HPT tuning experiment - Dodge Cummins Diesel Forum
 1Likes
  • 1 Post By flubyux2
post #1 of 7 (permalink) Old 04-21-2018, 07:21 PM Thread Starter
TECH SPECIALIST
steve05ram360's Avatar
Started retuning the truck today after all the changes recently. I feel there is some fuel economy left on the table and am going after it. I'd mentioned a while back that I'd use a fixed route at a fixed speed to see how a given change effected the performance. Since I look to the Calc Load values for guidance, I graphed 2 runs I did today.
1st run, existing tune that I've been running. I've had 2 tanks recently, 1 @ 22.2(? see signature) and 1 @ 21.99x mpg.
2nd run, reduced fuel pressure in the 8 fuel cells used during cruising (small change) and adjusted timing in only the cells that get hit at the MM3 range at the rpms that I get while cruising @ 60 mph. I plan to duplicate this effort again either early morning or late night with a higher speed, 65~67 mph. RE Timing... since I cut fuel, timing had to change. Also tweeked the pedal map.
Anyways, here is the graph. You can see where the 1st run exceeds the 2nd run load values. Couple of things come to mind when looking at it, with the load dropping on the 2nd run (modded tune), need to keep in mind that fuel pressure changed which may also affect the calc load value.
the graph represents the route taken, hilly for the most part with 1 or 2 flat spots...
cruise control handled the throttle set at 60 mph.
AFE PG7 drop in filter, AFE Torque Tube, HTT 2.5 turbo, AFE e-mani, ATS Arc Flo, 50HP DDP , 430k, HPTuners, G56, 25.065 mpg, mpg threads ->https://www.cumminsforum.com/forum/3...l#post23312562
steve05ram360 is offline
post #2 of 7 (permalink) Old 04-21-2018, 07:44 PM Thread Starter
TECH SPECIALIST
forgot to mention... in pulling the fuel back and changing the timing it appears to pull stronger when driving normal and using the changed area of the tune. This is purely a SOTP feel and could be a placebo effect.
post #3 of 7 (permalink) Old 04-27-2018, 03:53 AM
flubyux2's Avatar
What is your total fuel rate at that cruise speed?
My truck takes about 47-52mm to cruise.
I have my timing less than 10*. Around 7* for light cruise. Any more than that and it clatters pretty badly.
I just recently redid my timing using the udc calculator I found so it's at a 50/50 split from btdc/atdc. They say that split isn't perfect for every cell but that's what I ran with for now.
Comparing this tune to stock ecu and edge cts2 level 1, I'm +3mpg
59turbo likes this.
2006 3500 QcDrw, Laramie, 4wd, 8" on 22.5's and super singles, blow thru with 3x 12's, soundstream, MBrp 5", diy s&b intake, ejwa cts2 + hptuners, torque diesel s1 inj, fass hd150 & 8AN, WW2.
flubyux2 is offline
post #4 of 7 (permalink) Old 04-27-2018, 06:39 AM Thread Starter
TECH SPECIALIST
On the flats its 34-36mm3 iirc... Hmmm, maybe that might be worth graphing as well... I will have a look and get back on it, possibly tonite but most likely saturday afternoon.
I do know the load accumulators favor the current tune over the first tune when i started.
post #5 of 7 (permalink) Old 04-27-2018, 01:17 PM
flubyux2's Avatar
That's pretty good. You're truck is setup a lot differently I think. My truck is just a hog with a stock tirbo
flubyux2 is offline
post #6 of 7 (permalink) Old 04-27-2018, 02:30 PM Thread Starter
TECH SPECIALIST
yeah agreed... taking it back to stock height and lighter oem wheels has helped mpg a lot. that 22.207 mpg in the sig is the current high for 1 tank since switching to HPT.
post #7 of 7 (permalink) Old 04-18-2019, 05:04 PM Thread Starter
TECH SPECIALIST
And... bumping this one back up. This is where I started using the hilly hiway route to compare tune changes. This has proven to be an awesome way to verify a change, provided the change is done quickly and the route can be re-run under the same ambeint conditions...
Custom tuning... worth every minute of time spent.
