Turbo blankets - Dodge Cummins Diesel Forum
 9Likes
post #1 of 32 (permalink) Old 03-20-2019, 04:23 PM Thread Starter
BigGreenMonster's Avatar
Turbo blankets
I watched the video and from power driven diesel about the blankets and how they help with spool up. I also want to shield my hood from my secondary turbo.
Of course the turbo folks do not like them. I was told that when you turn the truck off, the oil drains out of the turbo. A thin layer of oil is left on the bearings and the blankets hold enough heat in to basically cook the oil on the shaft. Eventually it will up the bearings.
Who runs them? For how long? Are they worth it?
04 1/2 6 speed... Mostly stock
G.D.I. Mo. Fo!
BigGreenMonster is offline
post #2 of 32 (permalink) Old 03-20-2019, 04:38 PM
TECH SPECIALIST
steve05ram360's Avatar
I run one but short term so far. I think Broaner has them, Grunt also has them (also short term).
If your running your truck hard, you should be letting it cool down before shutting it off. Everyday driving, you should be fine if using a synthetic oil. I've run royal purple for over 250k with zero issues on 2 turbos with no cool down (no blanket though).
Are they worth it? yes
https://www.cumminsforum.com/forum/3...l#post28841265
AFE PG7 drop in filter, AFE Torque Tube, HTT 2.5 turbo, AFE e-mani, ATS Arc Flo, 50HP DDP , 415k, HPTuners, G56, 25.065 mpg, mpg threads ->
steve05ram360 is offline
post #3 of 32 (permalink) Old 03-20-2019, 05:06 PM Thread Starter
This is a fresh new rebuild. I have regular 15/40 rotella in if now with the break in additive. After that I will run shaffers synthetic.
I planned to let it cool down after driving but it will only cool down so much
G.D.I. Mo. Fo!
post #4 of 32 (permalink) Old 03-20-2019, 05:20 PM
KATOOM's Avatar
I have one on my 2nd gen and it clearly worked to reduce EGT's... Not around town stuff but towing in the summer my EGT's dropped considerably because of the radiant heat the intake was sucking in from the turbine housing.
Shut down idle times didnt change either because the turbine is the only component blanketed and the shaft is already protected from heat by the heat shield. So its not going to hold in heat as some suggest... You'd have to wrap the entire turbo to cause something like that to happen.
Jimmy N. likes this.
KATOOM is online now
post #5 of 32 (permalink) Old 03-20-2019, 05:54 PM
Craig06's Avatar
I have a bd blanket. Lowered egts, cant tell you long term effects though. In my opinion though, if u just ran it hard, let it cool off for a few minutes before shut down.
06 5.9 CCSB DD leveled, BBi 1.5's, FASS 165, ARP studs, Smeding valve springs, DPS exhaust manifold, 4" exh, AEM intake, Built 48re minus billet shafts, AGP 63/68 12cm IG, 20x10 -20 ballistics, 34x12 AMP tires. EFILive by Anarchy
Craig06 is offline
post #6 of 32 (permalink) Old 03-20-2019, 06:16 PM
Rhinopkc's Avatar
Turbo timer on my CTS makes me feel fine about my blankie.
Give Us a Call for All Your Suspension, Lighting, and Wheel Needs!
424.241.3252 x700
Rhinopkc is offline
post #7 of 32 (permalink) Old 03-20-2019, 07:29 PM
02smokin's Avatar
I have one but also short term. I always let my truck cool to 350 or lower. Iím not buying the argument about blankets keeping so much heat in to cook the bearings...
06 4dr LB Laramie,dynamic stg 4,64.5/73/.91,steed speed,anarchy EFi,Fleece bypass,ARP 425ís,insight,pac brake,6" Carli,long arms, king 2.5's,WFO traction bars,35ís
Sold trucks, 99,02,05,07,14
02smokin is offline
post #8 of 32 (permalink) Old 03-20-2019, 09:18 PM
lpennock's Avatar
I don't believe the blanket makes coking any worse as it doesn't cover the center where the bearings are. My Garrett doesn't have a issue either way with the water cooled bearings.
Sent from my SM-T350 using Tapatalk
Leonard Pennock AD7AS
2006 Ram 3500 4x4 6sp, F&R TrueTrac, EFI Live, GT3782R, Dual Disc
2018 Ram 3500DRW 4x4, Stock for now
lpennock is offline
post #9 of 32 (permalink) Old 03-21-2019, 01:58 AM
GRUNT 11B's Avatar
I don't worry about it. If i run it hard, I'll just let it cool down before shutting it off, just like i would before my turbo was all cute looking snuggled up all cozy with a blanket.
06 QCLB 4X4 G56, SOUTHBEND DD, FASS 150, ARP STUDS, 50HP INJECTORS, EFI, HE351 S475 COMPOUNDS, FLUIDAMPR, HAMILTON PUSHRODS & 103# SPRINGS, 624 HP 1090 TQ 01 QCLB 4X4 AUTO, WHEELS, TIRES, STEERING WHEEL, CUMMINS, BUMPERS, FUEL TANK, SEATS, ETC.
GRUNT 11B is offline
post #10 of 32 (permalink) Old 03-21-2019, 09:50 AM
TECH SPECIALIST
Snuggies....
Both your twins have blankets right?
post #11 of 32 (permalink) Old 03-21-2019, 10:09 AM
GRUNT 11B's Avatar
Just my secondary/HE351
post #12 of 32 (permalink) Old 03-21-2019, 07:39 PM Thread Starter
Why is that? I got them for both of mine. Figured I would try and keep as much heat out if the bay as I can
G.D.I. Mo. Fo!
Similar Threads
Garrett Powermax Stage 2 GT3782R Install/Review AH64ID 3rd Gen. Performance Parts Discussion 264 10-01-2017 11:15 AM
Injectors, turbo, and studs? Help me out guys Evancold 3rd Gen. Performance Parts Discussion 28 08-28-2014 11:11 AM
ATS Aurora 5000 71/83 Turbo Review w/ Picts!!! shanepx2 07.5 - 09 3rd Gen 6.7L Performance Parts Discussion 91 11-17-2013 05:05 PM
Is this the correct wiring woodworthcummins 3rd Gen. Powertrain 8 04-28-2012 08:07 PM
Switchblade turbo CumminsDieselSoot 3rd Gen. Performance Parts Discussion 3 04-24-2012 02:21 PM
