Shocks - Page 3 - Dodge Cummins Diesel Forum
 9Likes
post #25 of 33 (permalink) Old 09-12-2019, 01:32 PM
To piggyback on this thread, for washboard roads or hard dips, what one will give the best ride for the price? The Overlands I have do about as well as Bilsteins do in these two situtations, horribly. After a second of washboard road, the trucks front end just starts bouncing.
06 Mega Laramie 4x4 - Anarchy EFI live, CTS monitor, Thuren track back, 3" Soft ride springs, Overland shocks, EMF Ball Joints, 08.5 steering, steering brace, Lots of plans, lack of $$$ | 99 Dodge 2500 4X4 AT QC/swb, a few goodies, 12.37 @ 112.9 - Sold
oaborbag is offline
post #26 of 33 (permalink) Old 09-12-2019, 02:13 PM
smelonas's Avatar
IIRC, reservoir shocks are almost a necessity for heavy washboard roads because cavitation will get the best of the oil in no time if you dont have a res. Fox 2.0s with resis are probably your best bet. Not too expensive.
Problem with washboard is that you really do need the bigger body to help displace more fluid over the valving. The little double chamber shocks with 1.5 or small valve pistons arent crap at anything because they simply dont displace enough fluid and overheat/cavitate quickly. IFP is a bare minimum on a truck shock. Everything else is just good money after bad.
Sent from my SM-N950U using Tapatalk
1994 Buick Roadmaster Sedan 'Betsy' LT1-4L60E, Every Option Good Old Fashioned Lead-Sled
2007.0 Ram 2500 MCSB Laramie Every Option - ATS S3|FASS 150|DDP 50HP|S&B Intake|4"TBE|CTS2|EFI
smelonas is offline
post #27 of 33 (permalink) Old 09-17-2019, 06:54 PM
Thanks, and that was what I figured. Went from Bilsteins, to Overlands, zero improvement on washboards. Guess I'll look into the resi style shocks. The truck isn't fun to drive on the roads around where I live, the harsh bumps are way too harsh, and the I feel like the front end is about to get air on washboards
oaborbag is offline
post #28 of 33 (permalink) Old 09-17-2019, 07:55 PM
smelonas's Avatar
I just need some washboard roads to test my fronts out on. The rear is horrible now!!
smelonas is offline
post #29 of 33 (permalink) Old 09-17-2019, 07:56 PM
tryNto's Avatar
Any washboard road determines a speed you can drive at, it's just not the speed you want to go.
24hrsparkey and rghavana like this.
'03 QCLB 2500 305/555 NV5600 w/ FastCoolers 3.73 4x4, Color match Lear Topper.
Smarty S-06 PoD, Edge CTS for Gauges, DPP Cool Tube w/ OEM AF Box, Baldwin PF7977, GDP MK-2 FF Kit, Pusher Intake Horn, Adj. Boost Elbow @ 30psi, OEM Fan Clutch Delete/Mod, Steering Box Brace, On-Board Air w/Horns
tryNto is offline
post #30 of 33 (permalink) Old 09-17-2019, 07:59 PM
I have a stretch of highway near me and I've tried going anywhere from 55 - 80mph, bounces at any speed, thought its a little less harsh at slower speeds. Sometimes I think its also the wheelbase not helping.
oaborbag is offline
post #31 of 33 (permalink) Old 09-17-2019, 08:12 PM
smelonas's Avatar
That's kind of an incorrect blanket statement to make. It really depends on setup. With stock type suspension, you will only be able to go so fast, yes. With bypass shocks, you could probably do just about any reasonable speed from 0 to 70 or 80. It really gets down to how much money you spend honestly.
You dont redefine physics, you just twist it with money.
Same with building engines. You cant make 1500hp on a stock Cummins engine, you could with a billet and blueprinted one(aka money).
smelonas is offline
post #32 of 33 (permalink) Old 09-17-2019, 08:52 PM
tryNto's Avatar
OK, But a real washboard road is going to have an effect no matter what you spend, you can just go faster with more $$.
Depending on the spacing of the washboard, sometimes faster is smoother.
rghavana and smelonas like this.
tryNto is offline
post #33 of 33 (permalink) Old 09-17-2019, 09:26 PM
Guys it's a VERY Heavy suspension . The unstrung weight must be hundreds of pounds . Sooo much different than say a race vehicle .
So a washboard long section Will determine your speed unfortunately .
SOLD My 2001 and 2005 .
SOLD 2004.5 Sons mod truck
24hrsparkey is online now
