Freeze plugs - Dodge Cummins Diesel Forum
 1Likes
post #1 of 18 (permalink) Old 04-12-2019, 04:35 PM Thread Starter
BigGreenMonster's Avatar
Freeze plugs
I am having issues popping out freeze plugs. Installed brand new Cummins freeze plugs. Hammered them in there just over flush. Broke the cam in, 2k for 20 min... Fine, no big deal. Idled for a little bit no big deal. Reved it up and it popped out the middle plug on the passenger side. ... Reckon I did not have it set in all the way. Made 2 attempts with the rubber deals that did not work. Finally said F' it and pulled the bottom turbo off and hammered a new Cummins plug in there. Just to be safe I put some right stuff on it. Good to go. Drove to the gas station, filled up the tank. Sure enough... It popped out the rear passenger side plug now. What gives. This is a fresh rebuild. Not sure what would cause this to happen. Any ideas are fully appreciated.
04.5 5.9, 6 speed, Colt stage 3 cam, 62/65 over 475, BBI stage 1, smarty so4, fleece cp3
04 1/2 6 speed... Mostly stock
G.D.I. Mo. Fo!
BigGreenMonster is offline
post #2 of 18 (permalink) Old 04-14-2019, 11:19 PM Thread Starter
Anyone????
G.D.I. Mo. Fo!
post #3 of 18 (permalink) Old 04-15-2019, 01:12 AM
JB weld. Make sure your not using a socket that just fits inside the plug, will distort the plug. 3/8" punch and JB weld should hold about anything.
07 3500 MegaCab 5.9,CAI,BMS 50hp inj,SpoolAid,AFE3.5" intake,AFE SS exh,Snow stage 3,smarty SSR UDC
4"lift,5"dual exhaust,HX40 Wicked Wheel,BD Triple disc,Billet shafts,BD stage 4,BD VB,DD pan,Fass150,8an line,Twin fuel filters,Traction bars.
Smoksho is offline
post #4 of 18 (permalink) Old 04-15-2019, 02:29 PM
smelonas's Avatar
Buy the billet freeze plugs. Hate to say it that way. But it's the only way to fix the problem for good.
Sent from my SM-N950U using Tapatalk
1994 Buick Roadmaster Sedan 'Betsy' LT1-4L60E, Every Option Good Old Fashioned Lead-Sled
2007.0 Ram 2500 MCSB Laramie Every Option - ATS S3|FASS 150|DDP 50HP|S&B Intake|4"TBE|CTS2|EFI
smelonas is offline
post #5 of 18 (permalink) Old 04-15-2019, 02:46 PM
3 footin' through life
Broaner's Avatar
iTrader Score: 11 reviews
D&J updated freeze plugs are very nice.
smelonas likes this.
'05.5 6.7 Shotpeened NV5600 - 12.6 @ 111.6 - 994 HP & 1630 lbs/ft
150%'s, LBZ/Arson pumps, MHP +1mm, ZZFab, Wagler Rods, 69/73/1.0 & s482
1350 Frontshaft, TruTrac, 315's, 64" T-Bars,TGC 1/2"+, Carli BJ's, '08.5
Street Triple, 103#/Extreme Pushrods, 625's
Broaner is offline
post #6 of 18 (permalink) Old 04-15-2019, 03:12 PM Thread Starter
I just bought the billet freeze plugs, but I do not want to fix the symptom. I want to fix the problem. Is this a sign of an underlying problem, or is this just a case of incorrectly installed plugs and more pressure than usual due to higher rpms?
G.D.I. Mo. Fo!
post #7 of 18 (permalink) Old 04-15-2019, 03:40 PM
smelonas's Avatar
Cooling system pressure does rise as rpms go higher. That is why people tap and plug the head when they plan to spin over 3200rpms. But if you are still spinning stock rpms. You are either installing them wrong, or the block has been damaged somehow.
smelonas is offline
post #8 of 18 (permalink) Old 04-15-2019, 10:28 PM
Craig06's Avatar
Install a diy coolant bypass also. Use the aquatrol valve set at 45 psi.
06 5.9 CCSB DD leveled, 30% overs, FASS 165, ARP studs, Smeding valve springs, DPS exhaust manifold, 4" exh, AEM intake, Built 48re minus billet shafts, AGP 63/68 12cm IG, 20x10 -20 ballistics, 34x12 AMP tires. EFILive by Anarchy
Craig06 is online now
post #9 of 18 (permalink) Old 04-15-2019, 11:24 PM Thread Starter
What is this?
G.D.I. Mo. Fo!
post #10 of 18 (permalink) Old 04-15-2019, 11:47 PM
Broaner's Avatar
Normally having a plug that keeps popping out is a bit of rust in the hole or some imperfection thats creating an issue with it seating in there nice.
I have a fleece bypass and like it.
Broaner is offline
post #11 of 18 (permalink) Old 04-16-2019, 01:02 AM Thread Starter
You mean in the back of the block? I sldo have the fleece bypass kit. I thought that was more for cooling the rear 2 cylinders than anything else tho
G.D.I. Mo. Fo!
post #12 of 18 (permalink) Old 04-16-2019, 05:53 AM
TWR
TWR's Avatar
Hi as whats been said above maybe installed incorrect or rust/damage to the block, i would install a pressure gauge in the cooling system pipe plugs and see if something else is going on. Popping a frost plug from just reving it up and a short drive to the store, i am wondering if it has very high pressure for some reason?
2003 Ram 3500 6 inch lift, 2012 seats and console [email protected] Shifter, Fass 95 pump, Built 47re and mishimoto trans cooler, Srt10 hood, Smarty touch.
TWR is offline
Similar Threads
06 freeze plugs highly recommended? Jamesmoore24v554 3rd Gen. Performance Parts Discussion 7 09-06-2014 12:30 AM
Do freeze plugs eventually erode? dieselenthusiast 4th Gen Non-Powertrain 5 08-04-2014 12:05 AM
pull motor to replace all freeze plugs? alextsi66 94-98 Powertrain 8 10-07-2012 03:33 AM
Motor's out...things to do. Freeze plugs? Gaskets? HBKCummins 94-98 Performance Parts Discussion 12 03-16-2012 02:54 AM
freeze plugs chicknman 94-98 Powertrain 1 01-26-2011 10:10 AM
