Upgrading he351 in compounds - Dodge Cummins Diesel Forum
post #1 of 28 (permalink) Old 06-30-2019, 10:59 PM Thread Starter
99coalroller24V's Avatar
I currently have a stock/s475 compound setup.
I am looking to get in the sxe s300 frame turbo.
I want a good tow pig with minimal lag. The he351 done good but running to hot with my setup.
I'm also wanting to stick with a t3 housing considering my manifold is a BD SS t3.
My questions are :
S360 or s362? Pretty sure s360 but opinions
What size housings ( xx/xx/xx) ?
Would it need to be gated (I have a spring gate already ) ?
99coalroller24V is offline
post #2 of 28 (permalink) Old 07-01-2019, 02:25 PM
Diesel Auto Power
iTrader Score: 21 reviews
Length of housings are different from s300 and HE351cw.
Why not remove the he351cw and open up the wastegate port from 5/8 to1"
For faster response you could switch the common 1.32AR on the s475 (assuming the 96/88 wheel is on that turbo) and get a tighter 1.15AR for a better matched set up.
jkidd is offline
post #3 of 28 (permalink) Old 07-01-2019, 03:11 PM
TECH SPECIALIST
steve05ram360's Avatar
What about just upgrading the exhaust side of the HE351 with the turbo labs mod?
https://www.cumminsforum.com/forum/3...set-turbo.html
Their website sent me here...
https://www.ebay.com/itm/Holset-HE35...QAAOSwhnlb2efK
AFE PG7 drop in filter, AFE Torque Tube, HTT 2.5 turbo, AFE e-mani, ATS Arc Flo, 50HP DDP , 415k, HPTuners, G56, 25.065 mpg, mpg threads ->
steve05ram360 is offline
post #4 of 28 (permalink) Old 07-01-2019, 04:15 PM
Upgrading the exhaust side housing should be done in conjunction with the compressor side. Keep it even so to speak. And as luck would have it Turbo Lab and others do it the same way.
04.5 CC SB 4x4, Low stall converter, billet input, intermediate, and valve body mods. HPT tuned by Firepunk, FASS 150, BMS 50 injectors. Mechanical fan conversion with OEM plastic fan blades, Traction bars.
jballou is offline
post #5 of 28 (permalink) Old 07-01-2019, 09:19 PM Thread Starter
So the he351 is going to do just as good as a s360 if you open the exhuast housing up?
I have already drilled the wastegate port out to 1"
Honestly would like a clean compressor housing for the 351 and have it polished. Looks ugly sitting up there. Lol Idk where you could buy one at. Also jkidd would the 1.15 spool a lot faster than the 1.32
So basically keep the s475 with the 1.32 and add a s360
Or swap s475 to a 1.15 or 1.10 and keep the he351
Of swap s475 to a 1.15 or 1.10 and add a s360.
300 frame turbos look a lot cleaner to me and easier to adjust.
2006. AirdogII 4G165. Autometer Gauges. SB 3850. SXE S362/S475. EFI Live Vannest. ProComp coils/Bilstein shocks. BMS 50s. Fluidampr, GDP Ladder Bars, DAP #104 Springs, DAP .093 Pushrods, Haisley L19 Studs, BD SS Manifold, coolant bypass, DAP Sump, 5"TBE
post #6 of 28 (permalink) Old 07-03-2019, 05:13 PM
TheKid760's Avatar
Before you throw parts at it.
What overall boost, whatís the primary alone making? Any boost leaks etc. rule out other causes before jumping straight to parts.
But I would start with the 1.15 housing and see what it does then next step do the he351cw turbine upgrade. Then if thatís still not enough then consider a new secondary.
95 3500 4x4 5spd 4.10 - SuperB/GTA4202 Build, Colt stage 4 Cam, Ported Head, 7mm DV, 7x.012, blah, blah...
TheKid760 is online now
post #7 of 28 (permalink) Old 07-03-2019, 08:38 PM Thread Starter
I will have to get numbers again. I already forgot lol.
Would going from the 1.32 to the 1.15 drop hp?
post #8 of 28 (permalink) Old 07-05-2019, 02:45 PM
Ducati M.
DMan1198's Avatar
No, because even with the smaller housing your primaries turbine can support well over 1000whp.
Jaeger-12 ram 3500, CCLB, 68rfe, 2" lift, 5" tbe, steed, s476, MM w/MCC, OD, ISSPRO factory match, ARP 625's, Hamilton 103's/extreme duties, T/Rex traction bars, mag hytec trans pan,
The Roo Hunter- 93 w250, g360, np205, 4" lift, custom 3/8" bumper, Hellman sump, raptor 100, dual filters, ddp stg 3's and pin, steed, modded hybrid wh1c/hx40/s467fmw compounds 4" tbe, autometer cobalt series.
The Huntress- 02 VW Jetta tdi, 5 speed, egr/muffler delete, 11mm ve, gt1749v, ISSPRO factory match.
click here for Instagram:
DMan1198 is offline
The Following User Says Thank You to DMan1198 For This Useful Post:
99coalroller24V (07-05-2019)
post #9 of 28 (permalink) Old 07-05-2019, 04:22 PM Thread Starter
I got some pressure measurements...
RPM @2000 70-mph
EGT 1100
Manifold Boost 4psi
Primary 4psi
This one was just cruising down the interstate up a little incline
RPM @2000 - 3100 70mph-100mph
EGT 1400
Manifold Boost 58
Primary 36
This was EFI cranked up, 6th gear, and getting on it
post #10 of 28 (permalink) Old 07-05-2019, 07:58 PM
TheKid760's Avatar
Where are you measuring your primary boost at?
Because it has to be calculated from secondary boost, overall boost and atmospheric pressure.
What elevation are you at?
Edit, some rough math:
I assume you meant secondary boost (the he351cw). Assuming that and sea level elevation;
Your secondary is making 36psig or 3.45 PR
With your overall boost at 58psig or 4.95 PR that puts your primary (S475) at only a 1.43 PR or 6.3psig.
Your secondary ainít doing . If those assumptions are correct or close then I would start with the tighter housing.
post #11 of 28 (permalink) Old 07-05-2019, 08:40 PM Thread Starter
My boost gauges are in the cold pipe between the 475 amd the 351 the other is in intake manifold
Correct me if I'm wrong but the air goes into the 475 first then up to the he351 on the cold pipe. And that is where I was reading the 36psi. My 351 goes straight to the CAC
post #12 of 28 (permalink) Old 07-06-2019, 12:02 AM
If your numbers are correct that means your he351 is only putting out 22# of boost. Have you tried adjusting the wastegate on the he351? I have a very similar setup to yours just installed and starting to work on the tuning. I donít remember the exact numbers on mine but my 475 is pushing around 15-20psi and the he351 is 25-30psi
2006 qcsb 4x4, leveled on 35's, 5" exhaust with FTE resonator, ARP head studs, crower 110# valve springs, 7/16 manton push rods, BBI .5 GDP 2 micron fuel, EFI Live from Wildman, Edge CTS2 monitor, ZF6 swap, valair street dual disc, Stock/s475, pacbrake
Baron85 is offline
