Upgrade to He351 or ? - Dodge Cummins Diesel Forum
 2Likes
post #1 of 43 (permalink) Old 02-17-2020, 12:06 AM Thread Starter
pathfinder82's Avatar
Wanting to upgrade my stock turbo and I know there are tons out there. I don't need nothing radical because I'm not going to be drag racing, just pulling RV 6-10 times a year but want more hp. I plan on staying with stock stick's until they give out then I'll put 50's in but for now just want a upgraded turbo and I hear that the He351 would be a good option but need info and advice, Thanks Bob
Early 04 QCLB 3/4 ton 4x4 Built 48re,Magtech Deep pan, AFE magnum flow, Cool Hose, Sinister Inner Cooler Pipes w/ Air Intake Elbow,Oil Bypass system, Stock 17's, 2" Level kit,Edge CS, Air bags ,Bilstein shocks, Cat Delete,4" Diamond Eye exhaust, 👍
pathfinder82 is offline
post #2 of 43 (permalink) Old 02-17-2020, 12:17 AM
4everlearning's Avatar
Is the stock turbo for the 305hp engines different from the 325hp engines?
2005 QCSB, cold air intake, guages, a trans built by me and HPTuners tunes by me
4everlearning is offline
post #3 of 43 (permalink) Old 02-17-2020, 12:49 AM
hydraulic lifter crew
elephantrider's Avatar
iTrader Score: 10 reviews
what year model truck do you have?
'19 2500 t'man
elephantrider is online now
post #4 of 43 (permalink) Old 02-17-2020, 01:03 AM Thread Starter
2004 Cali Special 235 out of Mexico ,built 10-2003
post #5 of 43 (permalink) Old 02-17-2020, 11:01 AM
GRUNT 11B's Avatar
The HE351 will be a nice little upgrade over the HE341. So you can either upgrade your turbo or upgrade your tuning. You'll gain more from upgrading your tuning.
06 QCLB 4X4 G56, SOUTHBEND DD, FASS 150, ARP STUDS, 50HP INJECTORS, EFI, HE351 S475 COMPOUNDS, FLUIDAMPR, HAMILTON PUSHRODS & 103# SPRINGS, 624 HP 1090 TQ 01 QCLB 4X4 AUTO, WHEELS, TIRES, STEERING WHEEL, CUMMINS, BUMPERS, FUEL TANK, SEATS, ETC.
GRUNT 11B is offline
post #6 of 43 (permalink) Old 02-17-2020, 11:22 AM Thread Starter
I'm running the Edge cs , when towing I have it on tow mode so would it be better then to upgrade turbo for more boost while towing since the tuner is already set for tow ?
post #7 of 43 (permalink) Old 02-17-2020, 12:17 PM
GRUNT 11B's Avatar
Going from box tunes (like edge) to custom tuning is a night and day difference. You gain more overall going to custom tuning vs swapping turbos. You can always install an HE351 and if you're still looking for more, then upgrade your tuning.
post #8 of 43 (permalink) Old 02-17-2020, 12:28 PM
StealthDiesel's Avatar
Yes..
The 2003-04 HE341 turbo is very small. Upgrading that to the larger 2004.5-2007 HE351 is an excellent upgrade.
It's a common upgrade that has been done by many since 2004.5! A search on this forum will bring up tons of info.
It will bolt in but there are few mods that you should do.
- Full 4" turbo elbow and exhaust. The 2003-04 trucks have a 3.5" exhaust, the 2004.5-07 trucks have a full 4.0" exhaust.
The HE341 has a 4" outlet but the turbo elbow necks down to 3.5". The HE351 has a full 4" elbow.
- The HE351 has the electric wastegate which the HE341 does not. You will need to convert the HE351 to a mechanical wastegate.
You will need the special wastegate plug for the HE351.
- Some kind of boost fooling. Your Edge likely does this already.
- If you still have the 2003 exhaust manifold, I would recommend to upgrade that at the same time. Even a new Cummins ex manifold is better.
Cummins redesigned the 2003+ ex manifold several times, adding more material every time to deal with cracking and warping.
I recommend to remove/install the ex manifold and turbo as a single assembly.
As Grunt mentioned, you should upgrade your Edge CS. You likely have high EGT's while towing.
Interceptor modules like the Edge are outdated and not that great.
An ECM programmer is much better. Unplug most of your Edge CS and use it as gauges and research ECM programmers.
An MM3 is well worth looking into.
Your sig states your auto trans is already upgraded.
The stock size injectors are totally fine. Even 50HP injectors will cause high EGT's when towing with the HE351 turbo.
I hope this info helps...
HE351 on the left. HE341 on the right.
Name:	HE351 vs HE341.jpg
2004.5 Dodge SB QC 2500 2wd Cummins 600/6spd manual/3.73 LSD
ATS 3K/5K Twin turbos. DDP 50HP tips, F1 valve springs, ARP headstuds.
SBC Dual disk 3250. Smarty. Glacier Diesel intake plate, air horn, fuel & filter system.
MBRP S.S. muffler. BD short shifter. Brakesmart tow controller.
BD exhaust brake. Pullrite 24k Superglide.
StealthDiesel is offline
The Following 2 Users Say Thank You to StealthDiesel For This Useful Post:
4everlearning (02-17-2020), jkidd (02-20-2020)
post #9 of 43 (permalink) Old 02-17-2020, 01:13 PM
Originally Posted by StealthDiesel View Post
Yes..
Great info! Iím a little surprised that I was not aware of the HE341. I thought 03-07 all had the HE351
post #10 of 43 (permalink) Old 02-17-2020, 01:29 PM Thread Starter
Yes..
Totally appreciate all the info, it's alot to figure out what to do first.
post #11 of 43 (permalink) Old 02-17-2020, 01:43 PM
BFD
BFD's Avatar
I didn't try the 351 on my 03 305 but going to a II PS 62/65/14 made a heck of an improvement... without any fueling yet. Then I eventually got a TST PMCR and it became a towing monster! I had a DS Predator for 5 years and I will say the 100hp/econ tune made a terrific tow tune... a little tq mngt. below 1500 to save the clutch or auto, very good top end and power curve. You can find them cheap. Craig
2012 CCLB 4wd dually,3.73,68rfe,Fass,BD IH and E-brake kits.2008 Sunnybrook30RKFS 5er.
If you take something apart and put it back together often enough, you will end up with two of them!
BFD is online now
post #12 of 43 (permalink) Old 02-17-2020, 04:42 PM
nosympathy's Avatar
If you get an HE351 the plugs are like $30-40 (so you can leave the reference line to the actuator open) and you can either get an adjustable wastegate actuator (stock is fixed to 22/23psi) or get a manual boost controller.
Both will honestly cost about the same ($100-130), but since the wastegate isn't really adjustable once installed with the 3rd gen manifolds, the boost controller is nice for dialing in what you want exactly or if you change your mind later.
You can find cheaper boost controllers but you usually get what you pay for. I think mine is from grimmspeed and it's been really nice.
I have an 05, but dumped the solenoid a while back and put in the plug and the boost controller. I have an AFE wastegate actuator set at 32psi but didn't want to pull it to change to 40psi when my solenoid died. So boost controller ftw!
05 CCLB 48RE
nosympathy is offline
