Pulled engine codes P0201 and P2146... - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 04-14-2019, 05:37 PM Thread Starter
Barefootdog's Avatar
Running a steady 60 mph on the freeway. Engine light came on and motor immediately began to miss. No smoke out the pipe either running, idling or parked. Oil level stable. Starts easily w/no smoke. Obvious miss and poor power.
162,000 on the odometer...original OEM injectors in motor.
I have upgraded filtration as noted below.
Pulled codes P0201 and P2146.
Both associated with injectors, wiring to injector or ecm.
I know nothing about turning wrenches...
Just how f*cked am I?
06 QCLW SLT Big Ho 4X. 5.9 w/G56. DIY intake mod, DPP Cool Tube, Vulcan VP Max fuel filter, Alum DS, 08 streering/brace, Rancho 9000xl shocks, Hellwig Big Wing sway bar, air bags. Yukon free spin kit. EMF ball joints. Spicer u-joints.
Barefootdog is offline
post #2 of 10 (permalink) Old 04-14-2019, 05:40 PM Thread Starter
I don't trust either of the Dodge dealers in town.
There is a Cummins Northwest shop 5-6 miles north.
Any other recommendations in central Willamette Valley (Eugene) in western Oregon?
post #3 of 10 (permalink) Old 04-14-2019, 05:45 PM
Electrical circuit is not completed to the injector solenoids, could be plug connections, wires or an injector gone open circuit. One or more injectors is not firing fuel into the cylinder, so your running on 5 or less cylinders.
sdowney717 is offline
post #4 of 10 (permalink) Old 04-14-2019, 05:46 PM
rghavana's Avatar
Check wiring to injectors on valve cover hopefully just shook loose.
If that is not cause I would ohm test wires from ecm to injectors, known issue with harness failing.
04 QCSB HO Automatic
rghavana is offline
The Following User Says Thank You to rghavana For This Useful Post:
Barefootdog (04-15-2019)
post #5 of 10 (permalink) Old 04-14-2019, 05:50 PM Thread Starter
So....by not firing into one or more cylinders.....that's POSSIBLY better than over fueling 1 or more cylinders and frying pistons/cylinders....yes?
I'm looking for a ray of sunshine here...
Motor has been well serviced/maintained. Ran perfect prior to this.
post #6 of 10 (permalink) Old 04-14-2019, 05:54 PM
Its not overfueling, its not fueling one or more cylinders, which means no engine damage just going by the codes. Its also not likely the ECM or whatever fires the injectors, but most likely a loose or bad connection to an injector. It could be a bad injector the electrical part gone open. An ohmmeter would help and some electrical sleuthing.
The Following User Says Thank You to sdowney717 For This Useful Post:
post #7 of 10 (permalink) Old 04-14-2019, 06:15 PM Thread Starter
Guess its up to Cummins Northwest in the AM....
post #8 of 10 (permalink) Old 04-14-2019, 10:46 PM
steelhead1's Avatar
Most Cummins NW shops won't touch these light duty Dodge pickup motors. They don't have the special Mopar scan tool.
Your best bet for Eugene is Oregon Fuel Injection
https://oregonfuelinjection.com/
Get NEW factory Bosch only or BBI injectors. OFI only has the rebuilt Bosch off breed junke.
Or go to Source Diesel or Pure Performance, longer drive
steelhead1 is offline
The Following User Says Thank You to steelhead1 For This Useful Post:
post #9 of 10 (permalink) Old 04-15-2019, 02:24 PM Thread Starter
Update
Did my homework were I wanted to get this thing looked at, sourced parts/prices for valve cover gasket/harness, injector (if one were needed) and car rental.
Was ready to call the hook for the tow.
Went out and jiggled wires and worked the connectors from valve cover gasket to ecm...got in and it fired right up. Ran smooth, steady and with full power. Drove it around the neighborhood. It's running smooth and with full power. Will get it out on the freeway next.
Could it really be this easy...?
post #10 of 10 (permalink) Old 04-15-2019, 04:30 PM
Yes, sounds great for you. Just a bad connection in a plug or something like that.
Similar Threads
P0201 Code and P2146 Code Help pete97 3rd Gen. Powertrain 5 10-18-2015 08:50 PM
HELP HELP HELP alot of codes dont know what to do dodgeCumminstittle92 3rd Gen. Powertrain 11 10-29-2014 03:36 PM
This might be a complete list of codes... ProjectCummins740 3rd Gen. Powertrain 3 04-09-2013 12:39 AM
trouble codes p0201 and p2146 danielbradley 3rd Gen. Non-Powertrain 2 02-25-2012 02:43 AM
got codes P2146 and P0201 goodriddance 3rd Gen. Powertrain 3 07-19-2011 12:33 PM
