366, 369 or 467 - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 01-11-2020, 08:02 PM Thread Starter
jussmok3dout's Avatar
366, 369 or 467
Goal-800, mods bbi stage 2 injectors, fleece cp3k-will upgrade to 10mm exergy, studs, springs, pushrods, fass150, firepunk, 63/68/12 AGP, hptuners.
Is this a direct drop in replacement for a third gen not second gen? https://www.xtremediesel.com/bd-powe...91ar-turbo-kit
If so, it comes in sxe S366/80/.91 or 1.00, sxe s369/80/.91/1.00/1.1 which of those setups would be best? Not my daily, doesn’t tow hardly ever. Also looking at a stainless diesel s467
-David- 04 QCSB 4x4 Toyo MT 35x12.5x17, Firepunk Comp 1 built trans, Smarty UDC from Lavon @firepunk, Airaid, edge cs, 4in TBE, FASS 150, Fleece Cp3k, AGP 63/68/12
jussmok3dout is offline
post #2 of 8 (permalink) Old 01-12-2020, 05:17 AM
cattlepuncher's Avatar
I’d toss a 476/96/1.32 under it and let it eat. Probably spend $1500 more but would be an awesome setup and drive great. If you really wanna cheap out (might take a few years but you’ll probably wish you went twins) I’d do 66/73/.83 dual gated T4 off a 2nd gen manifold. Either route, I hope you have a stout transmission, head studs, springs, and pushrods.
Would not recommend the 73/80mm turbine with a .91 housing and definitely not 1.00. There are too many turbos with tighter hot sides than 73/.91 that are hitting high hp and you’re going to sacrifice response if you do it.
2006 QCSB 2500 4X4 67.7/83/.9, 2nd gen manifold, 60% overs, TRE Stage 1 trans, EFI Live
1998 QCSB 2500 4X4 12valve Sold and missed...
cattlepuncher is offline
post #3 of 8 (permalink) Old 01-12-2020, 04:58 PM Thread Starter
Yes I have all the supporting mods needed. Looking at a stainless diesel 2nd gen swap, would the s463 or s465 be enough for 800 or would I need the 467. Or as you mentioned should I get the manifold and piping kit and throw a different turbo on it that you might recommend?
post #4 of 8 (permalink) Old 01-12-2020, 11:16 PM
02smokin's Avatar
If your dead set on a single I’d go s369 2nd gen swapped
06 4dr,dynamic stg 4,64.5/73/.91,steed speed,anarchy EFi,DDP 150% overs,fleece dual cp3ís,Fleece bypass,Fass 165,ARP 425ís,Manton springs/pushrods,pac brake,6" Carli,long arms, king 2.5's,WFO traction bars,35ís
02smokin is offline
post #5 of 8 (permalink) Old 01-13-2020, 01:18 AM Thread Starter
Sent you a pm for help
post #6 of 8 (permalink) Old 01-13-2020, 08:01 PM Thread Starter
Ok I’m gonna go with the 467 more than likely unless you guys think the 369 is the better choice. If I go 467, is there any big benefit to spending 500$ more on a billet 5 wheel or will the regular wheel be fine?
post #7 of 8 (permalink) Old 01-14-2020, 12:02 PM
3 footin' through life
Broaner's Avatar
iTrader Score: 11 reviews
Depends which 467 you are talking about. Link it up. I thought they all had FMW's.
'05.5 6.7 Shotpeened NV5600 - 12.6 @ 111.6 - 994 HP & 1630 lbs/ft
150%'s, LBZ/Arson pumps, MHP +1mm, ZZFab, Wagler Rods, 69/73/1.0 & s482
1350 Frontshaft, TruTrac, 315's, 64" T-Bars,TGC 1/2"+, Carli BJ's, '08.5
Street Triple, 103#/Extreme Pushrods, 625's Broaner Gets Hooked
Broaner is offline
post #8 of 8 (permalink) Old 01-15-2020, 12:51 PM Thread Starter
Let the fun begin!
The Following User Says Thank You to jussmok3dout For This Useful Post:
Broaner (Yesterday)
