Frequently Asked Questions - Dodge Cummins Diesel Forum
post #1 of 1 (permalink) Old 03-20-2013, 11:29 AM Thread Starter
That sunset tho....
Mr Sensitivity's Avatar
iTrader Score: 5 reviews
We would like to try out a "Frequently Asked Questions" Sticky which will contain all previously "Stuck" threads eliminating clutter of multiple "Stickies" on the first page of the performance 3rd generation section.
READ THE FORUM RULES PLEASE
Forum Rules
Common Acronyms
Photobucket Tutorial
STARTING PLACE FOR NEW MODIFICATIONS
Basic Supporting Mods
AIR
Compound Turbo Tuning Calculator with Altitude Correction
Turbo Diagrams
Turbo Spec Compilation
Twin Guys Get in Here
2nd Gen Manifold Swap Done
BODY
How to: 3rd Gen Gutter Grille
DRIVETRAIN
How to: Grease the Front Driveshaft
AAM 9.25 Front Axle Pinion Seal Replacement
AUTOMATIC TRANSMISSION
Simple Guide to Upgrading Your Transmission
3rd Gen Mystery Switch DIY Works Great
MANUAL TRANSMISSION
G56 Install/Removal Walkthrough
ELECTRICAL
3rd Gen Gauge Install: Tips/Instructions/Pics
Boost Gauge Installation
My Gauge Install Experience
How to Make HIDs Work w/ Resistors
Headlights Dimming then Going Bright Again
Why do my Lights Flicker and other Helpful Starting Info
ENGINE
Installation: Injectors, Studs, and Springs
Hamilton Cam Swap in your Driveway: Lots of Pics/Dyno Numbers/MPG Numbers
FUEL
CP3 Injection Pump System
3rd Gen Fuel Filter Change Procedure
3rd Gen Popular Fuel Filter Data
CP3 Clocking Results
Write up: Clocking the CP3 Gear to Help Quiet Down a Noisy Pump
3rd Gen Injector Removal/Install Procedure
Injector Sizes and Diagrams
Check Your 4th Injector Line
Replacing Your CP3 DIY
https://www.cumminsforum.com/forum/3r...tor-video.html
MISCELLANEOUS
04-08 Dodge: Info/Specs/Wiring/Etc.
OBDII Code Info
Error Codes: 2003+ 3rd Gen Trucks
03-05 Code List
Official Wheel and Tire Backspace/Offset/Fitment Thread
DIY Thread List
Product Reviews
Rough Idle/Hard Start Solved
FYI Service Specs
3rd Gen Guys: Check Your Hose Clamps
SUSPENSION, STEERING, AND BRAKES
Carli Ball Joint Installation Writeup
Replacing Front Hubs
Steering Box Brace Install/Writeup: 3rd Gen 2006-2008.5
TUNING
Programmers: How do they Work?
EFILive
Documentation/Tutorials
EFILive for Dummies
EFILive for Dummies Part 2: Data Logging
EFILive for Dummies Part 3: Custom Mapping
Smarty/UDC
Smarty UDC Initial Impressions
Bully Dog
Triple Dog PMT Files Click Here
EDGE
Edge EZ Install: 04.5-07
TST
TST Warning: June 2006+ Trucks
2004.5 Carrillos | Girdle | Balanced | Spearco Intercooler | 14mm Mains | 150% Exergy's | PPE Dual CP3's w/ 10mm Stroker pump | Firepunk 66/84 Billet Compounds | Firepunk Comp 2 48re | Dual 165 Air Dog's | D&J Precison Ported/Polished Head w/ Side-draft Intake | Tuned by a cute hobbit who always has warm hands with fingernails that illuminate whatever they hold 1120HP
Last edited by Capt. Slow; 12-25-2013 at 10:05 AM. Reason: Added Photobucket Tutorial
Mr Sensitivity is offline
The Following User Says Thank You to Mr Sensitivity For This Useful Post:
Comanche Scott (08-17-2017)
