Heater blower motor working but not blowing air? Easy Recirc Door Replacement - Dodge Cummins Diesel Forum
post #1 of 353 (permalink) Old 11-06-2008, 02:03 PM Thread Starter
CF Administrator
THE STIG's Avatar
iTrader Score: 6 reviews
Ive seen about 4 or 5 threads on this now. Figure I would help everyone out and post how I did it WITHOUT tearing the dash out. A little bit of patience and removal of the glove box door is all thats needed. Here is what I wrote on other threads about it.
If you already have the replacement door kit from the dealer, look over your parts really good and you can see how everything works and what im talking about.
Also be sure its the recirc door causing the problem. There are 3 doors:
Mode door - selects the direction the air is going to blow ie: defrost, feet, ect
Blend door - blends hot and cold air to your selection
Recirc door - choice between fresh outside air or in cab air. You'll know if this is the culprit if your blower motor is on high and hardly blowing.
This is a very simple fix. I had to do it on my 06
  1. First, lay on the passenger floor and you'll see the blower motor, remove the 3 screws that hold it on and unplug it.
  2. Now reach up inside the opening with your left arm and youll hit a loose piece of plastic laying there. Thats the broken door, simply flip it vertical and out the hole.
  3. Next remove the glove box door, you'll see tabs on each side, just squeeze the door past those tabs and the door will want to fall past its normal opening position, you'll see that the door just lifts off.
  4. Next using a flashlight look up inside the dash and youll see where the recirc door housing is. It looks like a checkerboard layout. To the left of that is the servo that drives the door, unplug it and remove the 3 screws that hold it on.
  5. Next comes the only difficult part. There is a while nipple that hooks the servo to the door, it stays in once you get the servo off. Its held on with 3 little push clips that are kind of a pain to pop out. Once you get the white nipple out make sure there isnt any other parts left in there before you start putting new pieces in because they can fall into the blower motor once you kick it on, cause it to go off balance and break things lol I know, Anyways your new recirc door comes from the dealer with a new blower box ect ect, all you need is the door, the white nipple and the servo. Youll see how the nipple drives the door, Its been a while since I did this so If i remember right you have to put the piece on the door, then put them both into place at the same time, make sure the servo is lined up with the nipple piece, screw the servo back on. It wont mount flush if it isnt lined up.
  6. next plug the servo back in, and remove any tools and stuff from the area and turn your key to the ON posisition and turn the heater on (you dont need the blower motor hooked up yet) switch the heater from outside to incab a few times to double check its functioning right, you will have a clear view of it. Servo will move pretty slow.
  7. if everything is up to your standards, put the blower motor back in after inspecting it for broken blades and junk that might have damaged it, put the glove box door back on and you should be good to go!
Took me about 1.5 hour to do without any guidance, hopefully with this you can get it done in less time!! about a $40 fix (I think.. might be $20 now that I think about it)
This should help out alot of guys from having to deal with warrenty and not having their truck for a day and help avoid all this nonsense of pulling the dash out. If I can get my big sausage arm in there, shouldnt be no big deal for a regular guy.
The blower motor in the mounted postion
Blower motor removed
Glove box popped
Glove box hinge
Servo mounted
White clip that links door to servo that needs removed as suggested use a little socket to compress the tabs
Install the new door, white clip side first then snap the other side in. Its best to try and position the servo in a straight up and down postion to make it easier to put the door in
Recirc door open
Recirc door closed
Its pretty straight forward, just a view of some of the parts and pieces here to help you guys out
Powerful - Reliable - Inexpensive. Pick any two at a time, the third is not included.
CUMMINSFORUM. Often imitated, never duplicated. The world's largest #1 resource for everything Cummins Turbo Diesel.
Need something? PM any moderator or report posts anonymously! We are here to help.
THE STIG is offline
The Following 39 Users Say Thank You to THE STIG For This Useful Post:
12ptbuck (07-11-2011), 6.7L OneTon (05-11-2013), billyjobob (12-23-2011), carcrz (05-10-2011), claudester (08-08-2010), commonrailer (01-06-2010), commtrd (06-14-2012), coolfelix (03-11-2010), cudamills (01-07-2010), Cummins736 (05-30-2013), cumminshakesit (07-17-2011), deacro (07-20-2011), docta (09-20-2009), duckabel (11-04-2011), fatdaddy (08-13-2010), fordassassin (06-11-2010), hagar130 (01-28-2012), harvey4804 (10-12-2015), HEARMENOW (06-27-2010), HICKS25 (12-14-2011), Hit.It. (04-06-2010), hpstran (06-20-2010), jeepvin (07-18-2010), knichols (12-18-2010), krazyh0rse (10-23-2009), lmeyer9916 (06-14-2010), Nadz (12-01-2010), nmucci (06-06-2010), oz133 (11-14-2010), redruMHauler (03-09-2010), RollingCoal1983 (06-05-2012), schwabby04 (10-06-2010), smoked05 (02-16-2011), SSmith1247 (05-24-2011), TEX (08-23-2009), Thor99 (07-09-2014), towsit4x4 (06-19-2010), Wayneman (06-19-2010), woody96639 (08-13-2012)
post #2 of 353 (permalink) Old 11-06-2008, 06:29 PM
almor's Avatar
I'm having the same problem dealer fixed it last year for free now I got no more waranty and they're charging me $275.00 to fix it.Ac works but air is barely comming out of the ac vents.
06-2500 LARAMIE 4X4 WITH 2" LIFT KIT ON 33 BFGOODRICH AND BILSTEIN 5100,STOCK 48RE WITH DD MAG-HYTEC OIL PAN AND DIFERENTIAL COVERS,CARLI BJ'S /ADJUST.TRACK BAR AND HIGH MOUNT STABILIZER, SRT-10 MOPAR HOOD, RED HEAD GEAR BOX AND BORGESON SHAFT .
almor is offline
post #3 of 353 (permalink) Old 11-06-2008, 09:02 PM
almor's Avatar
After searching for a while I've found your post the most helpful and I will follow your direction to have my blower door replace by myself. One question though once it's gets to be replaced will the system funtion as it should or will this be just a quick fix and air flow will be different? Thanks a lot.
almor is offline
The Following User Says Thank You to almor For This Useful Post:
Carkon (02-13-2011)
post #4 of 353 (permalink) Old 11-09-2008, 04:19 AM Thread Starter
CF Administrator
THE STIG's Avatar
It will function exactly as factory because all your doing is replacing the broken parts with factory replacements, just a easier way going about it rather than having to tear the dash out. If you bear with me untill I get home on monday I will post up pics step by step and tear into mine again just to show people how and give you a better idea what im talking about.
THE STIG is offline
The Following User Says Thank You to THE STIG For This Useful Post:
post #5 of 353 (permalink) Old 11-09-2008, 08:50 PM
almor's Avatar
Hey dude that sounds great! meanwhile I will get the part from dealer.Thanks for your time and for sharing the tearing down I'm sure there's a lot of people that will benefit from it including myself.Thanks again.
almor is offline
post #6 of 353 (permalink) Old 11-10-2008, 12:40 AM
green'97-12v's Avatar
mine did the same this summer. it sucked. i just pulled the blower motor out and took the broke door and all the peices out. then put the blower motor back in. works awesome now
'06 2500 QCLB, G56, VALAIR STREET DD, SMARTY TNT, BD MANIFOLD, BD SUPER B SPECIAL, FASS PLATINUM, ISSPRO, 5" TO 7" MITERS, LEVELED, 35'S
green'97-12v is offline
post #7 of 353 (permalink) Old 11-10-2008, 03:03 AM
okie's Avatar
I vote to make this a sticky.
04 2500, Reg Cab, 4x4
Smarty UDC, Isspro, AD 150, Arson II, Fletcher Killer B Cam & Springs, Steed Speed, Exergy 60%, Firepunk Comp 3, Anarchy Dual CP3 kit, FMW 467.7
okie is offline
post #8 of 353 (permalink) Old 11-10-2008, 03:11 AM
antwan718's Avatar
What is the part number for the Ac door?
On a side note I have noticed if i leave the AC off and only the fan on then the door will not shut. Only when it is blowing cold for extended periods will I have an issue, have any of you noticed this as well or does this mean the relay to the door is going bad somehow?
-03' 5.9L w/Edge Mileage Max, 4" TBE, GHD, Modular Intake, Boost elbow
-85" Mustang GT CFI
-70" 440+6 Challenger R/T
antwan718 is offline
post #9 of 353 (permalink) Old 11-10-2008, 08:30 AM
Btp 2332's Avatar
I vote sticky also
2012 Challenger Rt [email protected] 11.68 125 shot
1998 12v,[email protected] fuel,S475-sold
Sold-2007, 2010, 2014, current 2002 CTD, TST Powermax 3
Btp 2332 is offline
post #10 of 353 (permalink) Old 11-10-2008, 10:36 AM Thread Starter
CF Administrator
THE STIG's Avatar
Sounds almost like thats another door. Are you sure thats the air recirc door your explaining? All the recirc door does is choose where the air comes from, outside air or in cab air..
"green'97-12v mine did the same this summer. it sucked. i just pulled the blower motor out and took the broke door and all the peices out. then put the blower motor back in. works awesome now"
Problem with that is if you drive the truck in any kind of cold winter condition your allowing cold air to be drawn in from the outside and blow right in where the door normally isolates the cab off and redirects the air to the heater system.... You get a bunch of cold air blowing on the passenger floor and for your passenger.... it sucks
THE STIG is offline
post #11 of 353 (permalink) Old 11-10-2008, 10:46 PM
Jusbecuz's Avatar
Mine broke as well this summer, and now that it is getting colder, I have air coming in the cab all the time from the outside. Can't wait to see the pics and get mine fixed, thanks
2003 3500 2WD, DRW, Quad Cab, 48RE, 3.73. stock HO. Dipricol Tranny, Boost, EGT Gauges, Firestone Ride-Rites
Jeff K. - ACDC
Jusbecuz is offline
post #12 of 353 (permalink) Old 11-11-2008, 09:16 AM
Doubleshot75's Avatar
Hey........ this kinda sounds like the problem I'm having!
I'm new here, and I think I posted this to the wrong forum. So Giddy....take a look at my post, and let me know if this is the same thing you had?
https://www.cumminsforum.com/forum/ge...dodge-ram.html
03' Dodge Ram 2500 Sport
Cummins 5.9
Mickey Thompson MTZ tires
Doubleshot75 is offline
The Following User Says Thank You to Doubleshot75 For This Useful Post:
mb889 (05-19-2012)
