Torque converter unlock switch - Page 2 - Dodge Cummins Diesel Forum
post #13 of 17 (permalink) Old 04-16-2019, 06:11 PM Thread Starter
dsldude's Avatar
Originally Posted by 02smokin View Post
First of all what turbo are you running? Sig just says T4? What size tires?
33" tires. s300sxe 63-73 compressor 63/80 super core turbine housing 80mm. 83 a/r twin scroll. Pretty sure it's just these sh$t injectors. Wish i could afford to go back to stock.
2004.5 Cummins, stock tune,5" turbo back exhaust, BW T4 turbo, Turbosmart WG, ARP Studs,built 48RE, BD flowmax lift pump and sump with h2o separator,
dsldude is offline
post #14 of 17 (permalink) Old 04-16-2019, 08:18 PM
02smokin's Avatar
If your still running stock tuning that is most of your problem
06 4dr LB Laramie,dynamic stg 4,64.5/73/.91,steed speed,anarchy EFi,Fleece bypass,ARP 425ís,insight,pac brake,6" Carli,long arms, king 2.5's,WFO traction bars,35ís
Sold trucks, 99,02,05,07,14
02smokin is online now
post #15 of 17 (permalink) Old 04-16-2019, 08:37 PM Thread Starter
dsldude's Avatar
Originally Posted by steelhead1 View Post
What's your MAX measured boost?
can try increasing Torque management.
at that altitude, only choices are go to stock OEM new factory Bosch injectors with the VCO nozzles and put the CAT back on.
or
Compound turbos
and tune for altitude.
I've pulled at over 11,000 ft with compounds 20,000+ GVCW, NO smoke even hammering it. Over 14,000 with rig alone, no smoke
Black smoke is wasted fuel and wasted HP.
Look for diesel to hit $4.50 a gal this fall. Saudis and Russian oligarchs are starving.
What would you change on tq management? I am usually around 34psi max boost can get closer to 40 at sea level. No boost leaks.
dsldude is offline
post #16 of 17 (permalink) Old 04-16-2019, 08:39 PM Thread Starter
dsldude's Avatar
You need some custom tuning brotha, that would help a lot with spool. A good tow tune for your elevation will help a lot
Tried that. No luck. Nobody can tune around my setup and elevation apparently.
dsldude is offline
post #17 of 17 (permalink) Old 04-16-2019, 10:45 PM Thread Starter
dsldude's Avatar
Just bought a used set of injectors for cheap. Gonna try them and compare.
dsldude is offline
Similar Threads
torque converter lock up switch Scott24x 98.5-02 Powertrain 16 03-03-2017 01:12 PM
Torque Converter Lock-up Switch 24v Blowin' Smoke 98.5-02 Powertrain 5 01-25-2016 10:52 AM
Dreaded torque converter playing lock unlock at 45 mph jonwalden68 98.5-02 Powertrain 19 08-22-2013 10:41 PM
does anyone know how to do a torque converter lock up switch? kylecummins89 94-98 Powertrain 4 08-13-2012 10:47 AM
Torque Converter Lock Switch went Not as Planned Please HELP! 98.5WhiteCummins 98.5-02 Non-Powertrain 0 10-23-2011 05:22 PM
