Solving the blown fuse problem for e-fans - Dodge Cummins Diesel Forum
 3Likes
post #1 of 15 (permalink) Old 06-14-2019, 09:57 AM Thread Starter
TECH SPECIALIST
steve05ram360's Avatar
I've chatted with a few people who have mentioned the reset-able fuse that goes in-line with the e-fans goes bad after a while. I dont have that type of fuse and use just a regular 30A fuse. In looking for a way to solve this problem I came across a current in-rush current limiter (see links below). This device should fix the fuse problem for us e-fan users. The way it works, in a nutshell is it provides a greater resistance at higher currents. The way I understand it, heat is what blows the fuse and it takes a certain amount of time for that heat to weaken the fuse element for it to melt. The P/N I am going after should solve this problem. I will update this thread as I go.
FWIW, my fans draw 28~29A on hi (when AC kicks on, goes straight to hi). I have 2 feed wires for each fan, one off each battery.
Websites:
https://www.rapidtables.com/calc/ele...alculator.html
https://www.digikey.com/product-deta...1025-ND/749865
https://www.ametherm.com/blog/inrush...inrush-current
Another way to fix this is to kick on the low speed prior to the high speed. The low speed would need to be in an on state long enough to spin up the fan, maybe 1 second is long enough. My original thought was to use a delay timer to control that sequence. Then I found the above solution.
AFE PG7 drop in filter, AFE Torque Tube, HTT 2.5 turbo, AFE e-mani, ATS Arc Flo, 50HP DDP , 412k, HPTuners, G56, 23.348 mpg, mpg threads ->
steve05ram360 is offline
post #2 of 15 (permalink) Old 06-14-2019, 11:19 AM Thread Starter
TECH SPECIALIST
Update:... already.... I contacted Ametherm about this and already have a reply, they are going to provide a recommended P/N.
post #3 of 15 (permalink) Old 06-14-2019, 02:05 PM Thread Starter
TECH SPECIALIST
Another update:
P/N MS35 1R040 should work OK provided the startup current is not choked out. Testing will need to be done.
P/N MS35 0R550 has less startup resistance and may be needed if the above does not work.
Getting samples of both.
post #4 of 15 (permalink) Old 06-14-2019, 02:56 PM
3 footin' through life
Broaner's Avatar
iTrader Score: 11 reviews
My flexallite draw 36 Amps. I'm using a standard marine 50 amp breaker instead of a self resetting style. Working well.
'05.5 6.7 Shotpeened NV5600 - 12.6 @ 111.6 - 994 HP & 1630 lbs/ft
150%'s, LBZ/Arson pumps, MHP +1mm, ZZFab, Wagler Rods, 69/73/1.0 & s482
1350 Frontshaft, TruTrac, 315's, 64" T-Bars,TGC 1/2"+, Carli BJ's, '08.5
Street Triple, 103#/Extreme Pushrods, 625's
Broaner is offline
post #5 of 15 (permalink) Old 06-14-2019, 04:19 PM
02smokin's Avatar
my Brother runs e fans on his truck and we put one of these in.
06 4dr LB Laramie,dynamic stg 4,64.5/73/.91,steed speed,anarchy EFi,Fleece bypass,ARP 425ís,insight,pac brake,6" Carli,long arms, king 2.5's,WFO traction bars,35ís
Sold trucks, 99,02,05,07,14
02smokin is offline
post #6 of 15 (permalink) Old 06-14-2019, 05:39 PM Thread Starter
TECH SPECIALIST
These parts are $10ea and are designed for this problem. By going big on the fuse/circuit breaker you run the risk of melting a wire creating a short and possibly having a fire. I speak from experience with the melted wire & fire part.
The quick fix is to put the 40A fuse in there which I will do if needed before getting parts in hand.
post #7 of 15 (permalink) Old 06-14-2019, 05:40 PM Thread Starter
TECH SPECIALIST
thats 18A per fan right?
post #8 of 15 (permalink) Old 06-14-2019, 06:00 PM
02smokin's Avatar
We didnít use that one it was a example but looks just like it and was a 50amp. Itís the initial start up amp draw that blows fuses usually.
SFDLT6 likes this.
02smokin is offline
post #9 of 15 (permalink) Old 06-14-2019, 07:56 PM Thread Starter
TECH SPECIALIST
Yeah understood, i did not have a peak hold function on my clam amp meter to find out what the peak current was, i suppose i could have hooked up a sense resistor and measured it along with the duration.
02smokin likes this.
post #10 of 15 (permalink) Old 06-14-2019, 11:15 PM
spooled05's Avatar
I don’t have any fuses , just strait off the battery to 2 grid heater relays than to the fans .
A/c triggers the low side ,temp probe triggers the high side .
steve05ram360 likes this.
05 c/c drw 4x4 full billet DTT,billet62/s480,PPE dual fueler,HP tuners,Flux inj.,studded,ported head w Hellmann intake,Hamilton valvetrain, Mitusa gusher,5"flo pro,mag-hytec dd trans and rear diff,guages
spooled05 is offline
post #11 of 15 (permalink) Old 06-15-2019, 10:13 AM
steelhead1's Avatar
steve,
did you try slow blow fuses?
ANL's are good
Bussmann (BP/FMX- 30>60 amp Female Maxi Fuses also work
Dangerous to use automatic reset circuit breakers in a vehicle high current electrical system such as the grid heaters. Engine fires with pressurized diesel fuels burn forever until the battery goes dead or tank runs dry.
steelhead1 is offline
post #12 of 15 (permalink) Old 06-16-2019, 07:55 PM
TheKid760's Avatar
Your running too small of a fuse, thatís why itís blowing. Rule of thumb is fuses should be 125% of amp draw to protect the wire from melting (assuming the correct wire to load was used)
Solving the blown fuse problem for e-fans-11484fd6-b8d6-4153-b4a7-fe5e6cc1ac25-94703-00002f06448f9ea6.jpg
https://www.bluesea.com/support/arti...t_Installation
95 3500 4x4 5spd 4.10 - SuperB/GTA4202 Build, Colt stage 4 Cam, Ported Head, 7mm DV, 7x.012, blah, blah...
TheKid760 is offline
The Following User Says Thank You to TheKid760 For This Useful Post:
Broaner (06-17-2019)
