P2146 & P2149 codes, barely running - Page 2 - Dodge Cummins Diesel Forum
 2Likes
post #13 of 18 (permalink) Old 04-16-2019, 08:28 PM
ssteve's Avatar
Well not really, because the problem only happens when the engine is running and warm. Things change when they get hot. I'll bet it's the valve cover gasket, as there have been known issues with them.
2006 2wd long bed quad cab. Bully dog triple dog programer. Cat fuel filter. Transgo shift kit, 150,000 miles.
ssteve is offline
post #14 of 18 (permalink) Old 04-17-2019, 12:40 PM
Originally Posted by dstevenson32 View Post
UPDATE: Pulled the VC,visually everything looked good and I tested all of the injectors and individual wires. All injectors were exactly .5ohms and wires were at .2 ohms, from what I understand thats what they are supposed to be at am I right? So im assuming that means issue is in main wire harness or ecm?
Seems your injectors are fine by themselves. So then just the wiring going to the injectors maybe intermittently open inside the wire plugs?
Or a broken wire inside the insulation wire sheath.
Could be bad plug end terminal connectors not making a good connection somewhere.
good practical video on fixing p2146
sdowney717 is offline
post #15 of 18 (permalink) Old 04-28-2019, 07:51 PM Thread Starter
dstevenson32's Avatar
Thanks for the reply ill definetly have to inspect all of that alittle further.
UPDATE
Truck started running good and i was able to drive around, then I went out of state and the truck sat for a week and when i got back today and went to start it, the truck had a real hard time starting and when it finally did it idled horribly and blew a ridiculous amount of white and grey smoke. CEL came on and i got a P0606 “ECM hardware error” and only the P2146 this time. At this point I’m pretty stumped. I want to say maybe a bad ECM or wiring but all that white smoke and sputtering hard idle makes me think more on the injector side
95' 2500 hx40, stage 2 industrial injectors, raptor RP150 fuel pump, southbend clutch, 4"-5" Diamondeye exhaust
dstevenson32 is offline
post #16 of 18 (permalink) Old 05-21-2019, 08:54 AM Thread Starter
UPDATE for anyone who stumbles on this thread with the same issues, the ECM ended up being fried. I replaced the ECM, all the issues went away and its running good now
post #17 of 18 (permalink) Old 05-21-2019, 10:41 AM
Good you got it fixed. When you changed the ECM, did it need to be flashed for the vin number, I think its not just plug and play?
post #18 of 18 (permalink) Old 05-21-2019, 11:24 AM Thread Starter
Good you got it fixed. When you changed the ECM, did it need to be flashed for the vin number, I think its not just plug and play?[/QUOTE]
Thanks, but I know it’s about time truck was down for almost a month. I sent my ECM out to be tested and when it tested bad that company has ECMs that they are able to flash for my VIN, mileage and manual transmission. As far as my understanding goes they are not plug and play but you can always get them reflashed if you find a used one
Similar Threads
Truck throwing codes but running fine? timmy-boy 98.5-02 Powertrain 4 10-03-2015 12:09 AM
Pulling P0121, P0237, P0633, P1222, P2146, & P2149 CarnageZ28 3rd Gen. Powertrain 2 09-24-2013 09:05 PM
25K miles zero codes then truck would barely... rraulston 07.5 - 09 3rd Gen 6.7L Powertrain 7 09-09-2011 12:14 AM
got codes P2146 and P0201 goodriddance 3rd Gen. Powertrain 3 07-19-2011 12:33 PM
03 5.9 white smoke running rough codes Dunbar 911 Urgent Situations 0 01-09-2011 03:31 PM
