Intercooler Upgrade - Who do you like? - Dodge Cummins Diesel Forum
 15Likes
post #1 of 50 (permalink) Old 05-10-2019, 11:27 AM Thread Starter
MegaRam07's Avatar
What are you all running and who do you recommend?
2007 Ram MegaCab Dually 5.9L 6 Spd Manual. K&N air intake, 4" straight pipe, Fleece ProFlo 750 10mm injection pump, AirDog II-4G 165, BBI 1.5 Injectors, Calibrated Diesel Stealth 64mm Turbo, FlexaLite electric fans, SBC DD clutch, Edge CTS2, PPEI EFI Live CSP5
MegaRam07 is offline
post #2 of 50 (permalink) Old 05-10-2019, 11:30 AM
Gator1's Avatar
I have a Banks with larger boost tubes, but probably not too much help, it did lower my egt's some.
Jimmy N. likes this.
03 Dodge SHO CCLB Dually Carli/Thuren Argon filled Shocks, radius arms, SRW 4 link Conversion, 17"methods, 42" Goodyear MTR Kevlar Tires / 6 in a row ready to tow!
Gator1 is online now
The Following User Says Thank You to Gator1 For This Useful Post:
MegaRam07 (05-10-2019)
post #3 of 50 (permalink) Old 05-10-2019, 11:35 AM
4everlearning's Avatar
Subscribed, Iím going to need to do this in the not so distant future.
2005 QCSB, cold air intake, guages, a trans built by me and HPTuners tunes by me
4everlearning is online now
post #4 of 50 (permalink) Old 05-10-2019, 12:45 PM
Iím running a cool twist I believe is the name. Honestly didnít notice much if any improvement. I got it as a package deal with my compounds.
2006 qcsb 4x4, leveled on 35's, 5" exhaust with FTE resonator, ARP head studs, crower 110# valve springs, 7/16 manton push rods, BBI .5 GDP 2 micron fuel, EFI Live from Wildman, Edge CTS2 monitor, ZF6 swap, valair street dual disc, Stock/s475, pacbrake
Baron85 is offline
post #5 of 50 (permalink) Old 05-10-2019, 01:33 PM
Gator1's Avatar
Just to add to my exp with the Banks cooler I think they claimed 200 deg drop in egt's...I noticed more like 100-125 deg drop. Buy their oversized tubes will flow a ton of air if you have the Turbo.
post #6 of 50 (permalink) Old 05-10-2019, 01:45 PM
utahtrapper's Avatar
I will do Mishimoto When my times come
https://www.mishimoto.com/dodge-ram-...ler-03-10.html
But wait for a sale or find a local distributor
2006 Blue Laramie DRW. 3500 5.9 G56 Mobil Delvac 50, Tans Cool PTO Covers, GDP Fuel Boss, GDP Double-X Ladder Bars, GPD big line kit, GDP MK-2 Fuel filter kit with CAT UHE 416 1225, GDP Power-Flo Intake Manifold, Throttle Up Industries Dual Fuel Filters, Dieselsite Coolant Filter, Cool Hose, Timbrens, 26k with Horses in Trailer, ................... BBi's .5 Towing Injectors WOW!
Carli Ball Joints
utahtrapper is offline
post #7 of 50 (permalink) Old 05-10-2019, 03:32 PM
05PowerHouse's Avatar
iTrader Score: 7 reviews
The Factory intercooler you have works just fine and is all you need. Your money will be better spent elsewhere
05CumminsCoal likes this.
| Firepunk HP-T | Firepunk Comp 2 | GDP Fuel-Boss | T&C 10mm | Ducky 63% | Billet S400 | GDP Air-Boss | Stud's | Rods | Springs | Gauges |
770HP 1150TQ ( Conservative Tune )
05PowerHouse is offline
post #8 of 50 (permalink) Old 05-10-2019, 03:59 PM Thread Starter
MegaRam07's Avatar
My factory intercooler has blown a hole, plus any way to get the EGT’s down I’ll do the upgrade.
post #9 of 50 (permalink) Old 05-10-2019, 05:07 PM
02smokin's Avatar
Are you having egt problems?
06 4dr LB Laramie,dynamic stg 4,64.5/73/.91,steed speed,anarchy EFi,Fleece bypass,ARP 425ís,insight,pac brake,6" Carli,long arms, king 2.5's,WFO traction bars,35ís
Sold trucks, 99,02,05,07,14
02smokin is offline
post #10 of 50 (permalink) Old 05-10-2019, 06:49 PM Thread Starter
MegaRam07's Avatar
I have a boost leak, only hitting 27psi of boost normal is around 40psi. On my setup I’ve seen as high as 1700 degrees (for a split second) before shifting. I recently replaced all the boots and clamps (Vibrant) and did a leak down test 30psi dropped to 20psi in around 30 seconds, no leaks on the boots.
post #11 of 50 (permalink) Old 05-10-2019, 07:07 PM
Jimmy N.'s Avatar
Like Gator 1, I went with a Banks charge air cooler. It makes everything on the stocker look puny.
'14 1500 V6, '17 3500 C&C, plus a '17 2500 in the household.
Jimmy N. is online now
post #12 of 50 (permalink) Old 05-10-2019, 07:09 PM
02smokin's Avatar
I have a boost leak, only hitting 27psi of boost normal is around 40psi. On my setup Iíve seen as high as 1700 degrees (for a split second) before shifting. I recently replaced all the boots and clamps (Vibrant) and did a leak down test 30psi dropped to 20psi in around 30 seconds, no leaks on the boots.
I understand you need one as yours is leaking, but you would have better luck dropping egts if you ditched that stealth turbo.
02smokin is offline
Similar Threads
Mishimoto Intercooler R&D Mishimoto 98.5-02 Performance Parts Discussion 190 10-19-2016 11:02 AM
Mishimoto Build Thread: 2010-2012 6.7L Cummins Performance Intercooler Mishimoto 4th Gen Performance Parts Discussion 104 12-02-2015 12:16 PM
Intercooler upgrade? BrwnCummins24 4th Gen Performance Parts Discussion 4 11-18-2012 12:05 PM
Intercooler Install samcf1 89-93 Performance Parts Discussion 7 10-04-2012 01:05 PM
