Help me build a better suspension setup - Dodge Cummins Diesel Forum
 3Likes
post #1 of 20 (permalink) Old 08-24-2019, 01:27 AM Thread Starter
matt_green's Avatar
I just picked up this 06 mega cab with a janky 6” spacer lift. I have a full 3” Carli/Thuren set up that I plan on installing.
What is needed for the rear to match the front with a 3” level? I do not have any of the factory ubolts/blocks/hardware so I’ll have to track down any parts necessary to get this thing fixed up.
ID:	854951   Click image for larger version
ID:	854953   Click image for larger version
matt_green is offline
post #2 of 20 (permalink) Old 08-24-2019, 01:38 AM
4everlearning's Avatar
My truck has 2” rear lift and 3.5” front.
The stock rear height doesn’t use blocks. I would go with a 1-2” rear block/spring. My truck doesn’t sit perfectly level and I don’t want it to. I prefer just a tiny bit of a rake.
2005 QCSB, cold air intake, guages, a trans built by me and HPTuners tunes by me
4everlearning is offline
post #3 of 20 (permalink) Old 08-24-2019, 03:07 AM
El Pozzinator's Avatar
Hit up the Filthy Off-road YouTube channel. You’ll learn more about suspensions than you ever thought you wanted to know.
08 Resistol. Anarchy EFI, 5" TBE, grid delete, fleabay elbow, Sinister coolant filter, Carbonite DP sensor, CSS -4" springs, reverse level, CalTracs, Amsoil bypass filter, Revmax VB/TCM, Mishimoto stock replacement radiator.
El Pozzinator is offline
post #4 of 20 (permalink) Old 08-24-2019, 10:27 AM
rghavana's Avatar
3 inch Carli/Thuren setup level
Add mini packs or better yet full leafs and they should come with ubolts, shocks that match what ever springs you have, limit straps if needed.
With minipack you remove spacer on rear axle for 2500 not sure on full springs though.
I would contact CJC, Carli/Thuren vendor for info. https://www.cumminsforum.com/forum/cjc-off-road/
04 QCSB HO Automatic
rghavana is offline
post #5 of 20 (permalink) Old 08-24-2019, 12:15 PM
Shorts's Avatar
Congrats on the Mega.
If you want the rear matched out with the front, I suggest minipacks in the rear. But you haven't specified what you're doing with the truck. Any way you go, I'd keep the rear mild, look at Carli or Thuren for options and balance out your percentages of ride vs haul capacity. A 3" front level is not hard to match on these trucks, your concern is getting the most out of what you do.
CJC is excellent to work with.
2006 Ram 2500 QCSB 4x4 48RE 3.73 285/70R17 AT3s H2s GDP MK2 Thuren 2" Coils Fox 2.0 & Track Bar N62'd "AF" steering Custom Diesel Brace MaxxLinks Modded stock airbox Coolhose 4040XL
Shorts is offline
post #6 of 20 (permalink) Old 08-26-2019, 01:27 PM
nbk9nbk's Avatar
The mini pack is crap, ask me how I know.
Wasted time, work, and money imo not much improvement. Full leaf pack and shocks are worth it. Also lower tire pressure makes a big difference. I have the thuren 3 inch and it sits 1/2 inch lower in front than back...
Sent from my SM-G930T using Tapatalk
02smokin and IH8CALI like this.
nbk9nbk is online now
post #7 of 20 (permalink) Old 08-27-2019, 03:24 PM
02smokin's Avatar
Mini packs are a waste imop also. Like mentioned doing anything to the rear depends on what your doing with the truck and what look your wanting (raked, level or higher in the front).
06 4dr,dynamic stg 4,64.5/73/.91,steed speed,anarchy EFi,DDP 150% overs,fleece dual cp3’s,Fleece bypass,Fass 165,ARP 425’s,Manton springs/pushrods,pac brake,6" Carli,long arms, king 2.5's,WFO traction bars,35’s
02smokin is online now
post #8 of 20 (permalink) Old 08-27-2019, 08:38 PM
I have the same lift in front but 4" blocks in the rear on stock springs Rancho shocks and air bags. The previous owner gave me a Synergy add-a-leaf set and Bilstein remote reservoir shocks.
Is the add-a leaf similar to mini packs? I read a few places where the ride would be harsher with the add a leaf...their website says it improves the ride?
My goal would be to get a better ride as I have air bags incase of heavier loads.
mxer dodge is offline
post #9 of 20 (permalink) Old 08-27-2019, 08:58 PM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 16 reviews
Keep the superspring if your going to be doing any towing. Youll need the shock tower rings when you replace those spacers with Thuren coils. Moog has one that has the ring built into the insulator Moog K160015
smelonas likes this.
1998 12v, 4x4, Club Cab, Carli, Thuren, BlueTop, Core 4x4, BD Diesel, PDD 5x.012, South Bend
2012 Laramie Longhorn, EFI by Ryan, Carli, Thuren
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is offline
post #10 of 20 (permalink) Old 08-28-2019, 10:45 AM
smelonas's Avatar
Thuren lift will be a little cheaper than carli and you can get specific valving specs from thuren. However, dont discount the carli set, their products are absolutely top notch.
Thuren has some new springs, the extra softs and his standard softs still of course.
Will need just a pinch of lift for the rear to match a 3 inch front lift.
Definitely get some big shocks and all that good stuff. If you think it's too much, it's not enough haha
Sent from my SM-N950U using Tapatalk
1994 Buick Roadmaster Sedan 'Betsy' LT1-4L60E, Every Option Good Old Fashioned Lead-Sled
2007.0 Ram 2500 MCSB Laramie Every Option - ATS S3|FASS 150|DDP 50HP|S&B Intake|4"TBE|CTS2|EFI
smelonas is offline
post #11 of 20 (permalink) Old 08-28-2019, 11:34 AM
nbk9nbk's Avatar
The extra softs are not 3 inch correct ?
post #12 of 20 (permalink) Old 08-28-2019, 12:04 PM
smelonas's Avatar
Check the website. I'm not tremendously familiar with his product line. Especially new products..
smelonas is offline
