NV271 transfer case position switch installation - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 09-09-2016, 11:43 AM Thread Starter
flainn's Avatar
Hi folks,
My transfer case (a NV/NP-271D) didn't come with a position switch, for some reason. The computer has had a code saying there's an issue with the transfer case since I got the truck, and the wire header to connect to the transfer case has just been dangling.
Well, also, the transfer case has been leaking since I got the truck, and I finally got around to both ordering a position switch (Airtex 1S4129) and taking the case off the truck.
After cleaning the case completely, I discovered that although there is a hole for the position switch, just as there should be, there seems to be a metal plug at the bottom of the hole. It seems as if the hole was never drilled completely through to the interior of the case, and the hole also is not threaded.
I'm wondering if anyone has encountered this with what is probably a reman transfer case, and how to fix it. I suppose I could completely dismantle, drill out and tap the hole, but before I do I figured I'd see if anyone has seen this before.
03 Ram 2500 SLT QCLB | 5.9 HO | 4x4 | NV5600 / NV271 | PacBrake | 210k
flainn is offline
post #2 of 4 (permalink) Old 09-12-2016, 10:09 AM Thread Starter
flainn's Avatar
Well, after three days and nearly 300 thread views, not a single reply. I guess no one else has ever seen this.
I couldn't buy the correct size of tap locally, so I decided to skip it. Maybe I'll fix it in the future.
flainn is offline
post #3 of 4 (permalink) Old 09-12-2016, 03:07 PM
macko300exc's Avatar
I'd assume that the tcase is not the original and has been replaced. My nv271 has a sensor, but it is a 4wd indicator whether in high or low
macko300exc is offline
post #4 of 4 (permalink) Old 09-13-2016, 10:40 AM Thread Starter
flainn's Avatar
Yes, it's a reman. It's even got some mechanic's initials and a date written on the top in Sharpie
Yup, it's actually a five-position sensor -- it's kind of neat. I wish I could use it. Anyone want to buy one?
flainn is offline
