How To: 4th Gen seats in your 3rd gen (pics) - Dodge Cummins Diesel Forum
 17Likes
post #1 of 247 (permalink) Old 06-04-2013, 04:44 PM Thread Starter
PSI
PSI's Avatar
First you're going to need to acquire seats AND center console from a 2010+ Ram 1500/2500/3500. You cannot use the 3rd gen console, the brackets are totally different. I paid $500 for my cloth set from an '11 1500. It took me a few weeks to find them, but just keep calling every wrecker in town and you will find them eventually.
Start by removing the seats. M15 in the front, M18 in the rear. I suggest using a breaker bar to get them started, and move onto an impact to get them the rest of the way out. I feel sorry for you if you've gotta use a rachet to get them out... They're tough.
A couple suggestions when removing the seats:
- You CAN take the whole front seat set out in one piece, but I do not suggest it.
- After all the seats are unbolted, unplug all the wiring and lean them back onto the rear seats. From here, you can unbolt the center console and remove all the pieces individually.
- Be VERY careful when installing and removing the seats from the cab. The brackets on the outside of the seats are easy to forget, and will scratch the heck out of your truck.
There is some wiring involved. I'm not going to get too far into how to wire it up, because wiring is different from truck to truck. However, it's very simple. You simply need to supply +12v to the seats, ignition-switched +12v to the cigarette lighter in the center console and signal to the seatbelt indicator. On the newer style seats, the seatbelt indicator may use two wires. One will go to the trucks indicator wire, and the other can be grounded.
Once you've wrestled the new seats into the truck, you're going to have to make one slight modification to get them to fit properly. This bracket here was hitting my cup holder center console, so I just rotated it out of the way.
You'll need to trim a small tab off this bracket to rotate it.
The center console bracket setup is a bit different than the 3rd gens. The center console bolts onto the passenger seat bracket, and then would bolt into the floor on a 2010+ truck. Since we don't have holes in our floors there, it'll just have to sit on the bracket and be bolted down with the passenger seat. I found that it made no difference what-so-ever, the center console does not move or sit uneven.
Bolt the seats down, plug them in and enjoy. The difference between the old seats and these is unreal. You can actually drive the truck without your butt falling asleep after 30 minutes! Your back won't be out of place after an hour!
I've got some Wet Okole seat covers on the way, that way they'll match the rest of my interior. I wish I had waited to order the seat covers, these 4th gen seats actually look pretty good in the truck, and would probably match the truck if I swapped the rear seats too.
Feel free to reply or PM if you need any help with your swap.
-Kyle
edit:
Finally got my Wet Okoles installed:
Fanman43 likes this.
07' 5.9 RAM3500 SRW(
EFILive, Exergy 40%(124), 225lph CP3, 63/68/14, Hamilton 110#, Southbend DD, FASS150
PSI is offline
The Following 32 Users Say Thank You to PSI For This Useful Post:
04Katya (03-25-2014), 05CumminsCoal (08-20-2018), 06MegaPower (03-24-2014), Anklh (09-15-2013), arinkuddy (07-23-2014), avvblanc01 (05-23-2016), bigtexss (06-05-2013), CTD&TDI (01-19-2016), CumminTryMe (03-17-2016), Dave88LX (07-18-2014), DNMC (10-08-2014), eric5678 (06-11-2013), Fanman43 (06-02-2016), Greenhart (07-30-2013), IH8CALI (03-26-2015), john928 (06-05-2013), kingshado (07-02-2013), KKD (06-05-2013), Lamoureux (03-29-2016), Landlord LEE (09-02-2015), Loki223 (12-14-2015), mcnasty27 (02-05-2018), mikeyt869 (04-10-2017), nibroc (06-16-2013), Nichols92 (06-12-2013), promisedlandorganicfarmer (10-17-2015), Ramcummins5.9 (07-05-2013), ROBBIESWORLD (08-05-2013), slowmover (05-29-2014), smokejunky (06-04-2013), thehulk99 (08-12-2014), Wilky50 (06-15-2014)
post #2 of 247 (permalink) Old 06-04-2013, 05:32 PM
CatGenTech's Avatar
This is a really good wrote up. Thanks for taking the time to put it together.
2006 Mega|Edge CTS|Fass150/Beans Sump|EFI/CSP5 Anarchy|2nd Gen Swap 63/68/.91BW By Anarchy|5" Exh|305/65R17 MickyT ATZ P3
CatGenTech is offline
post #3 of 247 (permalink) Old 06-04-2013, 05:36 PM
patfatnu's Avatar
thats pretty sick
11 Ram 3500 mega 4x4 built bd auto 6.7 Full deletes s471 2nd gen turbo headstuds hi flo grid Heater Efi live 5"exhaust gdp intake manifold bd 90hp sticks bd cp3 fass 6" carli backcountry radius arm lift thuren front end carli sway bar and other carli goodies
patfatnu is offline
post #4 of 247 (permalink) Old 06-04-2013, 05:38 PM
CatGenTech's Avatar
Do you happen to know if the 1500 and 2500 seats have any differences or if they are the same?
post #5 of 247 (permalink) Old 06-04-2013, 06:36 PM Thread Starter
PSI
PSI's Avatar
2010+ seats are the same through all the models AFAIK. I got mine out of a 1500.
PSI is offline
The Following User Says Thank You to PSI For This Useful Post:
CatGenTech (06-04-2013)
post #6 of 247 (permalink) Old 06-04-2013, 07:18 PM
CatGenTech's Avatar
Gotcha. I think this is a project I definitely want to look into doing. Thanks again for the info.
post #7 of 247 (permalink) Old 06-05-2013, 08:24 PM
dirty454's Avatar
Nice write up man! just ordered mine, front and back seat, sure hope the back seat will work tho.
07 5.9 6 speed, 3" lift, 35 cooper STT's, silencer ring MIA, 5" turbo back, Aeromotive Autometer gauges, SMARTY, MP-8 stack, Valair DD!
When your only tool in life is a hammer you gotta treat everything like a nail!
dirty454 is offline
post #8 of 247 (permalink) Old 06-05-2013, 08:33 PM
bigtexss's Avatar
iTrader Score: 14 reviews
The back seat is going to be a little tougher due to the larger cabs. Definitely some seat frame/bracket modifications.
'03 2500 QCSB S06 POD, Beans Sump, Raptor 150, CAT 2mic, Arson III, BMS 100's, he351, Hamilton Pushrods & Springs, 2nd-gen PDI 3pc into 5" exhaust, Opie's Bypass, 15% Ceramic Tint, Morimoto Projector 55w 6K HID Retrofit, 4th gen seats
bigtexss is offline
post #9 of 247 (permalink) Old 06-05-2013, 08:42 PM
dirty454's Avatar
Yea, i looked at the pics between the 2 close and they look the same size to me but i cant pull a tape on a picture lol, we will see when they show up, i will post up some pics when i get them figured out!
dirty454 is offline
post #10 of 247 (permalink) Old 06-06-2013, 03:53 AM Thread Starter
PSI
PSI's Avatar
The back seat will fit, size wise. However, you will need to modify the brackets. IIRC, they're a bit too long, so you'll have to chop them and drill new holes.
PSI is offline
post #11 of 247 (permalink) Old 06-06-2013, 04:03 AM
Adriasn15's Avatar
This is freaking sweet!
2008 Mega Cab 4x4 auto Resistol Edition - mini max, leveling kit, 5in TBE, 37/12.5/17 trail grapplers.
Adriasn15 is offline
post #12 of 247 (permalink) Old 06-06-2013, 04:54 AM
dirty454's Avatar
Good to hear brother!! cant wait to get them in!!
dirty454 is offline
