Going Electric - Page 28 - Dodge Cummins Diesel Forum
 50Likes
post #325 of 332 (permalink) Old 12-04-2019, 02:01 PM Thread Starter
Gator1's Avatar
no fans at all on hwy it's 50 deg here.
03 QCLB- 19 to 25 mpg with electric parts, and engine mods....
Gator1 is online now
post #326 of 332 (permalink) Old 12-04-2019, 02:38 PM
TECH SPECIALIST
steve05ram360's Avatar
Grab some cardboard and block the front, drop it down between the CAC and the AC condenser to play with. Mine setup nearly fully covered with just a 10x12 opening in front of the condenser. On the grades here, which is a 300~400' climb temps will start climbing. Usually at the top it stops and either holds or starts to drop again. All that with the fans off. I would be OK with just one of the fans kicking on to control temps as needed. 2 seems way overkill at this point, one fan on low draws 2800 cfm @14A on that test chamber I did so ~5600 combined.
AFE PG7 drop in filter, AFE Torque Tube, HTT 2.5 turbo, AFE e-mani, ATS Arc Flo, 50HP DDP , 428k, HPTuners, G56, 25.065 mpg, mpg threads ->https://www.cumminsforum.com/forum/3...l#post23312562
steve05ram360 is offline
post #327 of 332 (permalink) Old 01-17-2020, 09:13 AM
TECH SPECIALIST
whats the status of your electric PS pump swap?
post #328 of 332 (permalink) Old 01-17-2020, 09:17 AM Thread Starter
Gator1's Avatar
Electric PS, or WP?
post #329 of 332 (permalink) Old 01-17-2020, 09:19 AM
TECH SPECIALIST
PS... you and another guy were chatting about it and i thought you were gonna go for it
post #330 of 332 (permalink) Old 01-17-2020, 09:25 AM Thread Starter
Gator1's Avatar
I couldn't find a pump that was big enough. I got confused on the flow rates and thought it was possible and almost bought one, but flow rates were only 1/3 of what's needed.
post #331 of 332 (permalink) Old 01-17-2020, 09:27 AM
TECH SPECIALIST
whould it make a difference if you split theload between 2 pumps? PS & brakes
post #332 of 332 (permalink) Old 01-17-2020, 09:34 AM Thread Starter
Gator1's Avatar
The AMP draw on one pump is 80, and the cost is about the same as a hydro assist from PSC so I'm going that route. My steering is sooo good right now on HWY. It still needs help on trails, and I want to use it for search and rescue duties.
steve05ram360 likes this.
