Cummins Swap Setup Input - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 04-08-2019, 06:40 PM Thread Starter
TheKid760's Avatar
Hello all,
Iím new to the common rail scene so I have some ideas but would like input on my general setup.
2003 Ford Excursion 4x4, 5R110 Built with stock common rail stall triple disc (1600-1800?). Weighs 9k empty, 35ís, 2Ē lift, 3.73 gears. It is primarily the mommy mobile so the main focus will be on drivability, reliability, and noise as she hated how loud it was with the 6.0 and my truck (12v). Future plans call for a super hitch and an 11k travel trailer. She also does occasional tow duty with dump trailer (14k) and such.
Looking for a daily tune of around 500-550rwhp and the ability to turn it up to 650 ish. But that wonít be too often I hope.
Engine is a 2005 with 160k, wrecked running truck. Was used up in northern BC as a hunting guide truck, had an oil pan heater in addition the the block heater on it. Donít know anything else about the motor.
Parts:
- Reuse the Donaldson intake from 6.0 (best filtering and should flow plenty for 500-550)
- he351/gta4202 compounds. (Worth it to upgrade 351 wheels?). GTA is a 75/103 compressor and 82/75 turbine with 1.15 wastegated housing. I own both turbos already although the 351 is stock from the truck so will get a rebuild at very least.
- 6.0 upgraded banks intercooler with 3.5Ē inlet/outlets (already in vehicle)
- some cheap intake horn thatís 3.5Ē.
- grid heaters will remain
- debating pulling head for HG as it is in unknown condition. If I do Iíll do mild porting myself and get a valve job done.
- Steed manifold
- 5Ē turbo back exhaust if I can find it for the Excursion. (Has a banks 4Ē I might just keep to make it easier for now)
- cp3 sent to MD diesel for a flow test and arson 3 upgrades
- Injectors sent to MD diesel for flow test and 35% upgrade (65hp)
- coolant bypass
- if I pull the head Iíll thread the coolant plugs under cover
- Hamilton 178/208 cam with their vs, rappers and pushrods
- Fluidampr
- ARP 2000 head studs (unless the rumored Hamilton studs are released)
- FASS titanium 95 (already own bnib) and beans sump
- new oil pump for good measure
- Custom HPT tuning by me for engine and transmission
- CTS2 gauge setup.
Sorry for the long list and words. Any questions or comments let me know.
95 3500 4x4 5spd 4.10 - SuperB/GTA4202 Build, Colt stage 4 Cam, Ported Head, 7mm DV, 7x.012, blah, blah...
TheKid760 is offline
post #2 of 9 (permalink) Old 04-10-2019, 11:17 AM
GRUNT 11B's Avatar
It's a waste money to "upgrade" the wheels in it. Also if you planned on putting a cam in it, your money is better spent elsewhere.
06 QCLB 4X4 G56, SOUTHBEND DD, FASS 150, ARP STUDS, BMS 50HP, EFI, HE351 S475 COMPOUNDS, FLUIDAMPR, HAMILTON PUSHRODS & 103# SPRINGS, 624 HP 1090 TQ 01 QCLB 4X4 AUTO, WHEELS, TIRES, STEERING WHEEL, CUMMINS, BUMPERS, FUEL TANK, SEATS, ETC.
GRUNT 11B is online now
post #3 of 9 (permalink) Old 04-10-2019, 07:27 PM Thread Starter
TheKid760's Avatar
As far as the wheels. I was more referring to size. Bigger turbine do reduce dp or at my hp goals unnecessary.
And the cam: I got a new one for a song and motor is in garage so going ahead with it. Itís only gonna add to efficiency, itís the whole combination not just a few parts that make a difference.
post #4 of 9 (permalink) Old 04-10-2019, 08:39 PM
3 footin' through life
Broaner's Avatar
iTrader Score: 11 reviews
If you pull the head you need to have block resurfaced as well. FYI. Sounds like a good plan. Have fun.
'05.5 6.7 Shotpeened NV5600 - 12.6 @ 111.6 - 994 HP & 1630 lbs/ft
150%'s, LBZ/Arson pumps, MHP +1mm, ZZFab, Wagler Rods, 69/73/1.0 & s482
1350 Frontshaft, TruTrac, 315's, 64" T-Bars,TGC 1/2"+, Carli BJ's, '08.5
Street Triple, 103#/Extreme Pushrods, 625's
Broaner is offline
post #5 of 9 (permalink) Old 04-10-2019, 09:28 PM
GRUNT 11B's Avatar
I hogged out the wastegate on my HE351 to help lower DP. It still gets a little on the high side, but not terrible. You'll also have a little more fuel then me.
post #6 of 9 (permalink) Old 04-11-2019, 02:03 AM Thread Starter
TheKid760's Avatar
Exactly what he said! Though I've never bottom tapped.
Head studs, resurfacing, tapping the freeze plugs are the main things. Many normal places won't know what thats about so its best to find a cummins familiar shop. And when you do find a cummins shop they will hopefully know how to keep the valve seats in it.
Really be thorough cleaning the block. Use a razor blade to gently scrape off anything remaining on it. The 100% sure fire method is to pull the block and resurface it as well. But if you do a good job cleaning the junk off hopefully you won't have any issue.
Surely people donít machine the block every time a head gasket fails? Just trying to get educated, I have no experience with the MLS gaskets.
Would you recommend replacing the studs one at a time instead?
post #7 of 9 (permalink) Old 04-11-2019, 11:06 AM
Broaner's Avatar
Surely... the smart ones do. On 12valves its alot less of an issue. CR's different beasts.
Yes If the motor is believed to be in good running condition and you trust that source I would leave it. Studs one at a time.
Broaner is offline
post #8 of 9 (permalink) Old 04-11-2019, 04:53 PM Thread Starter
TheKid760's Avatar
Thanks. Iím gonna rig it up to run on the stand. See how it goes. Not full proof but at least it gives me some info
post #9 of 9 (permalink) Old 04-15-2019, 11:54 PM Thread Starter
TheKid760's Avatar
Bump. Any other input before I start buying too much.
Similar Threads
Which 2nd gen swap is best with my current setup? bubbaman 4th Gen Performance Parts Discussion 13 08-21-2018 07:35 AM
Completed 1998.5 to 2001 HO Engine Swap RPMI.1998.5 98.5-02 Powertrain 6 04-01-2018 01:50 PM
Aux input Oem Radio DIY me78569 98.5-02 Non-Powertrain 5 02-01-2014 10:30 PM
Need some input on a engine setup peak-j 94-98 Performance Parts Discussion 4 03-01-2013 04:24 PM
Pulling the input shaft on an NV4500 dennhop 98.5-02 Powertrain 6 01-20-2011 11:22 PM
