Rear main question - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 04-11-2014, 05:25 AM Thread Starter
Rear main question
How deeply should the rear main seal be set into the seal carrier. I know that there is an installation tool that comes with the fel pro gasket. The one that I took out was about the depth of the bevel, maybe about 1/8th inch. If I use the install tool with the high side out it wont even set the seal flush. If I use the tool with the high side in it sets the seal about 1/4 inch and the instructions say if the crank is grooved to set the seal about 1/8th inch deeper. so my question is where does the thing belong. thnx.
06 Ram 3500 4x4 6 spd AFE CAI, EDGE Juice w/ Attitude CTS 31104, 305 / 55 / 20, No Lift, Phoenix stage 4 sd clutch, Road Armor bumper
Frieslander is offline
post #2 of 6 (permalink) Old 04-11-2014, 10:37 AM
Benyo's Avatar
I just kept testing the depth, did you remove just the seal ? or the whole seal housing ?
06 Auto single cab long bed stockish
08 G56A Maga cab- Deleted/Anarchy reverse leveled
12 68RFE Mega cab- Deleted/smarty jr.
Benyo is offline
post #3 of 6 (permalink) Old 04-11-2014, 02:00 PM Thread Starter
just the seal
just the seal. I suppose it would help if I knew which side of the installation tool to use.
post #4 of 6 (permalink) Old 04-11-2014, 03:39 PM
Benyo's Avatar
If your not to deep into it yet , I would pull the whole seal housing out , it's the 8 bolts that hold the seal in , and replace it that way , then when you think you have the right depth you can fit it up and check the wear marks from the old seal !
Texting and driving ? Please officer cummins forum and driving ! ......... Have a nice day !
Benyo is offline
post #5 of 6 (permalink) Old 04-12-2014, 01:29 AM
destroked04's Avatar
Go to Advance Auto and buy their kit its $20 and comes with the installation tool.
2004.5 3500 SRW, NV5600, 5in Turbo-back MBRP, Silencer ring removed, S&B Intake, BD Exhaust Manifold, AFE Intake Manifold, Airdog II 165, 2" Thuren Coils, Smarty S06 POD, South Bend DD 3250, Edge Insight CTS, Bilstein 5100s
destroked04 is offline
post #6 of 6 (permalink) Old 04-12-2014, 09:33 AM
macko300exc's Avatar
I always set my seals to stick a tiny bit over the crank. Then when I install the flywheel or flexplate let it push it flush. I bite my self in the arse one day when working on a international with a dt, push the seal in a little to far and a month later it needed a intranet I couldn't get the number 7 main bearing out due to the seal being in to far.
macko300exc is offline
