Looking for advice for friend w/ 06 - Dodge Cummins Diesel Forum
 25Likes
post #1 of 64 (permalink) Old 10-21-2016, 06:08 PM Thread Starter
Fireman02's Avatar
A friend of mine recently picked up a 06 2500 w/ 77k on it. My experience is with 2012 & current 2014 2500 so I'm thinking things are similar, with a few differences that I'm unaware of. I'm trying to give him some general suggestions, change oil, fuel, & air filters. I've suggested fleetguard filters. Also said it'd probably be a good idea to change diff fluids, trans, transfer case, and coolant due too the age of the truck. Steering was surprisingly tight, so I'm thinking the front end components are ok for now. Anything else anyone would suggest or advise against I'm all ears. Thanks
Edit 10/27
His belt is fraying, I detailed a little about it below. Any suggestions
fyredawg likes this.
2014 Black Big Horn 4x4 Auto ccsb Hpp Efi
2012 Silver ST 2500 4x4 auto ccsb, deleted sold
2013 Springdale 303bhssr, 03 Cobra 478hp & 488tq
Fireman02 is offline
post #2 of 64 (permalink) Old 10-21-2016, 07:27 PM
VP Moderator
dozer12216's Avatar
Check for rust and clean/treat as possible.
dozer12216 is offline
post #3 of 64 (permalink) Old 10-21-2016, 08:45 PM
CSC 5150's Avatar
Have him grab a Baldwin PF7977 fuel filter and drop that in right away, if he doesn't have an aftermarket lift pump.
Fluids are plentiful and many people use different brands. I personally run Amsoil but there are many other choices out there.
Like Dozer mentioned, check the rear wheel wells, door bottoms and other places for rust. Those are some of the most common areas on these trucks.
Here's a list from the Amsoil website on fluid types and capacities.
2006 DODGE TRUCKS RAM 2500 HD PICKUP
5.9L 6-cyl Engine Code [C] Turbo Diesel
Lubricants & Fluids
Engine Oil
Grade 1......CI-4
Premium 5W-40 Synthetic Diesel Oil (DEOQT)
SAE 15W-40 Heavy-Duty Diesel and Marine Oil (AMEQT) Above 0 F......15W-40
All TEMPS......5W-40 [1]
Manual Transmission,G56 (6-SPD)......AP4
All TEMPS......
Signature Series Multi-Vehicle Synthetic Automatic Transmission Fluid (ATF) (ATFQT)
OE Multi-Vehicle Synthetic Automatic Transmission Fluid (OTFQT)
Automatic Transmission,48RE......AP4
Automatic Transmission,545RFE 4WD......AP4
Automatic Transmission,545RFE RWD......AP4
Differential, Rear 10.5 RG AA EL......GL-5
All TEMPS......75W-90 [1]
SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
75W-90 Synthetic Long Life Gear Lube (FGRQT)
SEVERE GEAR 75W-110 Synthetic EP Lubricant (SVTQT)
SAE 80W-90 Synthetic Gear Lube (AGLQT)
Differential, Front C205FD......GL-5
Differential, Rear 11.5 AA W/ Open......GL-5
Differential, Rear 11.5 AA Trac-Rite......GL-5
Differential, Rear 10.5 RG AA......GL-5
Differential, Front 9.25 AA EL......GL-5
Differential, Front 9.25 AA......GL-5
Transfer Case,NV244 GENII......AP4
Transfer Case,NV273......AP4
Transfer Case,NV271......AP4
Transfer Case,NV241 GENII......AP4
Transfer Case,NV243......AP4
Fluids
Power Steering Fluid......AP4
OE Multi-Vehicle Synthetic Automatic Transmission Fluid (OTFQT) [2]
Brake Fluid......HB
AMSOIL Brake Fluid DOT-3 (BF3SN) [3]
Clutch Fluid......HB
[1] Synthetic based oil.
[2] ATF+4 Automatic Transmission Fluid, Mopar P/N
05013457AA, specification number MS9602
[3] Hydraulic Brake Fluid, DOT 3 P/N 04318080AC, meeting MS-4574
Filters
Oil Filter 25,000-Mile Ea Oil Filter (EAO80)
Oil Filter WIX 57620 Oil Filter [1]
Air Filter WIX 49946 Air Filter [2]
Air Filter WIX 42846 Air Filter [3]
Fuel Filter P550800 Fuel Filter
Transmission Filter WIX 58613 Auto Tran Filter
[1] Manufacturer OE Recommended Oil Change Intervals
[2] with 4 Inch Pleat
[3] with 2 Inch Pleat
Chassis Lubrication
RWD
6-9 Fittings, 0 Plugs..........LB
Synthetic Multi-Purpose Grease NLGI #2 GC/LB (GLC3P)
Synthetic Water Resistant Grease (GWR3P)
DOMINATOR Synthetic Racing Grease NLGI#2 GC/LB (GRGCR)
4WD
5-11 Fittings, 0 Plugs..........LB
Capacities
Engine, with filter..........12 quarts [1]
Cooling System, Initial Fill..........29.6 quarts
Passenger Car & Light Truck Antifreeze & Coolant
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 48RE Initial Fill..........4 quarts
Automatic Transmission, 545RFE RWD Initial Fill..........5.5 quarts
Automatic Transmission, 545RFE 4WD Initial Fill..........6.6 quarts
Automatic Transmission, Total Fill
4 speed 48RE..........16.9 quarts
5 speed 545RFE RWD..........16.9 quarts
5 speed 545RFE 4WD..........16.9 quarts
Manual Transmission, G56 (6-SPD)..........11.8 pints
Differential, 9.25 AA Front..........4.6 pints
Differential, 9.25 AA EL Front..........4.2 pints
Differential, C205FD Front..........3.4 pints
Differential, 10.5 RingGear AA Rear..........5.3 pints
Differential, 10.5 RingGear AA EL Rear..........5.3 pints
Differential, 11.5 AA With Open Rear..........8.9 pints
Differential, 11.5 AA Trac-Rite Rear..........8.5 pints
Transfer Case, NV271..........4 pints
Transfer Case, NV273..........4 pints
Transfer Case, NV241 GENII..........3.4 pints
Transfer Case, NV243..........3.4 pints
Transfer Case, NV244 GENII..........3.4 pints
[1] After refill check oil level.
Torques
Oil Drain Plug.....37 ft/lbs
Manual Transmission G56
Fill Plug 42 ft/lbs
Drain Plug 42 ft/lbs
Manual Transmission T56
Fill Plug 20 ft/lbs
Drain Plug 28 ft/lbs
Transfer Case
Fill Plug 15-25 ft/lbs
Drain Plug 15-25 ft/lbs
MAR524AK and fyredawg like this.
'14 2500 Laramie, 4x4, CCSB, Leveled, 35ís, Edge JWA, AFE CAI,
CSC 5150 is offline
post #4 of 64 (permalink) Old 10-23-2016, 07:40 AM
texasgreg's Avatar
The power steering pump also runs the power brakes, so changing the PS fluid is another one that needs to be changed now and then.
https://www.cumminsforum.com/forum/3r...h-3rd-gen.html
2006 2500 Quad Cab 4x4, Short Bed, Auto w/Floor Shift, 3.73, CAT fuel filter kit, DPS Artic Air intake, Rancho 5000's, Mopar steering upgrade, Transgo shift kit, Smarty Touch w/EGT, Thuren 2" soft ride coils, Warn front bumper with Warn M12000 winch.
texasgreg is online now
post #5 of 64 (permalink) Old 10-23-2016, 08:50 PM
MAR524AK's Avatar
Fleet guard are good filters! Looks like you have everything covered as far as maintaining it right off. Any upgrades?
MAR524AK is offline
post #6 of 64 (permalink) Old 10-27-2016, 03:56 PM Thread Starter
Fireman02's Avatar
So we installed a heater block cord and changed fuel filter yesterday on his truck. When he fired it up to make sure there were no leaks, after a few minutes of idling we heard a intermittent squeal sound and noticed his belt was fraying. Right after he bought it he replaced the belt because it was a little frayed. It's fraying closer to the engine side of the belt. He ordered a new tensioner and belt, but noticed today that the a/c compressor pulley randomly doesn't spin. Is this a common thing that fails on these.
post #7 of 64 (permalink) Old 10-27-2016, 05:17 PM
MAR524AK's Avatar
Yes they are. I've done all mine on my 06. 135k miles
MAR524AK is offline
post #8 of 64 (permalink) Old 10-27-2016, 07:02 PM Thread Starter
Fireman02's Avatar
So you've replaced all the pulleys or parts associated with the serpentine belt setup? My buddy had also bought a water pump to have a spare, but is planning on changing that while he's in there fixing the other stuff.
post #9 of 64 (permalink) Old 10-27-2016, 07:14 PM
MAR524AK's Avatar
Almost all of them yea. Just come apart. Luckily I've caught them before they left me stranded
MAR524AK is offline
post #10 of 64 (permalink) Old 10-27-2016, 07:31 PM Thread Starter
Fireman02's Avatar
Ok I'm sure he's planning to check the rest of the stuff up front once the belt is off.
post #11 of 64 (permalink) Old 10-27-2016, 09:50 PM
MAR524AK's Avatar
While he is there just replace them. If they still good keep as spare. Buy another belt for spare.
MAR524AK is offline
post #12 of 64 (permalink) Old 10-27-2016, 09:53 PM
MAR524AK's Avatar
Edit 10/27
This is a great belt! Genos garage is a vendor on Igotacummins forum. They have pretty good products. Check their website out!
MAR524AK is offline
