Cant get my wheel hubs off. HELP! (Video) - Dodge Cummins Diesel Forum
 19Likes
post #1 of 37 (permalink) Old 04-03-2019, 08:44 PM Thread Starter
One of my bearings and both U joints on the front axle are shot on my 2004 2500 Diesel 6Spd. I found this video on how to get at the U joints and he ran into the same problem I am having. My wheel bearing unit is not coming off the axle. When pounding the hub, my bearing is starting to come apart instead of coming out as a single unit. Pounding partly threaded bolts from the back isnt working either!
Here is the instruction video:
https://youtu.be/Hl5v2l_7xJ4?t=156
Here is my video of what is happening with my truck. Short of taking a Plasma Cutter to this thing, what the hell can I do??
https://youtu.be/bv5hGuNnXuE
I'm currently trying to hit it with a torch, but that's not doing anything...
Tyson031781 is offline
post #2 of 37 (permalink) Old 04-03-2019, 10:55 PM
rayvin433's Avatar
Use a 27-32mm socket placed between the ear of stub shaft axle u joint oriented horizontally & the axle housing.
With the truck running, have a friend turn the steering wheel to use power steering to hydraulically press it out. Work it back & forth. Have friend crank on steering wheel hard. Might have to give it some hammer blows while applying pressure.
rayvin433 is offline
post #3 of 37 (permalink) Old 04-03-2019, 11:17 PM
Gator1's Avatar
Cutting torch and dynamite...Stand back and watch the show!
Jimmy N. likes this.
03 QCLB- 19 to 25 mpg with electric parts, and engine mods....
Gator1 is offline
post #4 of 37 (permalink) Old 04-03-2019, 11:34 PM
OR-RAM's Avatar
What Rayvin said. That method has worked for me on my 2nd and 3rd gens. The hubs are a pain!
2004.5 QCLB Laramie Sport 4x4 NV5600
OR-RAM is offline
post #5 of 37 (permalink) Old 04-03-2019, 11:46 PM
Gator1's Avatar
When you do finally get it off put some real truck hubs on instead of those failure prone unit bearings.
rghavana and Jimmy N. like this.
Gator1 is offline
post #6 of 37 (permalink) Old 04-04-2019, 12:01 AM Thread Starter
Someone on FB suggested manual locker hubs. Although I dig the idea on some level, losing in-cab switching sounds like a downgrade. Also, the hubs on Amazon were like $1700!! Which sounds outrageously expensive for what you get.
Again, links to "rear truck hubs" would help your argument.
post #7 of 37 (permalink) Old 04-04-2019, 02:27 AM
Gator1's Avatar
https://www.amazon.com/Yukon-Gear-YA.../dp/B0078U9ZEM
I can engage my locking hubs while I drive... and $1700 is pretty cheap for a part that won't fail, leaving you stranded, or dead...
Gator1 is offline
post #8 of 37 (permalink) Old 04-04-2019, 03:00 AM
Just dropped Dynaloc hubs on. Amazing. If I anticipate snowy or icy conditions, if I want, I can lock the hubs and drive around with the front axle live but not engaged to the transfer case like Dodge designed (which is stupid as it wears out the driveline and creates quite a bit of drag), and then switch to 4wd in the cab with the dial. When I don't anticipate needing 4wd, unlock hubs and enjoy easier steering and much better (at least for me) fuel mileage. Plus, beefy bearings that won't fail. I've had two unit-bearings fail on me a a couple year period. Not worth it. Do it once, do it right.
Gator1 and Jimmy N. like this.
'07 Mega, 3" DOR lift, Synergy steering, Carli track bar, 37x13.5 Nittos, 5x30" FTE, 4.30 Nitros/e-locker, Throttle-Up fuel filtration, BBI Stage 1 injectors, DSoT driveshaft, DynaLoc hubs, money pit, tuned by Les Szmidt (Silver Bullet).
super_kev is offline
post #9 of 37 (permalink) Old 04-04-2019, 08:04 AM
rghavana's Avatar
Rent , Buy, borrow or make a puller.
I used OTC 7901 Front Hub Puller for 4WD Vehicles
https://www.otctools.com/products/fr...4wd-vehicles-0
cheaper then replacing steering components when you damage them, using it as press
04 QCSB HO Automatic
rghavana is offline
post #10 of 37 (permalink) Old 04-04-2019, 12:13 PM
TeamDoty's Avatar
The hub puller is a good idea but I think the issue is that the puller puts outward force on the wheel mounting surface by bolting onto the lug nut studs. This would continue to pull his unit bearing apart. But it's no big deal if you pull that unit bearing in two... heck it opens up a little room for you to work
This guy too had a LOT of problems getting that hub assembly off:
He eventually gets it with lots of hammering of chisels into the interface between knuckle and hub.
If you do use heat, heat the knuckle portion as it surrounds the hub and when it expands it should increase the diameter loosening it's grip on the hub.
Heat, impact/hammering and chiseling are probably your best options at this point.
When you do get it done and put it back together... anti-sieze my friend... lots of anti-sieze.
I just replaced my u-joints this past weekend and practically pulled everything off by hand after unbolting. My truck goes offroad quite a bit and those parts are often under water + all the bad conditions winter throws at it in the midwest. I anti-sieze everything like this and it really makes a difference the next time you have to work on it.
Sincere good luck to you friend!
Gator1 likes this.
2005 3500 SLT 4x4|4" Ex.|Cooper STT Pro 315/70R17|HellBent 2" Lvl|Synergy Adj Track Bar/Steering System|Thuren Shocks|MOPAR 1pc Driveshaft/Big Steering Box|Carli Ball Joints/Control Arms/Diff' Guard|Banks High-Ram Intake|Maverick Ranch Bumper #12K Winch
TeamDoty is offline
post #11 of 37 (permalink) Old 04-04-2019, 09:49 PM Thread Starter
Yes, that puller would just spilt my hubs. I put a 6t puller on and tried the steering trick. It took two people, but we got it! On the second one, my 6T puller exploded! What an absolute nightmare!!
As the second axle came out, I walked over to the laptop and placed the $1700 order for the manual hubs.
Terrible OEM design all around!!
Now I'm ripping into my rear end and have questions there, but will put into it's own thread under non-powertrain.
Thank you all for the help and support!
Gator1 likes this.
post #12 of 37 (permalink) Old 04-04-2019, 10:15 PM
Gator1's Avatar
You'll be so glad you did once you get it changed over!
Gator1 is offline
Similar Threads
Ram 5th Wheel Adapter - Movement/Clunk Due to Loose Nuts MoreTorque 2013-2018 General Discussion 16 10-12-2016 07:59 PM
Twin Guys Get In Here Chuck Norris 3rd Gen. Performance Parts Discussion 442 02-12-2016 08:50 PM
wheel hubs and brakes problem dirtwheelsfl 94-98 Non-Powertrain 0 12-16-2011 08:59 PM
Differentials: open vs limited slip v8440 89-93 Tech Articles 13 12-30-2007 02:55 AM
