake,6" Carli,long arms, king 2.5's,WFO traction bars,35ís
Sold trucks, 99,02,05,07,14
02smokin is offline
post #3 of 9 (permalink) Old 04-15-2019, 09:44 PM
cerberusiam's Avatar
1-2 hard shift could be front band is too tight, might want to play with that adjustment. A flare shift going into OD is bad ju-ju, that generally means the OD directs are slipping before the OD brakes engage.
cerberusiam is online now
post #4 of 9 (permalink) Old 04-16-2019, 10:03 AM Thread Starter
Thanks for the reply. I will check the front band adjustment.
I may not be describing the 3-4 shift properly.
It's almost like the truck downshifts for a split second before up shifting. Not so much of a slip.
My knowledge on these transmissions is minimal obviously so excuse me if I'm out to lunch.
Seems like maybe it goes from 3rd lock to 3rd unlocked then locks in 4th? Explaining the rpm rise at the shift?
Albertan is offline
post #5 of 9 (permalink) Old 04-16-2019, 10:21 AM
Dynamic's Avatar
You don't describe whether or not your transmission is stock, or if you have any transmission or valve body mods (shift kit, maybe?).
Your 3-4 shift feeling is likely the converter unlocking for the 3-4 upshift after having locked in 3rd, then completing the shift, and then relocking the converter. It's annoying, but normal.
2000 Ram 2500, Quad, SB, 4x4, 24V...SOLD
Dynamic is offline
post #6 of 9 (permalink) Old 04-16-2019, 10:33 AM Thread Starter
The trans is stock as far as I know. (second owner)
Albertan is offline
post #7 of 9 (permalink) Old 04-16-2019, 11:02 AM
how about you post a little video of what its doing .?
2003 2500 bully dog tuner k/n air filther trans rebuild by me . tripe disc torque Dap injectors 60hp industrial injection bag of part . more mods in the future.
robert s is offline
post #8 of 9 (permalink) Old 04-16-2019, 05:30 PM Thread Starter
Here's a link to a few videos. All with an empty truck.
70% throttle:
https://m.youtube.com/watch?v=sf3lVCplFXY
Full throttle:
https://m.youtube.com/watch?v=85BfQNd-xwg
Tow haul:
https://m.youtube.com/watch?v=O1pxoBDljeA
Regular acceleration:
https://m.youtube.com/watch?v=SW4DN3CQfRA
Albertan is offline
post #9 of 9 (permalink) Old 04-17-2019, 09:47 AM Thread Starter
Bump.......
Albertan is offline
Similar Threads
Help Help...Code kevinb 4th Gen Powertrain 4 07-30-2014 07:11 AM
Antifreeze in my trans :( IHbuff 3rd Gen. Powertrain 13 06-15-2014 12:50 AM
At witts end with this automatic NEED ADVICE TRANS GURUS! pepsi71ocean 98.5-02 Powertrain 18 03-04-2013 05:30 AM
Carnage 12_second_Dmax Arizona 5 12-13-2012 11:54 AM
trans wont go into overdrive?!?! ifyoucantdodgeitramit 94-98 Powertrain 11 08-29-2012 08:37 PM
