Front drive shaft still vibrating - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 11-11-2017, 05:39 PM Thread Starter
jps59cummins's Avatar
Ok I own an 03 Dodge 2500 5.9L cummins. My front drive shaft broke right at the yoke and it also cracked a weld at the shaft so I went on to rockauto.com and bought a reman front drive shaft. The install went great, went to drive it and everything seemed fine at low speeds until I reached 70mph then it started to vibrate so I figured it wasn?t balanced right so I sent it back and rockauto sent me another reman. I just installed it and it does the same thing, it vibrates from 68mph to 76mph. So I?m trying to figure out if this drive shaft is bad too or if something else on my truck is going out. Before I had the new drive shaft I had the old broken one off for about 3months and had no issues vibrating at any speed. Can anyone help shine some light on this issue?
03 Dodge 2500 5.9 Upgrades: Edge Jammer cold air intake, Edge CTS 2 Juiced w/ attitude, MBRP 5inch turbo back
jps59cummins is offline
post #2 of 8 (permalink) Old 11-11-2017, 06:24 PM
PWong's Avatar
Try reinstall the drive shaft 90 then 180 then 270 degree off with reference to the transfer case to see if it help.
Otherwise the shaft needs balance.
_________________
'05 2500 QC SLT SB 4X4 48RE Smarty Jr 205k miles
Baldwin FB1311 + Donaldson P551313 (3 Micron) + Baldwin PF7977
PWong is offline
post #3 of 8 (permalink) Old 11-12-2017, 02:42 AM
mhoward's Avatar
You sure it's not the rear driveline u joints that are bad? They will cause a vibration. When mine were bad, right at 70 mph is when I got a vibration.
Flame Red | 2005 | NV5600 | 4 Door | Long Bed | 4X4 | Big Horn Edition | 285/70/17 Toyo AT2 | GDP Big Line Kit w/ CAT Filter | Edge Insight CTS2 | Muffler Delete Pipe | Fast Transmission Cooler
mhoward is offline
post #4 of 8 (permalink) Old 11-12-2017, 04:07 AM
Supporting Vendors
Rhinopkc's Avatar
Do you have a lift? What is your caster set at?
Give Us a Call for All Your Suspension, Lighting, and Wheel Needs!
424.241.3252 x700 [email protected]
Check Us Out On Facebook!
Check Our Forum For The Latest in LED and Thuren Products"
Rhinopkc is offline
post #5 of 8 (permalink) Old 11-12-2017, 04:41 PM Thread Starter
Ok I will try that..I actually looked up some front drive shaft installations on YouTube and I guess there?s a certain way to align it. So I sounds like this might be the issue.
post #6 of 8 (permalink) Old 11-12-2017, 04:44 PM Thread Starter
No rear u joints bad. When I had no front drive shaft there was no vibration.
No lift, not sure what the casters are set at.
post #7 of 8 (permalink) Old 11-12-2017, 06:47 PM
Rotate as mentioned , but shanking a drive shaft is violent and may have tweaked one of the yokes ? But I'd think a tweaked yoke would vibrate all the time , just thinking out loud ...
SOLD My 2001 and 2005 .
SOLD 2004.5 Sons mod truck
24hrsparkey is online now
post #8 of 8 (permalink) Old 11-12-2017, 07:53 PM
find a local driveline shop. have it checked.
04 QCLB. 48re, 4x4
95 12v #8 plate, 5 spd
Killer223 is offline
