48re issues - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 09-26-2015, 09:32 PM Thread Starter
48re issues
The truck in my sig i got abou 2 months ago, i just replaced the turbo and got the truck on the road. It was built by the previous owner. When you take off it shifts very quick out of first, it goes right to 3rd gear. It does not slip or flare or anything, you think it makes a clean 1-2 shift but then realize its a really long gear. If you manually shift it, the 1-2 shift is perfect, then it will have a 200 rpm flare from 2-3. Then the 3-4 is fine and lockup is good too. Its supposed to have a goerend VB. Tomorrow morning I am going to pull the pan, but looking to see if anyone knows what i should be looking for. I have no clue if it has billet servos or accumulators in the trans. I was thinking about trying a front band adjustment first. Someone mentioned to me it might have a leak in the 2nd gear servo and that 2nd gear works because holding it in manual 2 will have more pressure. Can anyone confirm? Thanks in advance
2005 ccsb - 100% injectors, 10mm cp3, s366, 6.7 mega rail
qssc is offline
post #2 of 5 (permalink) Old 09-26-2015, 10:20 PM
VP Moderator
dozer12216's Avatar
Do a external band adjustment first. YouTube and the technical library located below, if you stroll down through the forum page.
dozer12216 is offline
post #3 of 5 (permalink) Old 09-26-2015, 10:56 PM
rgsauger's Avatar
Go here for your factory service manual, get the ATSG manual, and the trans doc. It's all free. Good luck
https://www.dropbox.com/sh/81mtpw6h2...dZOLxp5ja?dl=0
06 Mega 4WD,Transgo, 329K miles, 2" TopGunz kit,4.11, H-2 wheels,35/12.50/17E BFG's, Flashpaq, K&N, B&W goose, dual shocks at each corner up front, steering box brace, and a bigass dent in the tailgate because my wife just had to back the trailer...
rgsauger is offline
post #4 of 5 (permalink) Old 09-27-2015, 09:04 AM Thread Starter
I had planned on doing a band adjustement today, but just seeing if anyone had any other thoughts.
qssc is offline
post #5 of 5 (permalink) Old 09-28-2015, 01:38 PM
Could be high governor pressure due to the higher pressure valve body blowing through the solenoid, could be low throttle pressure from a worn out valve or low spring pressure. Getting a pressure reading from the governor port and accumulator port will give you an idea of where you're at.
2005 QCLB 4x4, Edge, Fass 150, Beans Sump, Billet 48re, NO Trans heat exchanger!
Fuelie is offline
