Stock pitman arm flip? - Dodge Cummins Diesel Forum
 9Likes
  • 1 Post By tryNto
  • 1 Post By krashDH
  • 3 Post By 24hrsparkey
  • 2 Post By tryNto
  • 1 Post By Danderson
  • 1 Post By Smoksho
post #1 of 12 (permalink) Old 03-23-2020, 01:36 AM Thread Starter
cumminORnot's Avatar
Hey guys, so I did a 2ish+” lift on the front. Getting the shakes now at 60+ When I hit a bump. I have gotten the death wobble a couple times too. And it appears the drag link is at a pretty good angle. So my question is, has anyone flipped the stock pitman arm so you can mount the drag link on the backside? Or is the hole that connects to the steering box a one way as well?
Ps I installed dual RC steering stabilizer and upgraded steering linkage.
2004 RAM 3500 DAILY DRIVEN!! STRAIGHT PIPE 4", CUSTOM COLD AIR, SMARTY TOUCH, SOUTH BEND DOUBLE DISC...
cumminORnot is offline
post #2 of 12 (permalink) Old 03-23-2020, 02:45 AM
Trying to learn
tryNto's Avatar
With a search in the google box for "DW after lift install" = about 200 hits.
I'm guessing your answer is there > https://www.cumminsforum.com/forum/g...lift%20install
rghavana likes this.
'03 QCLB 2500 305/555 NV5600 w/ FastCoolers 3.73 4x4, Color match Lear Topper.
Smarty S-06 PoD, Edge CTS for Gauges, DPP Cool Tube w/ OEM AF Box, Baldwin PF7977, GDP MK-2 FF Kit, Pusher Intake Horn, Adj. Boost Elbow @ 30psi, OEM Fan Clutch Delete/Mod, Steering Box Brace, On-Board Air w/Horns
tryNto is offline
post #3 of 12 (permalink) Old 03-23-2020, 05:17 AM Thread Starter
I asked about the pitman arm. Not how to fix my dw. Iím trying to think outside the box. Thereís a reason why you have to do a pitman arm drop with a 3 inch lift correct? Usually because of an aggressive drag link angle. Which in my mind causes less stabilization.
This is something Iíve been dealing with for a couple weeks. Iíve done my searches and if you notice thereís no clear answer. My ball joints are good, everything is tight. Iíve done an alignment.
post #4 of 12 (permalink) Old 03-23-2020, 06:50 AM
krashDH's Avatar
Originally Posted by cumminORnot View Post
I asked about the pitman arm. Not how to fix my dw. I’m trying to think outside the box. There’s a reason why you have to do a pitman arm drop with a 3 inch lift correct? Usually because of an aggressive drag link angle. Which in my mind causes less stabilization.
This is something I’ve been dealing with for a couple weeks. I’ve done my searches and if you notice there’s no clear answer. My ball joints are good, everything is tight. I’ve done an alignment.
I've been running a stock pitman arm, 3" level, no drop, no issues in steering.
Your issue lies elsewhere.
tryNto likes this.
2004.5 2500 QCSB 6sp 4x4.Exhaust,Isspro EV2 gauges,SB DD3250-6,intake, Pac Brake, BD 2-piece manifold,leveled,custom front/rear bumpers,Smarty S06 POD,Chevy tow mirror conversion, projector retrofit w/ switchback turns, SRT-10 Hurst shifter,BD short shifter kit,Filters
krashDH is online now
post #5 of 12 (permalink) Old 03-23-2020, 09:37 AM
What brand lift and what kind of arms came with it ?
no , You cannot flip the pitman arm. Any pitman arm.
It is debatable if you need a "drop" pitman arm with the 3" lift . See below.
Adjustable Track Bar Drop bracket and upgrade very possible. and expensive. I dont know where you are at concerning the track bar unless i missed it but With oem trackbar and 3" lift the differential will be way way off center . And an issue .
The Track Bar AND main steering arm/bar MUST be just about at the same angle to operate properly . This is fact.
How you get there is up to you.
tryNto, rghavana and Jimmy N. like this.
SOLD My 2001 and 2005 .
SOLD 2004.5 Sons mod truck
24hrsparkey is offline
post #6 of 12 (permalink) Old 03-25-2020, 12:52 AM
hi-boost's Avatar
Hey guys, so I did a 2ish+Ē lift on the front. Getting the shakes now at 60+ When I hit a bump. I have gotten the death wobble a couple times too. And it appears the drag link is at a pretty good angle. So my question is, has anyone flipped the stock pitman arm so you can mount the drag link on the backside? Or is the hole that connects to the steering box a one way as well?
The sector shaft is tappered. So flipping the pitman arm will not work,...cuz it has a taper as well. Also the link end is tapered where it mounts through the pitman arm
06 Big Horn Edition 2500 SLT,HD,5.9L,4X4,QC,SB,48RE,3:73,5" MagnaFlow/6" tip,BDTDPP V2.4.3,Quad BF,moded stk airbox w/Cool hose,Pwr-Flow,Defiant,Thuren,6"lift,Carli,35x12.5-17 Ridge Grappler,bagofparts,EBC,MK-2,Warn,Viper16.5T w/syn line,free spin hubs
hi-boost is offline
post #7 of 12 (permalink) Old 03-25-2020, 03:14 AM
xXxSilveradoxXx's Avatar
I've got a 3" Long Travel setup on my truck with a stock pitman arm. I haven't had any adverse affects. Personally, with these trucks, I've found that DW is usually caused by something being worn out on the front end.
2004.5 Dodge Ram 2500 CTD QCSB
Thuren Long Arms, King 3.0s/2.5s, 37"s, 4.10s, Exergy 100%s, 10mm CP3, Fuel Boss, Smarty S06, GT3788R w/ 0.89 A/R, Garmon SR96, Cool Hose/AMS/Whistler, Banks 4" TBE
xXxSilveradoxXx is offline
post #8 of 12 (permalink) Old 03-25-2020, 05:18 PM
Trying to learn
tryNto's Avatar
Apparently he doesn't care about the DW.
rghavana and krashDH like this.
tryNto is offline
post #9 of 12 (permalink) Old 03-26-2020, 11:30 AM
GloNDark's Avatar
Did you adjust your caster after you put your 2" level on it? Are you still running the old Y-Style steering linkage?
I've got a 3" Thuren setup on my truck with a stock pitman arm and have zero shakes or death wobble.
From my experience, caster and alignment is almost always the cause of death wobble on these trucks. Check out Don Thuren's alignment specs write up, everyone with a Cummins truck should know this because normal alignment guys will not have a clue.
https://www.thurenfabrication.com/me..._ALIGNMENT.pdf
2006 Dodge 2500 Megacab - 5" exhaust, S&B intake, EFI live, 5" lift, 17" Raceline Clutch wheels, 37x12.50r17 Nitto Ridge Grapplers
GloNDark is offline
post #10 of 12 (permalink) Old 03-26-2020, 11:51 AM
Danderson's Avatar
Change out the pitman arm with the Mopar recommended unit when you do the upgraded suspension.
CJC should stock it and can offer knowlegeable assistance.
In addition be sure your running reputable tires in good balance.
'07 2500 SLT,5.9,Regcab.,G-56,4wd,Northstar TC800 popup 24/7. SBC OKHD. Dynatrac freespins and bj's. Synergy HD steering. Suspension mutt courtesy of Kore, Carli and Thuren.
Danderson is offline
post #11 of 12 (permalink) Old 03-26-2020, 09:25 PM
No, you can't flip the pitman arm, but you can find tapered inserts. Drill the end of pitman arm to required size press new insert in and tack weld and grind flat. I don't remember sizes but think the inserts are on Ebay.
Also the guys are giving some good advise on DW. When DW happens there is something worn out, balljoints, dropbar bushings, tie rods and so on. As asked prior do you have the y bar or newer improvement kit ?
Jimmy N. likes this.
07 3500 MegaCab 5.9,CAI,BMS 50hp inj,SpoolAid,AFE3.5" intake,AFE SS exh,Snow stage 3,smarty SSR UDC 4"lift,5"dual exhaust,HX40 Wicked Wheel,BD Triple disc,Billet shafts,BD stage 4,BD VB,DD pan,Fass150,8an line,Twin fuel filters,Traction bars.
Smoksho is offline
post #12 of 12 (permalink) Old 03-27-2020, 04:05 AM
Originally Posted by GloNDark View Post
...Are you still running the old Y-Style steering linkage?
Good call on the Y-Style steering, that completely slipped my mind.
