Is my transmission "hunting"... - Dodge Cummins Diesel Forum
 1Likes
  • 1 Post By cerberusiam
post #1 of 10 (permalink) Old 04-15-2019, 04:39 PM Thread Starter
Deanp88's Avatar
I have an 05 2500, 240k miles. I have noticed that when I tow, about 7000 lbs, and in T/H when my transmission shifts from 3rd to 4th or OD the RPM's will raise about 2-300 then drop back down. It only does this once. I have read several threads where people state that their transmission will shift back and forth between 3rd and 4th but mine does not do that.
Is there a remedy for this? Do the remedies for the hunting apply to this case?
Deanp88 is offline
post #2 of 10 (permalink) Old 04-15-2019, 04:44 PM Thread Starter
Deanp88's Avatar
I should mention that my truck is stock and I have a Smarty Jr set on #2 tow tune.
Deanp88 is offline
post #3 of 10 (permalink) Old 04-15-2019, 04:56 PM
Nv5600 swap
Sent from my SM-N950U1 using Tapatalk
2005 Crew 4x4 3500
floridabrahmer is offline
post #4 of 10 (permalink) Old 04-15-2019, 07:21 PM Thread Starter
Deanp88's Avatar
Originally Posted by floridabrahmer View Post
Nv5600 swap
I don't know what this is...
I also found out that in T/H mode it will do it while not towing anything. It does not do it without T/H on.
Deanp88 is offline
post #5 of 10 (permalink) Old 04-15-2019, 07:32 PM
Eric-07's Avatar
When’s the last time your trans was serviced?
If you don’t know then it’s time.
Fluid, filter, governor pressure sensor, transducer and, band adjustment and see what that gets you.
2007 5.9 MC - AIRDOG, AIRLIFT, ARP, AUTOMETER, BMS 100's, CPP 103# SPRINGS, 62/475, EXERGY 10mm, EFI LIVE BY [email protected] gltuningsolutions.com @DODGE74
, POWER DRIVEN DIESEL TRANS
, MBRP, MOTOMETAL, PRO COMP, NITTO RGS SUPERGLIDE 3600, FUZION 5'R
Eric-07 is offline
post #6 of 10 (permalink) Old 04-15-2019, 07:32 PM
Eric-07's Avatar
Stupid double post...
Eric-07 is offline
post #7 of 10 (permalink) Old 04-15-2019, 07:34 PM Thread Starter
Deanp88's Avatar
Fluid and filter were done about 150 miles ago. The other stuff I am not sure about. I will look into it. Could any of that cause this issue?
Deanp88 is offline
post #8 of 10 (permalink) Old 04-15-2019, 07:41 PM
Eric-07's Avatar
When it revs up those 2-300 rpm is there any power behind it or is it like it’s in neutral?
Eric-07 is offline
post #9 of 10 (permalink) Old 04-15-2019, 08:01 PM Thread Starter
Deanp88's Avatar
It happens in about 1 second but I do not feel the truck slow down or anything. Forward movement seems to stay constant but like I said, it happens very quickly.
Deanp88 is offline
post #10 of 10 (permalink) Old 04-15-2019, 09:38 PM
cerberusiam's Avatar
200-300 rpm variance is the TC unlocking and locking. The sift from 3rd to 4th is like 600-800 rpm drop depending on how hard you are on the throttle and when in TH the TC lock in OD is almost instant.
No idea what you are feeling when but it isn't normal and isn't shuttle shifting.
Craig06 likes this.
cerberusiam is offline
Similar Threads
2010-2012 6.7L Service Data & Part #s shanepx2 4th Gen Powertrain 192 07-21-2018 06:06 AM
Complete safe transmission fluid change method ? bluedoor 94-98 Powertrain 1 05-04-2018 09:45 PM
47RE Gurus, I need input. davedriveschevys 98.5-02 Powertrain 7 02-20-2015 03:28 PM
2001 2500: Another bad automatic transmission defdes 911 Urgent Situations 5 01-31-2015 07:41 PM
Mystery Transmission Chrismelto 89-93 Powertrain 8 01-10-2015 11:57 AM
