Dodge Cummins Diesel Forum
Dodge Cummins Diesel Forum (https://www.cumminsforum.com/forum/)
-   3rd Gen. Powertrain (https://www.cumminsforum.com/forum/3rd-gen-powertrain/)
-   -   06 2500 Diagnostics? (https://www.cumminsforum.com/forum/3rd-gen-powertrain/2498419-06-2500-diagnostics.html)
wink_06 04-15-2019 05:22 PM
Hope you’ll can give me some ideas....
I have an 06 2500 with 172,000 miles that’s having some issues. I feel like they’re all related. Starting a few weeks back, the truck started to feel like it lost some of its power, shifting just wasn’t as smooth as it used to be when i’d step on it . Once the truck is warmed up, the fan roars like I’m hauling heavy up a huge grade, (Kind of like how the 6.7’s roar) and the belt squeals more when I’m turning the truck off. About the same time, the heater started being slow to work— I can drive for a good 15-20 before I get any heat in the cab. Even when I have it on high. Today, I was driving to work and it popped the “check gages” light and the coolant read as overheating. The truck was not overheating— no smell from the engine bay and was correctable by blowing the heat into the cab. The check gages light intermittently turned off and on for the remainder of the drive.
What the heck?! I’m thinking the thermostat is bad and/or the fan clutch is going out?
The truck just had brand new batteries installed last week, new fuel pump and sensor a couple months ago. Regular maintenance, coolant is full. Not used for any heavy hauling. Up until now it wouldn’t pop any codes.
I plan to take it to the shop at the end of the week for diagnostics but if I can fix it before that’d be ideal.
Any ideas appreciated!!
rghavana 04-16-2019 09:01 AM
:welcome:
I would try and find out what is squealing
wink_06 04-16-2019 11:12 AM
Pretty sure the squeal is just the belt tensioner going out. It only squeals when turning the engine off.
I plan to replace the thermostat, water pump, belt and belt tensioner this weekend. Hopefully that solves my issues.
Powered by vBulletin® Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
