3rd gen smoke switch - Page 61 - Dodge Cummins Diesel Forum
post #721 of 843 (permalink) Old 10-14-2010, 04:56 PM
cummins04's Avatar
worked just fine in 2 years. but good point to add
04.5 QCSB Billet auto,15k HIDs, 325/18s powdercoated black, airlift airbags
SOLD 95,12V rcLB, 300k miles
2010 VW jetta 6sp TDI
cummins04 is offline
post #722 of 843 (permalink) Old 10-14-2010, 10:59 PM
HI! Im Taylor! Let me help you with that ;)
CumminsPower412's Avatar
yeah im not criticizing you. its just up here in PA we get a lot of salt put down on the roads in the winter and unless you have connections tight they corrode instantly. but of course even shrinktube connections arnt perfect either. im sure youll be fine
2003-2005 R title Ram 2500 6spd 4x4 / Southbend / Isspro / Motosport Diesel / MBRP / Airdog
The early bird may get the worm, but the second mouse gets the cheese
CumminsPower412 is offline
post #723 of 843 (permalink) Old 10-15-2010, 12:24 AM
cummins04's Avatar
i plow with my truck and plenty of moisture is there, ill redo mine one day when i get time but thinkin ill use silicone and then heat shrink it for better appearance.
post #724 of 843 (permalink) Old 10-17-2010, 05:06 PM
It's is located on the driverside of the engine, right next to the fuel rail. It is held in by two star head screws.
05cummapart is offline
post #725 of 843 (permalink) Old 10-17-2010, 06:16 PM
I have posted a few times and you guys are prolly ready to kill me but my switch wont make my truck smoke like your results. My truck just gets slow. Very slow. No smoke. And I did It just as many directions I have read on here. Toggle my Pin c to one side of my toggle and pin d to the other side. And my resistor I'm there somewhere don't member where. Please help. What did I do wrong? Does resistor positioning matter?
post #726 of 843 (permalink) Old 10-17-2010, 08:21 PM
cummins04's Avatar
my resistor is 3-4 inches from my switch, make sure it is on the C wire, and do you have the resistor that i posted before?
post #727 of 843 (permalink) Old 10-17-2010, 08:25 PM
Yes 10 ohm 10 amp
post #728 of 843 (permalink) Old 10-17-2010, 09:32 PM
Nothin but a Cummins's Avatar
i did mine excatly like cummins04 and it worked perfectly! I think I still have the diagram...
2006 Mega Cab 5.9L/ bd 48re/ efi live/ Pure Performance/carli/ bilstein/ thuren/ k&n/ mbrp/ bullydog/37x13.50x20 toyo mt/ train horns
Nothin but a Cummins is offline
post #729 of 843 (permalink) Old 10-17-2010, 10:06 PM
Helpful but believe thats what I have. Except I only have two prong toggle switch.
post #730 of 843 (permalink) Old 10-18-2010, 09:37 AM
ummm...the two prong toggle is the way to go. How did you splice into the map sensor??
post #731 of 843 (permalink) Old 10-18-2010, 06:29 PM
Just used quick spices simialar to the t spices. And I know there hooked up because I tried takong out the resistor and it instantly threw a code.
post #732 of 843 (permalink) Old 10-18-2010, 06:44 PM
no sure exactly why it isn't working for you. Do you have a boost guage? if so start the truck flick the switch and see what boost your at. My truck shows Im at 30lbs of boost when I flick the switch
